Originally posted by Armagdn03
I am not attempting to use BEMF at at all and I just consider it as a loss. It is the inductive kickback that I am sending to the capacitor. The inductive kickback flows in the same direction as the applied current therefore it adds to the motive force but instead of just allowing it to be passed across a diode back to the coil, I am passing it across a capacitor in the source therefore reducing the applied power to the circuit while maintaining the power in the coils. This is your DC tank circuit.
Because of the poor actual efficiency of modern motors this alone does not take us into overunity and if we increase frequency up to resonance the current drops reducing the motor output. Remember it is the current that gives us the magnetic force.
My problem was how to convert the voltage gain in resonance into current flow and I think your coil does that. so now we are pulsing your coil in a DC resonant circuit to see if we can still get all the effects shown in your video while reducing the input further. On this test we can run the motor off the third winding with either AC or DC and compare the results. We can also place a diode across the motor such as in pulse width modulation and achieve the gain given by that or possibly try and feed that to the source line so there are lots of things to test.
We can experiment with different values for the capacitor to see the effects and losses with different values from large to small.
You are right, off the shelf motors are not ideal, too high an ohmic resistance or too few turns.
I have Electric motor secrets part 1 and 2, are these the videos you refer to?
The way the motor runs is opposite to normal, any increase in load will stall the motor as the motor will not like to rise to the load. This is because I don't want the current to ramp up as in normal PWM or the gains are lost.
If we have a single phase AC motor on the grid and accelerate it, it begins to generate. If we accelerate this generator with our motor we have the type of load we need, one that requires less torque as speed drops allowing our motor to run at the best speed and output set by the conditions, at some point a balance will be reached and we have our fixed load.
My research has been into the motor functions of the Lockridge device and even though I cannot find that type of generator here, to convert to a motor, I don't think it is a problem as such. It is apparent to me that we can operate a normal motor in this fashion.
The basic principals are this.
In resonance in a coil you get a voltage gain with no increase in current. I was trying to use this voltage gain to force current to flow in the motor but the pulse frequency and inductance limited the current even though the power entering the motor was sufficient. The result being a very inefficient motor action for the power supplied. Your coil gets around this.
In inductive kickback you get a current gain that can be recycled, it is new current as the old current has already passed through the motor and it is current that truly gives power to a motor. I can reduce the input power by collecting and reusing the current in inductive kickback while still adding to motive force.
Not sure I have explained well, please ask me what you don't understand and give me any reasons you think this might not be the case.
Does anyone have any tips on removing the rotor windings?
