Parallel Self Charging
Much higher ???Originally posted by ibpointless2 View Post25 volts is much higher than the original 24.90 volts that I started with."There is no love without prayer - there is no prayer without forgiveness because love is prayer - forgiveness is love." Virgin Marry - Immaculate Conception ...The geologists say it's not in the ground, the airforce says it's not in the air, the astronomers say it's not from space, so we are running out of options...
when it should be lower in voltage, any increase is enormously significant. God this forum is full of that type of useless comment.Originally posted by cikljamas View PostMuch higher ???Last edited by Inquorate; 12-20-2010, 05:04 AM. Reason: Subscribing. For ****s and giggles. Good stuff ib2Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
Maybe ???
This might be what was happening to me. A few years ago I was living in my
camper van while I was working on the west coast. I had an extension cord
hooked up to the battery of my truck. Each night I would come back to the
camper van and plug into the female end of the cord which was in the van hooked up to a 12 volt battery pak. I would run a small 75 watt inverter off
this and would use a 9 watt cfl, or 12 volt TV, and also my laptop. Not usually at the same time. I would sometimes be using power all night. I was not worried about running the the truck battery down to low, since I was parked on a bit of a hill, and could start it by rolling in reverse and engaging the reverse gear.I was very suprised, that even after seeming to draw lots of power on numerous occasions, never once did the truck not have enough juice to start on its own.It seemed like I was getting some kind of free energy thing happening. Usually,after going to sleep, there would not be anymore energy draw while both batteries were still hooked up, so they would be like that for a few hours resting.
FRC
It is not useless, now we know that it is enormously significant increase !!!Originally posted by Inquorate View Postwhen it should be lower in voltage, any increase is enormously significant. God this forum is full of that type of useless comment.
Thanks !"There is no love without prayer - there is no prayer without forgiveness because love is prayer - forgiveness is love." Virgin Marry - Immaculate Conception ...The geologists say it's not in the ground, the airforce says it's not in the air, the astronomers say it's not from space, so we are running out of options...
Is this how you walk :Originally posted by machel1224They are made from scratch just for you
Now, you are probably thinking that custom golf clubs are even more expensive than name brand discount golf clubs
YouTube - Ministry of Silly Walks"There is no love without prayer - there is no prayer without forgiveness because love is prayer - forgiveness is love." Virgin Marry - Immaculate Conception ...The geologists say it's not in the ground, the airforce says it's not in the air, the astronomers say it's not from space, so we are running out of options...
if you do not have enough space, park like this :
YouTube - French Car Parking Technique 02"There is no love without prayer - there is no prayer without forgiveness because love is prayer - forgiveness is love." Virgin Marry - Immaculate Conception ...The geologists say it's not in the ground, the airforce says it's not in the air, the astronomers say it's not from space, so we are running out of options...
And if anybody interviewed you ever answer them like this :
YouTube - Brendan Venter's interview after a defeat to Racing Metro"There is no love without prayer - there is no prayer without forgiveness because love is prayer - forgiveness is love." Virgin Marry - Immaculate Conception ...The geologists say it's not in the ground, the airforce says it's not in the air, the astronomers say it's not from space, so we are running out of options...
Even though they both add up to the same voltage or slightly more after the experiment, there is less energy overall after. The larger capacitor lost more joules than the smaller one gained. It's like saying a 10uf cap at 10v + 100uf at 20v is the same as 10uf@20v + 100uf@10v. It is not. Give us the capacitance and work out the joules then you will see that you have lost energy. Most people know that sorting 2 caps in parallel wastes a lot of charge, up to 50%Originally posted by ibpointless2 View Post[ATTACH]7238[/ATTACH]
Keep it connected.Originally posted by sucahyo View PostDo we need to sit it 12 hours un connected after that before measure it again?
And it works better with capacitors.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
Originally posted by Zooty View PostEven though they both add up to the same voltage or slightly more after the experiment, there is less energy overall after. The larger capacitor lost more joules than the smaller one gained. It's like saying a 10uf cap at 10v + 100uf at 20v is the same as 10uf@20v + 100uf@10v. It is not. Give us the capacitance and work out the joules then you will see that you have lost energy. Most people know that sorting 2 caps in parallel wastes a lot of charge, up to 50%
For the capacitor experiment....
I started out with two capacitors
The big one was a 4700uF 35volts ; its standing voltage at the start of the experiment was .874 volts.
The little one was a 220uF 50volts ; its standing voltage at the start of the experiment was .168 volts.
When i connected them the bigger one lost voltage and the little gain voltage, both equaled .874 volts. And then they started to gain voltage.
The next day it was up to .902
After 2 days it was up to .946
After letting it sit unconnected to anything for 12 hours the big one standing voltage equals .942volts and the little one equals .940 volts.
They both seem to be sitting at a higher standing voltage then with what they started with. .942volts is much higher than the original .874 volts that the big capacitor started with, Where did this extra power come from?
Here's a video of me playing with it a few days ago.
YouTube - Capacitors self charging off each otherAll truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
It is not real charge.
Unfortunately it is not a real charge. Just doing small tests with a single cap and battery I have found out that the gain in voltage is not real. As I measure the voltage on the single battery it lowers the value as the meter slumps back to the voltage that the battery was when I started the test.
It seems that the cap is converting some of the real current into a fluffy charge that sits on top of the real charge of the battery. As I have said before capacitors are a very weird thing. When they are used in such a way they convert some of the heavy charge in the battery to a new light floating charge. This makes the battery charge but not in the traditional sense.
Most of my tests are on batteries with a good physical state but lacking in full charge. Meaning at 12 volt battery riding at about 10.2 volts.
I highly doubt that capacitors allow a heavy current flow and this is where you are seeing a "Charge" but that charge is very very light.
