Thank you and I'll need to signup over there. I believe that it may be a step up transformer, but I have to start somewhere. If this does nothing but step up the MOT then I will learn from that too. I look forward to reading the other thread and seeing what others have done and trying add what I can.
Kapagen Theories, Replications, Winding Diagrams, Circuits & Schematics. KAPAGEN ONLY
Hello Friends energy forum
I love the theme kapagen
but took three weeks, trying to light a lamp, and I have not gotten
I tried everything, diode, microwave transformer, grounding, and I consegir nothing even longer for despair I placed a 6-volt lamp, and is illuminated but feel sad to see it, hehehehehe
the desperation led me to use trial and error will
and finally e coseguido 1000w light a lamp, but the transformer gets very hot, the spark gap, it sounds very intense but at least I have received a smile to my face, jejejejeje
leave here the level of modoficacion, for some desperate like me
this test, it makes me think that the transformer and capacitor diode work perfectly
Some of you have worked on kapagen to the amendment?
chauuuuu
hello friend Jiffycoil
ok friend, I also am using a very Codensa parachute, has the same capacity as yours, but yours has the naked eye is larger
I as I said above I have not turn on the lamp I am using for 1000 watts, with a single capacitor 1mf, so I placed three condesadore in parallel, and so I have come to light, I've also changed the distance of Picasa land, and placed, at 2 feet away, which has improved brightness
I think one of the problems I had is that the soil is wet, after it has rained much here
thanks for your reply and good luck with your work, I see you're a thin person on the job
chauuuu
Hello Ismael 34,
Thank you again my friend for the kind words. The light board I show in the photographs has 10-100 watt bulbs, and in tests both Kapgen generators which I have built light all the bulbs. I'm happy for your success and you may be correct about the wet ground causing problems for your tests. I look forward to my tests. I'm awaiting arrival of the Luxmeter and then I will be ready to begin.
Kapagen
Please I want you to send me the the names of the all the components used to build kapagen. I have not been able to identify some I could see the microwave oven transformer, diode and capacitor but some other items I cannot recognize. my email address is [email protected]
kapagen
kapagen
Hello Dejiola2001,
All of the build information I used is on this page.
As far as hardware goes with the build you have to source whats available to you. For example the JLN Labs build uses Epco surge arrestors across the terminals on each light bulb. I could not source those so I got as close as I could with another brand. With building the coil I think no two builders coils are going to be the same. If you go to the page I attached you will see a build list at the bottom left corner.
Resonance: The Key
Hi all,
Please note that the following are based only on my personal research and experience.A Closer Look At The Mighty Incandescent Light Bulb:The Ground Circuit:The Reversed Tesla Coil:
Using the ground circuit mentioned above I have constructed a finely tuned Tesla coil where both the primary and secondary coils resonate at the same frequency. When this is achieved or close to it the Tesla coil can be efficiently used in normal or reversed configuration.
This is provided your HV source is feeding it with the correct frequency.
My finely tuned Tesla coil now allowed me to do away with the spark gap and grounding all together. This is very imprtant for the self feeding part of my setup. This begged me to ask the question.
I believe Tariel Kapanadze's device to be very simple and based on well known principals.
Hope this info helps you in your search to deciphering the Tariel Kapanadze Generator.
Would show us your schematic diagram ?
To: ZincFold
If you success to replicate the Kapanadze set-up,
would show us schematic diagram as well as photo of your device.
It will be very helpful to other people to replicate the device.
Is is really self running device ?
Thank you.
Thank you for posting this. I'm in the middle of testing my replication and appreciate hearing and seeing what others have done. I would love to see the replication that you used in your experiments. Having only details and images of what others have done to base replications on, seeing others work helps all who experiment. Do you also have details of watts in and watts out? Seeing those numbers would be very helpful so I can gauge your results with mine and the others who have experimented with the Kapagen generator. I would love to see the Tesla coil you talk about in the "The Reversed Tesla Coil" segment of your post. Being an old Tesla coil builder I love to see other coils. We can learn so much from seeing what others have done.
