Yes!
I hope that helps people understand my cryptic writings. I don't mean to be so cryptic but my understanding of this stuff is actually from years and years of reprogramming myself to the natural ways and it is buried deep in all the greats of our time of this natural way of dealing with energy.
Capacitors or leyden jars as I like to call them actually do the job of separation or isolation all while still including the ability to either pass or block any part of a signal. They also have the ability to increase the base potential of a signal and allow for a more powerful swing in that potential. This is a key aspect of what we are looking for. But there are from what I am understanding a great many ways to utilize this swing. Take this patent for example:
Electrostatic energy conversion system - Google Patent Search
This is a variable capacitance static converter. That allows the conversion of static energies to be given motion and cycled through the load as an ac signal. It also uses a vacuum to control the static corona that would otherwise be there if air was dense enough. This unit should be looked at more. It needs a source of static potential though which should be very easy to provide Via Wimherst machine or the likes. So we need a source then a leyden storage system and then a control system to control the amount of the built up charge on the leyden jars to inject into the above system.
Simple right... lol
Well I found a rather nice mini static generator machine as well.. Here it is:
MINIATURE PRINTED CIRCUIT ... - Google Patent Search
Also we need a way to regulate the output of the mini static generator machine as well and this of course uses.... You guessed it vacuum TUBES!
Here it is:
FELICI - Google Patent Search
We also need a way to take the high voltages present and convert them to low voltage and higher current. This is a simple matter of stepping down the voltage through a transformer where the load is supposed to be on the first patent but that transformer needs to be a Tesla no core transformer built to the correct Tesla method. Both resonance and split primary should be used much like Don Smith used.
I have also been playing with the idea of a special antenna that has an aluminum core with a dielectric wrap with a steel or copper sheath to pick off the charges before it gets to the core. Since aluminum is not exactly reactive to magnetic fields in the normal manner this might prove useful as a broadcast element for the potential we will provide and the coper would intercept the charges before they get to the core of the input antenna's. I have not tested this out yet but I am really liking the idea so far. The larger antenna would be any normal antenna, single core and the smaller antennas would be custom made.
Lets see if we can figure this out then....
Simple right... lol
Here it is:
