Lockridge Device - Peter Lindemann
  • stuck on theory
    The lockridge appears to have this configuration. Remember you do not have to drive that second coil, by using it as an output current flows and impedance changes. In a motor generator configuration like I have done, the lowering of impedance causes the device to draw more current. By drawing current from the generator coil when supplying the device with AC we get acceleration. Acceleration under load. This was using a simplified armature but even worked a little with a standard armature.
    I dont know if your idea about how it works is the same as mine, but you seem to be looking at similar principals
    As for resonance and using it as an LC circuit, it seams to be leading me away from that, but we just dont know.
    I use the reverse engineering approach and let the device teach me, and it has taught me a lot.
    Are you telling about a kind of transformer?
    So in a transformer you need ironcore or metglass as a magnetic
    media. so the air coiled trifilar cannot deliver enough energy to the 300W light bank.
    300W -> my Trifilar will melt away !
    240 turns of magnet wire 21 is not very much.
    even if you use the tesla patent "Coil for Electromagnets," patent #512,340
    (bifi selfcircuited)
    you cannot transfer 300W
    So the only part is to use the CASE of LR as an Ironcore.
    but rotating fields destroy / shifts the phase of magnet flux away ?
    this will really weird but maybe a key to the function.
    So you need to transform the 12V AC to 220V AC for the bulbs ?
    we need 10 times more windings on L3 than L1 to shift the voltage
    from the generator to the bulbs, with 12 V trifilar you will see not even
    a glow in the bulb.
    Robert49 did report a "clicking sound" here. A possible clue to a missing component. What makes clicking sounds? A spark gap maybe? I also heard about the resonance sound from another source who I just can't remember. JB or Mark McKay? Not sure.
    A relay to switch the light bank as an ballast to the generator
    not to burn the gen coils ?
    If I am correct, and it works in attraction, the flux will be held within the case and very little will leak out. This would mean that the reason the the trifilar coil are wrapped around the case for only one reason, convenience.
    I still believe it is possible for the trifilar coil to be used in a way that Babcock showed us, as a choke to store energy. This coil would then impedance match by supplying whatever voltage is required to maintain current in the motor.
    Yes you could. But the magnetfield arround the trifilar will interferere with
    the rotating field in the GenMo (Generator/motor combo).
    The Idea of resonance in the motor is not without merit, but suffers from problems. The bigest being that the inductance in a motor constantly changes as it rotates, and as load varies. How to make a circuit respond to this is problematic and I was unable to do it.
    An OpAmp is fast enough to do an PID , measure the resistance and
    instaneous output a difference signal to the MOSFET driver -> adjust L properly.
    but in resonance the losses in the coils are almost zero. Xl=Xc=0 (in theory)
    so drop in Amp from the power supply at constant rpm (when you feed constant Voltage to the motor)
    or rising RPMs with constant current supply.
    another approach: (not tested, but inspired from JB SG Cap Discharger)
    charge a capacitor (diode) inside the Resonance loop.when you reach the 30V then you can "click" an relais
    to push the joules from the cap to the Motor. (KICKMode)
    say "in the right moment"
    Resonance is short lost, but the motor turns further (momentum)
    the resonance should reestablish and the cycle repeats.
    Ismael Aviso:
    He find a way to short circuit the motorcoils at the right moment to
    (on the peak of the sinus wave) and charge insteanous a cap without
    "lenzing" the generator out !
    so you could use 2 Coils of the generator and close them
    with lowest (!) resistance at the peak (when rotorfield approach the statorwinding)
    so you recycle power and say bye to Mr. Lenz
    No Lenz no Drag on the generator. perfect
    OK Mr Brown.
    I will shortly forget the resonance mode.
    So if there is no LCR system at the moment.
    how will you connect the parts to get a working model ?
    What I have overseen ?
    • Voltage?
      Remember folks, no one has a working model of this device except possibly the government in some warehouse somewhere. We have no way of knowing voltage or frequency of the output to the bulbs. We can assume they were standard 220v/50Hz bulbs used in Germany and 120v/60Hz used in US. Bulbs are not picky and actually work better with high voltage and high frequency. They will use less current and illuminate fully, even cold if high enough.
      Hans, if this is truly a reactive or radiant device, you will be working with a slightly different form of energy. Without conversion, our scope and meters are useless. Caps help with this problem. JB has shown us how to collect this in a cap. My experience with this form of energy is you must allow for a "break in" of the conversion components before measuring efficiencies. I wish I could remember my second source of information regarding the resonance component because I also remember the statement by Lockridge himself not to use anything other than light bulbs on the generator or risk burning the whole thing up. Also a clue to high voltage and/or frequency.
      Randy
      _
      • Originally posted by tachyoncatcher View Post
        Remember folks, no one has a working model of this device except possibly the government in some warehouse somewhere. ..
        Randy
        • Originally posted by HansKammler View Post
          Yes a transformer, but not the trifilar coil. The powered field coils and the armature act as the primary, the other field coils act as the secondary. So if we pulse the primary using the commutator as the switching mechanism, with the powered field coil and the armature in attraction, we will get a strong transformer action in the generator coil. As this generator coil is also producing DC in it at the same time, we have the problem of separating the AC and DC signals. If we use diodes the AC becomes self cancelling and we cant extract it.
          Ill say it again to try and make it clear to understand. So we use one powered field coil and the armature as the input as a low BEMF motor, as I have described before. the 90 degree configuration with one of the generator shoes forces the motor to turn and generate DC in the coil mounted on the un-powered shoe. As this is pulsed we get a pulsed AC wave also occurring in that generator coil. This is only half of the field coils in the case.
          The second powered field coil is opposite the first and set in attraction. Normally this would lock the motor and it would not turn, but because the case is split, there is no flux path and this does not happen. The flux from this second powered field coil follows a second path around to the second output coil. Transformer action again creates an AC wave in this second output coil. The two act purely as a transformer as it is arranged in the case so that the powered armature does not sweep the shoe of the second output coil.
          We have a motor, a generator, and a transformer all in one case. Only one friction loss, only one iron loss for all three devices so our efficiency is much higher than three separate devices.
          We use the output of this transformer section like a magamp to turn the AC produced in the first generator coil into DC while powering a load at the same time.
          We have one pulsed input x. We have inductive kickback from this which can be collected which will be in the region of 17 to 35% efficient, so now our input to the transformer is 1.17 to 1.35x
          If the inductive kickback is fed to a capacitor across the load, it will reduce the input so our input is now 0.65x. Are you starting to see the gains? For an input of 0.65 we get an input to the transformer of at least 1.17. Allowing for a relatively poor transformer efficiency of say 60% we still have 0.7x as a transformer output.
          The generator is more efficient than out donor motor as we have reduced the BEMF by 2/3rds. Normally we would expect this motor to generate with around 50% efficiency but we know it will be better than that. however if we only apply a generation factor of 0.5x our total output is 1.2x.
          If our device is running at 1000w, for an input of 650w, we have an output of 1200w and with no use of a trifilar coil.
          a glow in the bulb.
          We can wind out output coils to whatever ratio we want
          Normally a motor is set up in repulsion with flux leaking out of it all over the place. By setting it up in attraction we keep the flux in the core and improve transformer efficiency.
          Read my thread here and you will see how to set up the motor in attraction. http://www.energeticforum.com/renewa...ing-motor.htmlI came up with this while I was trying to resolve the AC problem in the generator coil but eventually discarded it because the trifilar coil is 90 degrees out and so could not have this effect.
          I dont think we had this technology in the 1940s
          Ismael Aviso:
          OK Mr Brown.
          • Comment
            • http://www.energeticforum.com/renewa...ing-motor.html I talk about the construction from the 7th post
              q1.2
              the magamp is wired as a recifier than an amp ?
              Yes, that is one way to do it.
              q2:is the overlapped ac peak smaller or greater than the dc peak on the generator ?
              If the generated DC is 12v the AC will vary this DC between 24 and 0 v. Effectively the AC gain is lost when the voltage drops to zero.
              There is another way around this problem using reactance (I think thats the correct term) ie the voltage may drop to zero but current still flows. Its something I am trying to figure out.
              q3: how did you reduce the bemf on the generator to 2/3rd ?
              The generator is absolutely standard and so works in a conventional way.
              It is how the device is made to motor that is different. Little or no BEMF is generated in the field coils because no armature coil passes them while it is energized.
              • There is another way around this problem using reactance (I think thats the correct term) ie the voltage may drop to zero but current still flows. Its something I am trying to figure out.
                q2:Magnetic reactance or electrical rectance do you mean ?
                my first idea would be a CAP in series with the generator winding (Motorcap) to filter out the DC component and clip it to a fixed level (biasing).
                the DC i filtered out with an bridge recifier and collecting in a second cap. So i can use both of them after.
                Is that you want to tell me ?
                q3: Its because you switch off the current in the armature coil before it passes the field coil ? Right ?
                • No problem, its so obvious to me because I know how it works, but I forget that no one else has seen anything like this I will go through it again with this drawing http://www.energeticforum.com/attach...-coilsetup-jpg
                  The ability to make the current lag or precede the voltage.
                  Congratulations, you have thought of another of the methods of spiting the AC from the DC, but I never figured out how to get the DC out, and so have never mentioned it on the forums. Its one of the many things I call "a work in progress"
                  I think we are going to make some progress
                  Correct, hopefully you can now see why.
                  I suggest you build the "Interesting Motor", I call it the Motor Assisted Generator (MAG) or Motor assisted Dynamo (MAD) Then run some tests on the pulsing so we can narrow down the options for splitting the AC and DC
                  Sorry for the long and in depth post
                  • #13 efficience 2:
                    In effect we are using our electrical draw from the generator to compensate for the increased load on the motor by passing its current through the motor windings first. Yes, the motor will slow but by not as much as expected. The lower the voltage requirement of our electrical load the more current drawn and the greater the compensation.
                    Could you be so nice and explain me this further.
                    You take the generated current trough the motor windings to compensate
                    an increasing load on the motor ? why is this load increasing on the motor ?
                    if the motor is very low in voltage this is better because it draws more
                    current from the generator. so your kind of generator will be happy to give us
                    more current but its unhappy to supply a higher voltage ?
                    so the key is to use an low impedance armature And low impedance
                    field coil ?
                      When we draw current from the generator, it causes drag, the motor slows and the BEMF in the armature reduces. This allows more current to flow. Also when a load is placed on the secondary of a transformer, the impedance drops and more current can flow. Normally all the extra current comes from the source, but as we are creating current in the generator it makes sense to use that too.
                      The voltage drop across the motor is very small, so if we make the voltage of our output higher than the motor, it will draw generator current through the motor with little voltage drop. We can still power our load but the current flow has assisted the motor. This extra current in the armature causes more generated current so it is a self compensating loop.
                      As the transformer action is lowering impedance, more current flows, which in turn causes stronger generation due to the higher magnetic fields in the armature. Again it is self compensating the the generator.
                      field coil ?
                      Not exactly, we can drop the impedance with the transformer action, We want very low ohmic resistance both in the field coils and the armature. Big wire. This is why I play around with starter motors as their ohmic resistance is often below 1/10th of an ohm. The problem here is I may be too low on the inductance, another compromise.
                      Your asking the right questions
                      • Comment
                        • Comment
                            thank you for your explanations.
                            1,
                            I realize at the "interesting motor" that you solder not every plate
                            on the armature with a coil because you will reduce the "brushfire" by
                            switching to the next segment. OK
                            so i think I can place gluefilm (isolationtape) on every 2nd plate(segment)
                            of the armature right ?
                            With that motor we are avoiding transformer actions so every segment would be fine, remember this came as a result of my research so I left options to make it what we are talking about now. I would recommend you start with only one coil on the armature, this makes it much easier for setting up the motoring function. After we have the motoring function set up and tested, we can add extra coils.
                            What I am thinking right now is 4 blank segments between each coil. this will allow a full charge and discharge of the armature before the next coil is charged, but this may change, as I'm still working on it.
                            2,
                            but then I realize to run your setup I have to rewind , resolder all segments
                            to set the wire lap in a 90 degree formation. OK
                            a lot of work for me to rebuild the commutator. OK this work have to be done.
                            The 90 degree setup on the armature is for two reasons
                            1) so that the commutator will line up with existing brush positions
                            2) It keeps the wires close to the shaft preventing them getting caught in the brushes.
                            Nothing special, just practical.
                            • thank you mbrown for your explanations.
                              This is a whole new concept and I have to check how can I do all
                              this mechanical work at home. With electronics this is more easier.
                              Interesting you do a mechanical NE555 oscillator with your 4 blank armature.
                              Do you have a photo of your armature (actual) so I can figure out
                              how you wire it (wave or straight) I never wire a motor in my life.
                              When I buy the Bosch generator I my first thought was, **** how this dirty thing works. real Hard (!) ware
                              I have fear to destruct my armature if I begin to unsolder the windings.
                              But wire to wire it should work
                              cheers,
                              H.
                                cheers,
                                H.
                                Sure, this was the one I had the best results with.
                                The hardest part is getting the old windings out as they are usually held in with epoxy. I used a hack saw to cut the windings off at each end and then a punch to knock them out.
                                This video will help you with the wind, the only difference is I connected to commutator segments at 90 degrees do that i did not have to move the brush holders that were already there. http://www.energeticforum.com/redire...lpage%23t%3D99
