Be gentle, I'm new
I've been considering building a wood-gas generator for quite some time (after watching The Colony, a post-apocalyptic reality show). I never knew such things existed, much less that they were once in wide use throughout the world.
ok, now my situation. I want to make a wood-gas generator generator. By that I mean a wood-gas generator feeding a gas-powered electric generator.
Some other info:
I have lots and lots of dead trees to work with. they grow and die off faster than I could possibly use them.
I plan to use a 5hp Briggs-and-stratton engine, attached to a pulley/bracket system with probably 2 or more car alternators. (before anyone mentions it, yes, I am aware of the lawsuit, and that it probably has significantly less than the advertised 5hp) These alternators will be wired in parallel (for constant 12-14v, but more amps), and then wired into a 12vDC to 120vAC inverter. Yes, I'll have a battery hooked up for the 12v field. I'm also considering taking apart a broken gas-powered (factory-manufactured) electric generator, and using parts from that (a number of advantages to this, like no need for a battery). I think the engine is the only part not in working order. At this point, though, I'm mostly interested in making plans for the wood-gasifier itself, and just getting it working. All the electronics can be handled later.
what I can do, and what I have:
arc-welding and brazing are fine. light metal work (what can be done on an anvil) is probably fine. grinding and cutting (including with a cutting torch) are fine.l I have various pipes, piping connectors, pressure tanks, metal sheets, barrels, bars, and pieces, bolts, nuts, and lots of other junk that I have to work with. I would really like to get this thing working while only using scrap junk that I have lying around. I'll have to buy sealants and some small things, though, probably.
Advice on any part of the system is appreciated.
I would really like some input on the wood-gassifier itself. I don't have any experience with them whatsoever, and I'm open to all ideas and input.
At the moment, I'm thinking of making a "stratified, downdraft gasifier," not an imbert. The main reason is because I want to use larger chunks of wood. In fact, I want to modify the design to allow for even larger chunks of wood. Any idea on how to do that? Here is a link to the design I'm thinking about basing my model off of: http://wood-gas.com/wp-content/uploa.../woodgas12.pdf
A few more modifications might need to be made since it will be for a stationary engine. More cooling and maybe another filter will be needed.
Wikipedia has good info and some very detailed PDF and web links: Wood gas generator - Wikipedia, the free encyclopedia
Thanks in advance
PS: this isn't too technical for this site, is it?
If there are other forums you think I should check out, please let me know
Some other info:
Thanks in advance
maybe I can modify the design to get higher temps to crack the tar (break it down into smaller carbon chains for easy burning, and far less stickiness).
