Pyramid
General D.Eisenhower
http://www.nvtronics.org
Sucahyo and Blackchisel:
I make my own rods. They can be tuned also. Tuning is important if you can't get it to work. The more you use them the better you get at detecting the different field strengths... as you also become more sensitive to the faint energies.
It is your soul or spirit that is reading the fields. The rods are like the neadle of the volt meter, but you become the meter.
One can feel the wind, even though you can't see it. Reading aether with meters is like trying see the wind. Once converted, like converting wind to electricity with a windmill, then it can be measured by meters.
The rods do detect something like magnetism, or gravity waves, but that is not what it is.
What is magnetism? It is the same force as gravity waves? I don't think so, but I just don't know.
The thing to remember is that Aether is the source or all sources, and the power of the vortex is what controls and manipulates it. There is also a vortex going on inside the pyramid, again it's a vortex within a vortex. So, how to tap it, is what we are looking for. Separation of the positron from the electron, May be the Key.
This is something that needs to be looked into...
Sucahyo:
I tested the pyramids polarities again, and I got the same readings. There is still the same difference as the first time, between the 1/3 level (north), and 2/3 level (south) direction. So there is something going on there.
If there is anything else that you'd like for me to try, just let me know.
You can also try it for yourself, if you have a big enough pyramid. The rods themselves can be made from practically any materials, like iron, brass, stainless steal, etz... If you are sensitive enough the materials won't matter. If you are not sensitive, none of the rods or pendulums will work for you. So, it's all about being sensitive.
Some people mention that rods as well as pendulums should be made from certain materials and tuned for specific purposes. Although that may be true, I think that if one is sensitive enough, even a rock on a string will function as a pendulum.
One of the future sciences is electromedicine, and also astromedicine. We are slowly getting there. The pyramid may hold the key. As what are called vents in the Great Pyramid are not vents at all. The people that built the structure did not need water running underneath it to produce power. As anything and everything is made from Aether, and the pyramid is an aether focusing device. There may also be other ways to produce electricity, as also other ways make usable light.
We have only been at this electricity "business" for 100 + years. If the money involved were not present, we may have found secret key long ago. We are still only babes, when seem through cosmic eyes. Another couple of years will make or break us. You can feel it in the air...
At least I can.
NickZ, thanks. What exact length did you cut tour brass rod?
What kind of radiant circuit that you have NickZ?
Can you try this:
Connect a bucket of water to your radiant circuit positive output (after the diode) for some minutes. Then after you can detect polarity happen on the water, disconnect from radiant circuit and connect it to the pyramid.
Would the pyramid energy change with the water or the water polarity change to the pyramid?
This is to test the pyramid strength. to compare with radiant circuit.
I can only use pendulum. Reading various rule for length made me interested in trying to read rod energy. The problem with pendulum is it is too coarse. I measure square produce opposite polarity or pyramid.
I think water is very usefull to hold / sustain the energy capture by the pyramid. We know that water is programable.
Sucahyo:
I am pretty unscientific about making the rods.
I've used several types of materials, but 1/4 inch brass round rod is what I prefer. The total length is 14 inches, 12 inches long, and the handle is 4 inches. Most people use thinner rods, that are lighter and easier to use, like 1/8 in thick, or so.
You can use one or two rods, for water dowsing 2 rods are normally used. But most of the time I just use one.
In the Separate Attachment is a drawing of the small 4 or 6 inch pyramid coil idea. A Jtc can be placed in the center, and a big cap could hold the pulses that are sent back from the bemf from the frames coil. Just a thought,
There is also a few pictures of some of my Joule Thief circuits, a 12 led Captret, a Captret- Jtc, and the small Bumble Bee coil is a tiny solar Jt. Just some of my latest toys, they are lighting my house (as night lights), all night long.Last edited by NickZ; 07-23-2011, 03:42 PM.
Thanks NickZ.
I read length at site bellow:
Interestingly, your 14 inch is close to:
Nice result with all night long light35.8 cm
Distance of Earth to Moon, a known nodal distance for earth gravity / 8 x
384,403,000 m
22.912 m
2.864 m
35.8 cm [24x fractal]
4.4750 cm
.559 cm
35.8 cm 14.0945" [ 3/32"] 24x fractal system
Dividing by 8 is not a true fractal but noteworthy of the sheer number of nodes that do pop up using this system. The nodes are very much present showing a true resonance. This number may be useful for bending into circles as 14 inches is longer. For a perfect circle the nodes would remain stationary.
Maybe you only need to wound the square and try to capture the spike out of the triangle peak.
Connecting only one wire can change balance. With battery powered circuit connecting one wire to a bucket of water can make it more positive or negative than ground depend on circuit and terminal used.Last edited by sucahyo; 02-22-2011, 06:58 AM.
Sucahyo:
Total lenght of the rods is 16 inches, not 14 like I mentioned before.
It's a matter of feeling, if the rod it's too long, it will moves a bit slower, a shorter rod is quicker to respond, but not a may not provide the same field sensitivity. You can always cut them shorter, but since you can't make them longer, start a little longer, and trim them to where you feel that they have the best balance, when held in your hand.
I see, thanks. That is different with the way to get resonant rod in the link I post previously. The writer mention that with hand the rod feel to have segment of energy. If we cut it to the exact node, we get rod that response more.
I will try it.
Sucahyo:
Dowsers depend on the direct feelings from any emanations visible, as well as from invisible sources.
The 14 to 16 inch total rod length will work fine. Just try it and see. You can also make several different types and lengths to try.
Every thing emits vibrations and waves, which can be be felt with the rods regardless of tuning. It's not like it won't work if the rod is an inch or so longer or shorter.
Testing the 1/3 and 2/3 areas in the pyramid, can also be done with a pendulum. This may also show the cw or ccw direction or flow difference.
I will try to connect a joule thief to the bucket of water, later on tonight. But, I'm not sure how to how to determine the outcome.
I have heard the water can be charged, and is the reason I prefer to drink Live flowing water, from wells or streams, instead of the dead boiled stuff in the bottles.
I have tried a 10 inch steel core bifilar coil placed on the very top of the 6 foot pyramid, but nothing special to report. I think that a copper air core coil may work better, but who knows.
I feel that there is something to the Dome device and its ability to produce lots of current. Nobody else has be able to produce that much current with any other device. The thought comes to mind, to try to do something similar.
Your polarity difference idea, may be similar to the reason the Dome works as it does, in separating the + from the -. In doing so, we may also be separating one kind of energy from another.
Interesting that you mention about the mangos falling, as we have no mangos fruiting here right now, since they are not in season. In Venezuela for example the mangos are harvested twice each year, but here in Costa Rica they only produce from May to July, once a year. So, I see that the reason is because there is more life force present there year-round, as also different currents.
There was a device that was originally called a
Vortexometer, then the name was changed to Radiometer, when it was commercialized many years ago. It was a clear vacume sealed glass bulb with 4 mica cups inside of it, that were black on one side and white on the other. They spun around when placed in the sun. The device proves that the more light intensity there is, the more energy is present in the air.
At 10.000 feet altitude there is 40 % more visible light intensity, and therefore also more energy present in the air.
Thanks NickZ. I have something said to produce big polarity. I will try on that. I forget where I put my copper tube so I will try thick copper wire.
I have been trying to make artificial live flowing water. I find cemenite and copper tube help somehow.
The mango is the same. While there are artificial way by spraying chemical to force it produce fruit twice a year, my neighboor mango is surely never be treated with anything. The tree supposed to already pass fruiting age. The tree already produce fruit few months ago but some how there is one or two fruit keep growing. It taste very sweet too, unlike what my neighboor mention it was. So my neighboor is not too excited seeing the mango have fruit again. Besides, the only branches that produce fruit are the one that grow over my yards.
On ATREE reference, the energy is said to accumulate under the ball skin. So normal electricity over, radiant electricity under.
Interesting info on radio meter
Sucahyo:
The last link you sent did not work.
Earthquake in New Zealand. (check the picture).
I was wondering what this last Feb. full moon would bring. New moon can also be just as strong an effect. 3 days after the full moon is when the highest tides are noticed here.
Less than two years left...
The last fruits to fall from a tree are always the biggest, and if totally ripe will have the best flavor. As all the energy from the tree is only shared by very few fruit, so, there is more flavor and a bigger size. My wife puts fruit out in the yard for all the birds. If you do, you will have all the birds in the area in your yard.
I had an huge avocado tree that would harvest about 4000 fruits, and about 3 times that many would fall on the ground while still very small and unripe. The tree could only handle 1/3 of the amount of fruit that it could produce. The rest would fall off by themselves. 4000 were sold.
I have a small analog volt-meter, but it is not very accurate at voltages under one volt. Can this meter be used to determine the water bucket test. And how to do it. I was busy the last couple of days and have not done the bucket of water test yet. But, I did try to see if my pyramid would light a joule thief, but so far, no results.
Maybe a proper capacitor is needed, for the energy conversion to electrical output. The joule thief will light on about 1/2 volt in the battery, but I don't think that there is any electric output from the pyramid frame, 0 volts by itself. A grounding wire to an outside ground source probably is needed, I have not done that yet.
That site seems down often, I attach the page.
It is worrying to see the event coming. A friend who has orgonite and cloudbuster post very proud achievement of not having cyclone for two years, then cyclone strike his town three days after that for days. Two lesson, first prepare for the unexpected, second, don't let coincidence to cloud your judgement.
The mango tree still produce tasty fruit when it produce many fruit last year. People do force reduce the fruit to make it tasty. However I think if the condition is right, we don't need to do that. If you have farm, can you try cemenite and clockwise copper in watering device?
Volt meter can detect voltage difference of water bucket with ground or our body, especially if your circuit output >100V. But that will register value right away. Won't need time to wait. Not sure if it still register voltage after we disconnect it from radiant circuit, but I bet it can be around 1V like some electrolysis experiment shows. But that is not what I meant.
What I meant is to measure it with your dowsing rod. To see if pyramid energy change with the water bucket. If it is then putting joule thief in the pyramid is useless because pyramid would be weaker then the joulethief in term of unseen energy generation. Joule thief will influence the pyramid instead of the opposite.
Try to see if pyramid frame show some voltage in voltmeter compared to water in a bucket.Attached FilesLast edited by sucahyo; 02-24-2011, 03:01 AM.
I can see no voltage from the pyramid frame, but I think that I need the - outside ground connection for it to register the difference in potentials. I will do that also sometime, when I get a 5 meter long wire and copper ground rod. I also think that you would need a capacitor to convert to any usable electric power. What do you think? I don't mind the joule thief being stronger than the pyramid if there is something to be gained. I wish that I had more insight... and the bulb in my head would light up, also.
Not from pyramid frame to pyramid frame but from pyramid frame to water in a bucket.Originally posted by NickZ View PostI can see no voltage from the pyramid frame
My circuit register double output voltage with non grounded water vs ground. 150V with non grounded water, 50V with ground.Originally posted by NickZ View PostI will do that also sometime, when I get a 5 meter long wire and copper ground rod.
I think water which is not grounded is much better than ground.
Agree. Maybe a high voltage capacitor.Originally posted by NickZ View PostI also think that you would need a capacitor to convert to any usable electric power.
