Hey. No tecnical literature talk about ac on the field windings on ac
generators and motors. has the capitalists something to hide here? the
magnetism on the rotor will not be constant using ac. it will wary same
as the sinus wave. it will induse the same normal sinus wave ac in the
stator windings as the constant magnet dc powered rotors do. The
benefits is this: the magnetic lock effekt will be wery redused,
60-70%? also the back emf counter effect will be redused, 60-70%? it
can be drawn more power from the stator windings because most of the
thermic effect from the back emf voltage/current is redused. i will do
tests on standard 2 pole gensets. when the rotor spins making 50 or 60
hz, it flips north
/south poles. the result is that the stators get
constant north pole and the other stator gets constant south pole. i
think that is ok, it will generate ac ok. The logics on this is wery
simple, just do it right electrically and mechanichally. there is
histories about self running generators and motors. a 4-pole can maybe
runs as motor and generator, half by half. the same thing will go for
motors to. they will be overunity machines. se the link, this guy
runs a modified generator. YouTube - 3000 Watt Generator Powers Itself, Grinder & Drill Press.mp4
hz, it flips north
/south poles. the result is that the stators getconstant north pole and the other stator gets constant south pole. i
