@ ilandtan
just to add something here, in practice there's a lots of parameters, like a simple battery and light bulb circuit
a simple switch will cause the bulb to light up, the same switch will cause it to be in off state, here you still have the power but the switch in off state, the same thing may happen to us, in some test i just changed a thin wire with another thick wire and the power increased dramatically in the capacitors banks, you know about skin effect, i too, but sometimes we do the bad thing by making the switch in off position and we say this don't work !!!!
i am telling this to say there's a lots of critical parameter that we must notice to achieve a power gain! we have to make sure the switch is in ON POSITION !
with a ferrite as a core you will achieve around 1000 more feedback inside your primary ... in other hands greater current will be induced in the secondary, the only problem is the reduced frequency, for sure there's an optimal values we have to work with but it's great if you test this and tell us the results.. so we could compare our works and see the weak point and the strong points also !
