Originally posted by sucahyo
My radiant sleeping aid have the opposite effect if I ground it. Some people here mention headache from their device if they ground them.
I don't mention this before because I thought your grounding source is reliable. You should try to connect it with a bucket of water, ungrounded.
I have an earth ground but will try this too.
I believe DOR can be produced by your electronics, your well, underground water river, lay line, lief electric wire, bad spot, etc. Your house can become neighboorhood orgone absorber too if your wall have metallic paint or metal part.
I agree, there are many factors which cannot be ignored. I do have some suspicion about this house (good thing is rental not mine) and hopefully we'll move shortly.
Electricity or magnetism can not explain why I can see this effect on ice with just stone:
That is non electric, non magnetic quartz stone. And I do measure it with compass and voltmeter to make sure of it. Fog is a sign of DOR energy, clear part is a sign of POR energy. What you see is alternating layer of POR and DOR produced by a live crystal.
My version is here, and I think more complete than Reich version:
http://www.energeticforum.com/health...ead.php?t=5524 Thanks, will look into it.
Do the bird or other animal like being in your garden with orgonite? Do your sky blue or whiter? Didn't notice any change in sky but My tomatoes seem to enjoy and my dogs wander around quite often, not counting bumblebees trying to build a nest despite our attempts to discourage them.
Collect all the orgonite you have inside the pyramid and then feel the energy. If the orgonite work like it should, then the energy inside the pyramid must feel good no matter how bad the surrounding is. I passed this to my "partner". I'll get the results soon.
I strongly believe that a good orgonite produce the same aura as battery negative pole. While bad orgonite will produce the same aura as battery positive pole. I use negative radiant for my radiant sleeping aid.
I strongly believe that electrosmog is actually deadly orgone. I second that.
When you build an orgone accumulator, you will collect anything around no matter what it is. I believe you pyramid is strongly influenced with surrounding which happen to be filled with deadly orgone. The pyramid may collect different energy if you put it on the garden. Unfortunately, weather lately isn't that great and pyramid would need to be covered with something (plastic) to make a waterproof.
Some achieve conversion from deadly orgone to life orgone, but I don't think the science is mature yet. I believe it can be done.
For pyramid shape, I would try to mimic the real one with:
size = original size x pi^(n)
where n must not be fractional, an ordinal number that can be positive or negative.
Vtech
. What a coincidence
and much appreciated
