Originally posted by NickZ
Pyramid
I made 2 cones, cw from their bases. That was quite fun to wind. Trying to figure out how to energize both. I tried feeding them from sin generator ( hot of gen to the top, apexes wires connected together and bottom to the ground of gen.) and connected one transistor oscillator ( John Bedini circuit) to one of my Rodin Coils placed in between (this is the suspected area of Aether concentration). I was able to get 3V oscillator LED very bright by connecting only one wire from the oscillator to the Rodin coil. Second end of toroid isn't connected to anything. Doesn't matter if I connect positive or negative of oscillator. Other short wire acts as an antenna only. I had to go quite high, over 600kHz to find this spot. Also, there is a mA meter in series with oscillator which isn't detecting any current.
This isn't really related to the pyramid but I found amusing.
I'll have to wait for copper sheets to cover it. There isn't enough energy from the frame shape only.
http://i29.photobucket.com/albums/c2...l/IMG_0397.jpg
http://i29.photobucket.com/albums/c2...l/IMG_0398.jpg
I tried to move away to capture entire setup but oscillator is in the right lower corner and LED is fully lit.
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
General D.Eisenhower
http://www.nvtronics.org
Thanks for the update Vtech
. Can you sense its energy? Judging from the arrangement, the meeting point is positive and outer is negative?
Will there any change of energy if rodin coil or star coil is hanged on the pyramid?
Everyone, all the mountain in Java island is already erupting, a very rare event, usually it is only one at a time, not all at once, indicating that there is big land movement happen. That prediction is not surprising for me, since it is already supported by the evidence so far. But we will see if it is correct.
No one know how wide the area of the next sudden big land movement to happen, so any clue would be good. We use the clue to make sure of survival, not to terminate our life. We must verify the information, also on any succesive one even if the first one is true.
The way I imagine will be that one apex will become a positive and other negative. When bases are connected there will be conical Aetheric field emanating from each apex. When apexes are connected there will be spherical Aether field in and around the gap between them. This is the one I'm after.Originally posted by sucahyo View PostThanks for the update Vtech
Will there any change of energy if rodin coil or star coil is hanged on the pyramid? I can't get them to communicate this way
Energy field is very weak in terms of measurable DC/AC etc. It is present and it can be felt. I need to cover frame with copper. In this stage I'll not see anything significant. I had to deal with basement flood for couple of days and couldn't get anything done except winding coils.
I hope you guys are ok. I live on a small island but off the coast of Atlantic, not Pacific Ocean. We have 1 - 1.5m surge once in a while but that's nothing to compare to 7-10m wave. I have uneasy feeling about that trench.
Thank you.
I wonder if filling the cone inside with a bunch of small coil or crystal frgament can make a difference.
I now suspect that if there is hole in the cone apex, the apex will have more potential and the base has less. So I see your configuration as the cone suck energy to power the rodin coil.
I hope your flood will pass soon.
My flood is just a minor inconvenience. Pump is taking care of the problem. It was coming in a rate of 1gal/min. Poorly made basement. Good thing we're only renting this house.Originally posted by sucahyo View PostThank you.
I wonder if filling the cone inside with a bunch of small coil or crystal fragment can make a difference.
The way I suspect is that pyramid walls as triangles should interact with Aether causing to respond. Therefore, what may happen is vortical movement within each wall and concentrating at its peak. This energy should get "sucked" by the upper cone. There should be also another stream entering and traveling up the lower cone. Both should look like vortex. Their culmination point would be a gap between both apexes. What I hope to detect is a spherical energy field in this area. Now, if I can figure out how to interact with this sphere, possibly trough an oscillation. Possibly by energizing (ringing) cones with small vibration but through one of the power points; either apex, King Chamber or Lower (underground) Chamber. It has to be done with respect to the harmonics and resonance
I don't have any suitable material (copper) to cover the walls atm
Thank you
I see.Originally posted by blackchisel97 View PostMy flood is just a minor inconvenience. Pump is taking care of the problem. It was coming in a rate of 1gal/min. Poorly made basement. Good thing we're only renting this house.
With that I think you shouldn't left the bottom square too and apply copper wall aswell. The square should interact with the triangle.Originally posted by blackchisel97 View PostThe way I suspect is that pyramid walls as triangles should interact with Aether causing to respond.
I wonder if it has to be solid wall, what if you use wire wrap? Tedious job surely....
After winding transformers, Henderson's, Rodin's, Starship's and cones wrapping each side doesn't scare meOriginally posted by sucahyo View PostI see.
With that I think you shouldn't left the bottom square too and apply copper wall as well. The square should interact with the triangle.
However, I think it should be solid. Either copper sheet/foil or double sided pcb board. I found some 12"x9" copper sheets, 0.01"thick and reasonable priced but it will take some time until they arrive. I was looking around for some roofing copper but it is quite expensive and they don't stock that either. I think that pyramid has to be enclosed = all surfaces covered.
Energy field can be felt as far as 12" outside from each wall. Around the center (apexes) is warm. Over the pyramid apex feels like a narrow cooler breeze/beam. Near each corner (inside) on the distance of 1/3 length from the base quite intense, almost piercing.
I see that you are not scared lol.
I suggest wire wrap because Egyptian do not build pyramid by carving a granite mountain which should be possible for them if they want, but they use squared rock instead.
I also see an energy device that use grid instead of wall. So maybe faraday cage like may work.
About layer, maybe double layer PCB is stronger. might as well see how much potential build up between the inner layer and the outer layer of copper, Ark of the covenant style ......
Guys:
I finished some beach sand batteries. Three beer cans in series, copper 1/4 inch tube inside, gave me 0 volts, nor can I even light an led. It's been over 24 hours since making them, is that too soon? They are dry. I also tried to charge them at about 12 volts from a Jtc., although they do conduct the voltage through them all, they don't seam to hold any charge or output anything.
I also made a one gallon size cement battery, using washed beach sand with a copper spiral coil inside, and another thick copper wire also, which also gave me 0 volts output. Oh, well...
Sucahyo: What is alum?
I only used washed beach sand, and cement. I liked the simplicity and availability of it.
I just wrapped the outside of the plastic gallon jug of the beach sand battery with Aluminum Foil, to see how it would work as a Capacitor. And it seams to work, I get bigger sparks too. Interesting the way that the polarity gets separated by the Leyden jar Capacitor Effect
I think that I made a good bunch of resistors at least, and a big capacitor, Ha. I was thinking of soaking them in sea water and letting them dry out.
I was just playing with one of the cement beer can batteries that was connected to the secondary of a joule thief. I was trying to get a 20 led bulb to light, and, I don't know what I did, but I got the strongest shock that I've felt yet...(from a Jt). The Jt was connected to the cement- sand battery. So, maybe there is something to the beach sand-cement battery idea.
Alum is Amonium aluminium sulfat dodekahidrat, Ammonium Alum, NH4Al(SO4)2.12H2O, usually used to make pickle .
Link by bedini:
McCormick Alum 1 jar Ammonium Aluminum Sulfate on eBay.ca (item 180590058671 end time 20-Mar-11 05:58:58 EDT)
What I get is in shape of crystal shown on page 8.
Interesting that you can shock yourself with wrapped one.
Thanks for the information on the Alum.
I think that in this case I'll try the salt water soaking instead for now. I was hoping beach sand would work as it did for "Lidmotor".
The big one gallon capacitor is still fun to play with. I'll connect it to the pyramid, also. I can also use it to study the polarity issue.
I got shocked from the smaller beer can size battery when I connected it to the joule thief.
I was once informed of an earthquake before it happened by a psychic, and it did turned out to be true. She had also told me about the full and new moon being times of the most intense seismic activity. She also mentioned that New Moon was the worse time for the Japan- China side of the world, as far as earthquakes go.
After 30 years I still remember that chat.
Lead acid type batteries are always going bad, I think that having an electrolyte is a poor system. I have a bunch of 12 volt Pc Back-up power supply batteries as well as many others batteries that are all bad. It is best not to have anything that will sulfate or corrode. The crystal batteries sounds interesting.
From other hand, those are the ones you can restore back to full capacity. I've done with several ranging in size from a motorcycle to a large, industrial. Also there are some changes inside done through cycling using radiant charger which case them to be charged in a fraction of time needed before, using conventional charger. They climb over 16V and settle near 13V. All of them were discarded by previous owners as a junk.Originally posted by NickZ View PostLead acid type batteries are always going bad, I think that having an electrolyte is a poor system. I have a bunch of 12 volt Pc Back-up power supply batteries as well as many others batteries that are all bad. It is best not to have anything that will sulfate or corrode. The crystal batteries sounds interesting.
However, idea of constructing a battery cell which can be used in series just like any other and climbing back on its own is pretty amazing. Even if it will provide just emergency light through an oscillator. 1W LED in total darkness is pretty bright.
