Hi 7imix, I'm using a bridge rectifier to charge a battery and place the probe and ground on the AC connections of the bridge, so i'm charging a battery while I do it. yes I did see your frequency go up to 28khz but it looked like the waveform got a little less straight to me after a point in the video, not much though.
Here's a shot
Though I'm not exactly sure what frequency that is. I think onlyabout 12khz.
Sucahyo I remember you talking about a small capacitor in series with the the bridge on stingo could you tell me how that is wired is it placed accross the AC connections of the bridge?
Edit#2 7imix, I forgot to answer your question about the coil, sorry. I have a couple that do it one is carefully wound 3 layers on a 10mm straight cylindrical core about 28 winds total 1mm wire, the other is less than 15 feet 0.7mm wire very roughly wound on a toroid. 20khz seems to be my Stingo's limit.
Here's a shot
also purple carona stuff in a couple of spots, i've changed to both in parallel then two arc's one in series one parallel, wow, and wireless lighting neon's and fluro's will upload another video later I gotta find my tripod and make some room. This thing was just breaking down the insulation in no time where the coils were too close together and arcing up like mad.. I'm having a real laugh with this, when i stop the battery voltage go's crazy.
It's a bit wierd because my picture camera batteries went flat too, really quickly, just a coincidence I suppose. Anyway the wireless lighting effect is real but doesn't go for very far. I'm driving the ignition coil with stingo's AC ability.
. Just in case it is not a coincidence, put some metal bar preferably alumunium between them. Or protect the device with alumunium wrap. I think stingo spark is more destructive than other circuit spark. I think it is possible that it produce something meter can not detect but the battery can feel it.
