Plasma Effect - Cosmic Ray Amplification
  • #16
    Originally posted by FRC View Post
    Yes the coil ignition system in an automobile is a Tesla patent. But does anyone
    know about the the ignition system in a Model A Ford ? A friend of mine, originally from New York state, told me his brother made a Jacob's Ladder with
    a coil from a Model A Ford. He said that the coil ran continuous, unlike Tesla's
    pulsed coil, and that these Model A's ran on kerosene. It sounds like the coil
    was delivering a plasma spark. Does anyone know ? Or am I wrong ?
    FRC
    where would one get a Model A coil?.
    I would just get an ignition coil from the auto part store, even ebay will ship it to your door for less than a few green paper.
    don't worry, you do live in a North America Free Trade zone, go ask for your duties refund, damn thieves.
    • #17
      HHO rock
      Originally posted by power1 View Post
      Silicon refining is done with a simple HHO torch, broken glass or Heat Resistant Glass works better, make your own composite and alloys. It is easy!
      Could you elaborate a bit on this? I am set up with HHO, and I have been noticing some strange characteristics when I melt down a certain landscaping rock, turning it "to glass". I had one piece behave like a transistor ala John Bedini method. I'll find out the name of it, but it's sold around here by the tonne, and I think they call it silica shale.
      • #18
        EnergyMover
        no, Superhighway to Energy.
        Where does it come from?.
        • #19
          kcarring,
          easiest way is to make a clay bed, same way as you make fire brick, make a long brick, mine is 2 feet long, 4 inch cube with 1 inch deep, 1 inch wide channel in the middle stretching length wise.
          just melt your glass to fill in the channel, then slowly liquefy glass by dragging slowly from point a-b, as it molten silicon cools, impurities are attracted to molten side, before you reach the end, point b, cut off molten silicon, repeat process 3 times and you'll have pure silicon, cut off 2 inches at point b end, as impurities are there., work in clean room and avoid dust,
          discuss more at my Crystal thread, you can alloy silicon with other element and control crystal growth with magnetic field, that's how they build nano devices.
          • #20
            thanks chasson,
            you can grow your own diodes too, many different alloys can be done.
            same thing I am doing with PbS, it is the size of the crystals that makes it able to harvest energy, gamma, cosmic rays etc.
            discuss more at crystal thread.
            • #21
              Silvertogold had made a very logical point over at Aaron's water spark thread, don't know why you guys can't see it.
              • #22
                FRC
                I can't remember where I saw it, but I KNOW I saw a picture/diagram/description that indicated that the model T's coil is wound in the PHASE CONJUGATE MIRROR configuration.... I gotta keep saying it.
                • #23
                  power1,
                  when you suggested metglas, I remembered what Don Smith recommended, and that was one of them. It is in the class of materials that exhibit magnetostriction. I haven't done too much research in that area, but I believe you are describing the same thing that he showed us how to do, but with impulse currents rather than resonance as Don was suggesting.
                  • #24
                    Originally posted by SuperCaviTationIstic View Post
                    power1,
                    No, I am not saying that you need fancy magnetostriction material that you can never get in the first place, I was simply saying that I use Toroid transformer with metglas like core.
                    All you need is to produce sinewave, oscillating, a/c which is all the same thing, and you can produce this wave easily with a toroid wound coil, from a 12v battery use a Jeanna's Light toroid coil then rectify that and use arons circuit or the Imhoteps circuit as mentioned above.
                    Aaron now has a fancy name for High/ Low voltage capacitor connection which is only Quenching of the current, the modern capacitor achieve that effect, Just like Aaron and others before him. You can still do it old fashion style with spark gap and magnets for Quenching but not necessary, magnets placed under spark gap produces electric air, quenching or what ever it is called today. it is a phenomena that have many interesting effects.
                    Anyway, there is your Radiant Energy for any of you that had spend so much time with those circuits before.
                    I will no longer discuss this, it is of no use to me.
                    • #25
                      One last ting to clear up the Mystery Hypes.
                      For anyone that does not clearly understand Transistors, they are silicon with nano lattices which is bombarded by cosmic rays, they go through a lot of trouble to eradicate this problem, which is not a Problem.
                      With impulse current, you make the Silicon superconductive, which is the gate for your enegy to come in, Everyone else here can speculate on what ever they wish to say but you can prove it to yourself by replicating my experiment with a pancake Tesla Coil.
                      • #26
                        Back in the '60's I cut the top off one of those big power transistors. Exposed to sunlight it generates a small amount of power. Still have it and checked it again, still works
                        If one wanted to test it for gamma or other natural energy what would you pulse it at? My pulse generator only goes to 3 Mhz and I'm guessing it might need to be a lot higher than that?
                        • #27
                          What is Superconduction?.
                          It is conduction without time/space.
                          What is Silicon?.
                          You say its glass, sure
                          What happens when you refine it and take out the impurities?. Silicon Rectifiers, Silicon Chips, How is silicon arranged in the Wafer?.
                          Take a living matter, say a deceased person or may be a smaller animal. Let it decay for 5000 years then see what is left, not very practical as your life time is too short.
                          Use plasma or HHO and reduce all matters by removing all elements, water, carbon etc and see what is left.
                          SILICON will be left. So what is Silicon?
                          The principle is no different from lumbers milled from a tree. Build furnitures, structure, houses etc, you are the architect, you create. Only problem is your organic material will decay.
                          What is Decay?
                          Now with silicon, if you construct using nano scale or single molecules, you are able to allow pathways for the gamma, cosmic waves to do useful work, instead of penetrating unorganized matters and causing decay.
                          • #28
                            with the cap off, use it with Aarons water plug circuit or the Imhotep circuit that I had used above and see how many CFL that you can drive and measure the input and output. Big difference, isn't that OU?.
                            you need to rectify sine wave AC and step it up to High Voltage at High Frequency with Quenching effect.
                            • #29
                              Wait a minute here
                              Isn't Silicon not a conductor?.
                              Isn't glass just an Insulator?
                              Then how can it become semi-conductor when purified?.
                              Then how can it become super conductor when under high frequency/ high voltage quenched current?.
                              Then how can it have intelligence when arranged into nano pathways?.
                              • #30
                                Interesting Thread
                                Very interesting thread Power1. Thanks for sharing all this!!
