The Golden Component
Agree
I agree with everything said. Take an audio amplifier, you are getting more energy out in vibrations then was put in. Most everything electrical is giving us
some free energy, be it heat, sound, or whatever. We just have to try to make them more efficient for greater gains.
FRC
Negative resistor, which converts heat to electrical energy would be the golden component, unlike a resistor, which converts electrical energy into heat.
I'm trying to say that all electrical components are a golden component, they all are the same. A resistor and a transistor is the same, so is the same when comparing all other electrical components. You can make the golden component into a resistor, capacitor, diode, or anything really. The golden component is metal plates separated by some type of dielectric and this golden component also has battery characteristics with it too, so it is always giving off power.
Using the golden component idea in a circuit will always give you more power out because each resistor, transistor, diode, etc. gives off power itself thus you'll always have overuinty.
Any and every component can be made into a golden component, but we make them like the components we know to day and thats why we don't see overunity. Our current setup of components are set to never get overunity because we design them that way. To see overunity in a circuit you need to change the components you use and thats why i put up my theory of the golden component.
The key to overunity in a circuit is to make every component produce its own power like a battery, doing that will guarantee overunity.All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
