Lets get this straight..
First off! Dr. Stiffler was using a fully charged battery.. We told him not to. Have you ever shorted out a 12 battery that is only putting out 7-10 volts standing? Nothing happens.. I know lol...
Please stop spreading bs like this. I have brand new caps running the original circuit and have seen no such effect on the caps. I even have a bunch of old caps all rated at 200v with zero effects after running for 5 days now. Obviously Mr. Stiffler did a fopah and used a battery with a good amount of charge on it. This setup "Captret" is only designed for use with dead batteries. It was this way so we could see what is really going on with it.
If the good Doctor did something for which it was obviously stated you should not then thats his fault. That would be like saying hey I used a capacitor that was rated for 10 volts on a system that was running 24 volts. We have always said to use the captret on a dead battery that was not charged but had a standing battery voltage of less then 3/4 of the original voltage. End of story.
The reason why caps will do that is not because of a chemical reaction although that might be a little why is does but the main reason is because of the forces that get setup in the caps. they tend to get squeezed and end up popping open because the ends are designed to do that at a very standard pressure of 7 atmospheres. In a normal mode of operation this would be very loud and a little messy but other then that if he had followed the directions he should have used a dead battery and not one of his test batteries with a good charge on it. Isn't that what experiments like this are for? If you understand what is going on in the cap the way we are using them you can see why they would squeeze out. They were not designed for this but at very low voltages in the 5-10 volt range they work ok. Since both plates tend to charge positive in relation to the negative of the can this squeezes the plates as they try to push away from each other. So the plates having no where to go move axially, once they are out of alignment that movement can have considerable pressure in a direction that it was not designed to have such pressure except for a safety release.
No offence but you're just another guy like me and everyone else.
