Agreed!
The surface area will be very very important. Also I believe white will be best because there is all the light spectrums in there. I checked on ebay and they have a ton of 100 bags to sell of the super high bright leds like I have. eventually we could move to the higher wattage leds like 1 watt or higher to haldle the burn off of the voltage. We might as well get some good effect of generating light while we are creating the vacuum of potential at the led. Later when we are more capable of using a high resistance load to create that outlet we can switch to motors and such...
With this kind of system we could get away with cheap 12 volt panels and any charging we get from that would maintain the charge level of the battery since we are not using current from that battery. Kinda like a solar powered calculator works but we have a battery to contain the power. Right now capacitors leak to much to use them as batteries but there are some great battery technology out there that can provide greater capacities and less leakage then capacitors. Maybe is the Ultra caps come down more it would be advantageous to use them since most are now into the millions of times for cycles. Since we won't be going through any cycles to drain the battery they should last just about forever besides normal decay of the materials.
