The funny thing about us is that we think we have a great handle on what makes a magnetic field operate. Nothing could be further from the truth but that fatally ignorant statement.
Lets look at this page which is fairly current of what we do know.
What is a magnetic field?
This talks about what we think is going on. Well even with our brightest minds we can not even look into the space between two Lines of force and understand there is a substance there allowing for the field to manifest in our reality. Energy is very real and the substance that allows for the field to even exist is real as well.
Put simply "Space" is a density of something. This something allows for all movement of anything we can imagine, Light is included as well. Light is but wakes in this space. Wakes from the movement of charges in the medium of space that gets radiated and referenced from any possible angle from that wake point. Seeing a light source is but a small percentage of the movement of light from your perspective when compared to all perspectives. It is a duel reaction that light travels both radiating from the source and the wake of the source all radiating in a vast network of a very dense transmitting medium. Light is passed through this network via conduction of a particle. This has to deal with the structure and that structures opacity. Light is allowed to travel and radiate because of the structural material of this medium. It passes light passively and largely lossless. Light travels at the speed that it does because there is very little impeding it on the low end. When the frequency of the wakes become too high it tends to jam up or slow itself down and this is the limit of the speed of light. This, by no means, means that there is nothing faster then the speed of light. The limit is for light only through the medium and does not govern anything outside of light propagation.
As far as I know the best analogy of how light gets transmitted would be the LCD monitor. There are a few differences that I know of. One being the difference of dimensions. An LCD monitor is a 2 dimensional device and the network of space is 3-4 dimensions. The 4th dimension is actually one of energy transfer of the energy network of space. With the physical location in real space being the 3d part. The 4th dimension resides directly underneath or below the physical dimensions. This makes real matter have a 4th quality and that is the energetic state of the matter. This is accomplished by having a network of a medium of space inside the matter making it have effects like fields and potentials. This network is maintained through self generation of the medium being dragged through the vacuum of space. Seeing that the scale of the medium is much finer then the scale of matter it can be seen that any movement at the smallest scales would generate a static charge as that network is dragged through itself. This would be based on the mass of the matter and how much of the network is in that matter as well.
Now one might be wondering how exactly did this all get started. Well the initial input of energy was brought about by the great unzipping of our space. As a general rule it is dark out in space. If all matter was stripped out of our space there would be no light source just the darkness. We are in a confined space one could conclude and I bet if we could pull our scale of view back we would find that we live in a bubble in a very large Black holes material. I think this area we live in is just so massive that we would never have thought that we are in something. Since there is matter in our space there is light and that matter is apart of that black holes material. It could be that as the size of this Black hole got so huge it defied the known laws of physics and crushed a layer in the black hole. This caused a rebounding effect when a separation in that layer caused by the crushing of a layer beyond its capability to maintain the gross laws of physics we think we know today. Because a layer was crushed, it could not stay together anymore and flung apart, eventually causing a bubble to form in the material of this super massive black hole. Walla you have all the energy of our universe and the matter that would be so important for the production of light. Light can be considered as a result of energy as it moves or a wake of that energy as it hits matter.
So what causes the magnetic field anyways? Well it is this 4th dimension we need to look at. It is the pathways that all charges must follow. This pathway is actually very geometric in form and where that form comes from is exactly what this dimension is made of. Otherwise why would Phi even exist in nature? Fundamentally it comes from the geometric shape in 3d of matter that helps this fundamental particle reproduce it's geometric effect even in different scales of view. When energy flows on the smallest of scales it must follow planar rules of geometry, which has a lot to do with static laws as well. One would think that just looking at a plasma globe would give us some idea as to how this network moves and forms. A very dynamic flow happens when gross matter is not involved. With matter being the form of a network being held steady by matter. Matter brings a locked in organization to the network and density has a lot to do with it also of that matter.
Discuss!
Discuss!
