Mark,Almost all the old starters were identical in the motor portion of the units, the only thing that changed was the end housings which determined what engine they would fit.
GoReggie, beautiful work ! I'm assuming that was a test and you plan to replace the rear housing as well - that bushing may not last long continuously running. Although if placed in line ( direct drive ) it may not be a problem since there are no side loads. Maybe a seal and grease fitting would suffice. It wouldn't take much to make a bearing hub that could be welded into the rear plate though. I'm following a similar path...
________
Easyvapedigital
________
Easyvapedigital
