Figure a disc with radius of 1 meter having a 6,28 meters circumference spinning at 1000 rpm. At 1000 rpm means that the disc will have a 16,6 turns per second. Witch gives us a speed of 104,6 meters per second. squared becomes 10955 and than divided by 1 = an acceleration 1000 times grater than the gravity.
The centripetal acceleration will be = to more than 1000xg or 10955m/s*s
What if you use this disc to pump water?
Would not you use the force to perform work without consuming power?
The only power being consumed will be that of the bearings and the water contact but the work being developed would be far greater than the energy being consumed.
a=v*v/r
What if you put a generator on each water output of the disc?
a=v*v/r
