Tesla,
Very interesting stuff. Sounds like you've done alot of reaearch in this area.
I see high voltage is the way to go, makes sense.
On the HP I figured about 1 from the torque test. I think I could get about 4hp or more if I put another coil on top, then double the voltage.
I had a thought yesterday on possible making a coil that would double the output power from the bemf. Lets say we want a 100 ohm coil for a motor. Instead of winding one coil, wind 2 coils at 200 ohms each and wire them in parallel, but shaped as one coil for the motor. The input power from the power supply would be the same, into 100 ohms, the magnetic field should be the same. The bemf from each coil would be twice the voltage, half the current, but in parallel. So the current would add together, to equal 1, and the voltage in parallel would be double from each coil but in parallel so not add together so equal 2. Compared to the coil wound at 100 ohms the bemf now has twice the return voltage because of twice the windings. What do you think? Is that a patented coil design in the making?? Haha. Let me know if you think that is worth testing.
