Mr Wiegand's Wonderful Wires
  • Mr Wiegand's Wonderful Wires
    Here is an very interesting macroscopic engineering of the Barkhausen effect.
    When a ferromagnetic material is subjected to a magnetic field, its domains align to the field, however not in a smooth gradient. Rather, domains "snap" into place as the core reaches sturation. This is called the Barkhausen effect.
    Mr. Wiegand recreated this effect in a macroscopic sense by creating a "wire" which acts as one large magnetic domain. As a magnetic field increases near the wire, the domains, all at once snap into position, creating a large uniform pulse. This could be referred to a magnetic avalanche mode.
    I found this very very interesting, and immediately thought of applications. Wiegand wire is generally several mills thick, however I would imagine that creating a larger version would be much easier than attempting to manufacture the wire itself. Imagine creating electromagnet cores, which go to avalanche mode when a predetermined level of saturation is reached, causing the entire core to suddenly flip its polarity independent of the speed of change of the magnetic field which initiated the flip!
    Wiegand effect : Define, Explore, Discuss
    Popular Science - Google Books
    The Barkhausen Effect experiment by Jean-Louis Naudin
    Here is an enlightening quote from Naudins experiments on the Barkhausen Effect which if hold microscopically true, could infer a macroscopic correlation.
    "The most interesting in the Barkhausen effect is that there are no magnetic links between the source (the 2Hz flat excitation coil) and the EM induction produced by the Barkhausen jumps inside ferrite toroid core. So, this can be a path to explore for building Free Energy generators due to this non reciprocal effect (see the Bakhausen scalar detector from Bob Shannon)."
    Here is an interesting quote I found searching...
    "ON FREE-ENERGY: EMAIL RECEIVED BY INE FROM TOM BEARDEN, SEPT. 8, 1997"
    "By the way, anyone who thinks that a permanent magnet cannot be made to "change" its own field itself, just needs to go back to school! E.g., a validated example for three decades or more is given by the Wiegand wire, around which there are numerous patents. The Wiegand wire is used in all sorts of things to obtain "free" switching. Coil lots of fine wire around the Wiegand wire, and when the wire spontaneously switches its fields, it will will generate a voltage pulse in the coil. That is used for all sorts of sensors. The Wiegand wire switcher is even used to produce some automotive ignition systems, particularly in Germany. Why university EE and physics departments are not vigorously pursuing this sort of thing for switching the fields in a magnetic motor with the Wiegand effect and assemblies of self-switching magnets is again something inexplicable."
      A very interesting patent which deals with this subject.
      High-output magnetic field transducer - Google Patent Search
