A Way to make your SG fan go better :)
  • A Way to make your SG fan go better :)
    Mother nature knows best Using the Humpback whale's ability to tweak fluid and bio dynamics (create vortexes) Here is a concept to run turbines and fan blades at 40% better efficiency!
    Concept comes from
    WhalePower Fan Test | Whalepower
    Fan is here and should have an SG circuit on it,
    Envira-North Systems Homepage
    Byomimicry is very underrated it seems
    Ash
    Again, nature shows us.
    Very nice Ash, can't wait to see that on airplanes ! Less consumption, less noise ...
      Really nice finding Ash
        love it!
        Good stuff bro
        Maybe we should couple this with SELSAM
          HI EgmQC, digitz /Ren ALL
          I Think we should make a rear car Fin with this design for Ren so he could drive up my way with less fuel more often
          They would definitely Rawk on those turbines Ren, I cant help my self guys, i am going to play with the SG fan with this soon, just going to try and find the patent, i bet you its balanced really well, a rear car fin should have this too, i dont see any reason why it should not work. Maybe one of those fans could go on a 10 coiler for better out put.
          I be you any money that there is a tone of BIO MIMICRY capacity which we have all over looked my friends, I bet you there is more.
          Ash
            Great discovery!
            Wow! Pretty much all i can say.
            That is awesome. I'm telling all my friends.
            Thanks Ash!
            EnergeticTube.com - Where technology goes Live!
            ETaffairs.com - Your Portal Here on Earth
              It's about creating and utilizing as much IMPLOSION as possible....It's the same principle behind scales on fish, and the feathers of a bird. Every tiny protrusion from the surface of a moving object has a low pressure zone behind it...the more you make, the more suction you create behind you for the incoming fluid flow over the surface, speeding up the passing air, the faster you go due to lower resistance from lower fluid density.
              Take a good long look into Schauberger's designs. Supercavitation is the end goal with this design properly implemented.
              From what I've seen, if you have a smaller, nearly detached protrusion ahead of the main body of whatever is moving, it helps a lot.... look at the shape of the earth's magnetic field as it is distorted by the bombardment of energy from the sun.
              Whenever a distortion in an object is created through interaction with a fluid it flows through, or the object creates a distortion in a fluid it flows through, I think the object should be redesigned to be the shape of the entire distortion.
              It's also about including the reactive half of the equation in addition to the active half in a device. For every action there is an equal and opposite reaction..... why fight this reaction when you can make it do half your work?
                You bet Ash Though by the time I could afford to put that wing on my car we will all be flying UFOs
                Didnt we (Aussies) do something similar on our swimming costumes for the olympics? Modeled after shark skin?
                  Concept comes from
                  Ash
                  You actually found a great way for the fans, as this will be better for us to get the proper implementation of these fans.
                  I will go through this resource as it will be beneficial for me in my projects.
                  is something scam
                    you guys are the man not me
                    Man ALL of you here do so much good you dont even realize, its my job to make it count, thanks for the posts guys.
                    If i help and support one energetic forum member, i AM HAPPY.
                    Ash
                      Hey, for me also it is very useful to know some the importance of energy and what new we can do to save energy which can be used later in a future as, it is very necessary for us to save energy in every aspect otherwise, we will not have any resources left in future.
                      is something scam
