Hey guys. I have very very little experience in circuits, and wiring, soldering etc..
I built this circuit using a bread-board and for the wire's used 22AWG magnet wire.
When everything is hooked up nothing happens, I think it's because the magnet wire had a coating so it wasn't making proper contact? Should I strip the coating using a razor blade? Or use 16AWG wire thats easier to make contact?
I have plenty of options on how to connect the wires, I bought plenty of alligator clips, crimp's with open U shaped ends(Seen on left of pic). I also have plenty of electrical tape...I'm not sure which one to use, so many choices...help please!
I have been following the video here YouTube - How to Build a Bedini Motor ... Part 2 to build the circuit
Here is what I have so far...
keep an eye out for me
So I'll try again. Glad you got it to at least run. You are correct about your magnet spacing. The magnets should be about 3-5 magnet widths apart. So you will need to make a new wheel and get about twice as many magnets. Also the orientation of the magnets is important. It is hard to tell from the picture but it looks like your magnets maybe are mounted with the long part of the magnet aligned with the wheel. The long part of the magnet should be parallel with the axis of you wheel. The idea is to have the magnet move past the center of the coil as fast as possible. The magnets should also be regular ceramic magnets not strong neos. We only need the magnet to generate just enough power in the trigger winding to turn on the transistor. You also need to make sure all magnets are mounted with the north side facing the coil and the south side facing the wheel. The wheel also needs to turn very easily. It should spin for at least a few minutes without power after you give it a hard spin by hand. Many people have failed to get good results from their SSG because of excessive drag on the wheel. It also seems you are getting some bad advice. You do need a good core in your coil if you expect to get good charging and easily be able to tune your SSG. The core should be soft iron wire. Think electric fence wire or welding wire or even coat hanger wire is better than no core. It needs to be able to be magnetized when the coil turns on and needs to loose that magnetism when the coil turns off. Copper will not work. Cut the wire to a little bit longer than your coil and put as many in the coil as you can. I have a SSG made with a 17" aluminum bike wheel. It has 12 magnets. I can give it a gentle push and it will take right off. It also charges very well. Some of these things I have told you you may already know, but I am trying to help you double check everything so you can get a good running SSG.
