Originally posted by electricity
Captret - Perpetual Light with Dead Batteries
@LidmotorOriginally posted by Lidmotor View Post@ Ibpointless, Dr. Stiffler, & All
I worked on this today and got good results. Dr. Stiffler-- I studied your work on this at the link that you gave and did a replication using my SEC 15-3. I got hung up on the Joules calculations otherwise I would be posting those results. All I can say is that my results looked good but not like what you had. My setup just isn't adequate to do precision work with accurate measurements. What I did see was very impressive though. A big cap charged up super fast when it was hooked up to the SEC and the earth ground through an AV plug.
The testing with the Captret was very interesting and after I got it to working the original way, of course I had to mess with it a bit. This is the video of what happened.
YouTube - Captret replication.ASF
Cheers,
Lidmotor
Both Conrad and myself have set this afternoon aside to look into this in a straight forward way. Luckily every thing is in place for such a study because of the ESEG work from some months back. Anyway once the data is in I will post it here.
Super F cells
meter read 12.5v start. I've had some phenomena recently. Must be my new cotton insulated tesla coil.Originally posted by Zooty View PostReally? Would you like to explain how you started at 12.5v with a 9v battery?
seriously, my flashlight has 5 leds ran with 400v 1000 uf (2 caps in series)Last edited by electricity; 11-10-2010, 03:24 PM.
What circuit should we test?
@ALL
Well the first try is a total bust using the very simple cap, battery and LED.
I have made a video of it and will post it, but would rather be posting working circuits, so someone please state and show the circuit we should test.
Once the video is loaded I will edit and place link here.
No acid inside, just solid ceramic. Not that its relevant.Originally posted by electricity View PostI got a bunch of these HV caps from Russia, originally for replication of a Don Smith devise, BS schematic dont work,
May be I can use em for this circuit.
Got some 16kv 470 nf and 3kv 2200nf, metal caps
Any suggestions?. Dont want acid spewing
Hopefully you could test them all, there has been many branches added to the design. I suggest starting simple, I've got videos of everything on YouTube and the diagrams on the energetic forum and overunity.com.
This was when i first discovered it and didn't know what to think about it.
YouTube - ibpointless2's Channel
This is my favorite video, I get two flashes for the price of one charge.
YouTube - Captret PROOF OF OVERUNITY
Here is the basic LED captret circuit that really made me want to post to this forum. YouTube - Captret LED Driver circuit
what i know:
The higher the Farad the longer it takes for the LED to turn on, but the longer the LED light will last!
The LED will start off bright but get dim over time, but settle on a brightness.
the amps go down over time, and that maybe why the voltage goes up over time.
When the LED goes dim you can disconnect it and just tap the LEAD and it will flash at real bright but go back to dim. It could be recharging in pulses?
If you let it sit for a day the captret will bring itself back to normal brightness when you reconnect it, but the higher the farad the more you got to wait.
The captret produces AC voltage across the top and the + ; also across the LED's + and -.
It loves voltage, the higher the better. 7 volts and up, 20 volts is preferred.
Dead batteries work great, you would normally have thrown them away but now you can use them. Put the dead battery in series to get higher voltage.
It doesn't have to be 9 volts, i just use them for their low amp hour rating. AA, AAA, or button cells will work, just put them in series.
Happy exploring!
Is ceramic conductive? I have some laying around and might try. You might want to try the SGATE idea of a coil around it?Originally posted by Armagdn03 View PostNo acid inside, just solid ceramic. Not that its relevant.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
Thanks for taking the time to help
Thank you for taking the time to look into this and test it in a lab. You are my window into the world of real scientific research. Most of us who work on a kitchen table or a simple bench in the garage are very limited in what we can conclude from our experiments.Originally posted by DrStiffler View Post@Lidmotor
I have this awful feeling that you are going to tell us that what is happening is -------normal.
Lidmotor
Analog rules
Ok, digital multi meter lied, guess it's fried.Originally posted by Jiffycoil View Post@electricity
Thank you. I've just started reading through the thread and I must say this is very interesting. Way to go ibpointless2!
Analog says 9.78v, Amp is neglegible.
The flashlight led has 9 LED and has been running for 1 + 1 hour.
Will do reading at end of the day. caps is 400v 1000 uf
Battery shower
I meant the 12v lead acid.
High potential High frequency current, what do you reckon?.
16kv 480 nf in pararell or 3kv 2200nf in series. :thumbsupLast edited by electricity; 11-10-2010, 04:53 PM.
