I attempted a faraday disk replication with some things I had last night. 1. 3.5inch diameter copper disk/.25 inch thick. 2. two 3 inch diameter ring magnets with 1 inch hole. (very strong) 3. hollow aluminum shaft. hand drill.
drill was coupled with shaft using plastic collar that is Non-conductive. copper disk forced onto aluminum shaft. magnets spaced .25 inch from disk on each side by acrylic wall.
I could not get any Amperes out. NAdda. Either spin direction, varying rpms from 1-1000. tried a resistor as load, with meter in line with load. nothing.
So switched to N-machine type configuration with magnets first directly contacting copper on each side. about 2mA. with magnets insulated from copper with thin film of rubber, about 2mA. varying rpms 1-1000 again.
I went to original configuration again. Used 2 smaller magnets of 1.5X.5 inch and placed them on each side of disk on just one edge. Original Faraday experiment style. NOTHING!!!????
Can someone please explain what might be my malfunction? Am I not achieving a high enough rpm with such a small copper disk. ANy insight will be helpful. I am completely at a loss on this one.
I'm stumped.
