Between each section a unidirectional gas release valve with a wind turbine on the gas release into the other end. The turbine turns when the gas from the other tube pushes through the unidirectional valve. So the two noble gases do not mix the tubes will have a sliding divider.
Will using two noble gases, one with a low atomic weight and the other with a high atomic weight create a constant wind in a controlled loop wind turbine system?
File:Endohedral fullerene.png - Wikipedia, the free encyclopedia .
Atomic weight - Wikipedia, the free encyclopedia
Noble gas - Wikipedia, the free encyclopedia
! I hope you can do it, good luck to you. Keep us updated with pictures on your progress, please?
