I figured out tesla and grey
  • I figured out tesla and grey
    I have done a great bit of research into Tesla and E V Grey and T Henry Moray and have learned what their principals are based on and further I know how to tap the Ethereal fields that are present in the universe but as with a lot of these type of idea's people tend to come up missing so I would like some documentation to be preserved as this relearning of things people already knew is starting to get old. I have figured out what Tesla meant when he said he could power the world without wires as he proved in his released writings. It all boils down to this once you understand the following concepts that once you build a field in an inductor it will not get and stronger under dc conditions. It went back to the arc from the HV switch before it made contact. It disrupts the Ethereal fields present in everything in the universe.It is sent out in shock wave much like a stone make wave in a pond when it hits the surface it sends electrons racing though the world. the trick is how to tap this affect in real life I will be posting some crude drawings and schematics for this to be done I mean if they could do it for over a hundred year old technology it will be a no brainier for modern state of technology. I do have a proposed Idea on my site trolldungon.zapto.org/free_energy go to the Tesla link as it all derives from his plans.
    I couldnt access the site.
      Dead link
      It doesn't work for me either.
      Carroll
        Sorry
        I know it is just an excuse but I was updating computer
          I have it on my personal computer
          It's on my computer so if I upgrade or repair it my site goes down. I usually do not let it go down as I do not use windozs or whatever that other system is I can not take a chance of some other peps from deleting my site as happened at xenophed.com where they erased the site and said it violated proper use. No I do not know what "they" meant. So I am now trying to rebuild years of work from scratch. It is a good thing that I can remember a lot. It is however a low bandwidth connection.
            No luck here either. You know that Google and many others offer free web sites? Just sign up for a Google gmail account and then you can build a web site easy and for free or even a blog site if you want. You can see the free offer from Google's main page by just pulling down the 'more' menu and then choose 'sites'. Hope that helps.
              try here
              https://sites.google.com/site/thetrolldungon/https://sites.google.com/site/thetrolldungon/
                Glad to see Google's site worked for you. Thanks for posting it. There does seem to be 3 images though that aren't showing up at the moment. They are figures a, b and c. The seem to have links associated with them also but nothing shows up either way for them. I've seen a concept like this recently and have been considering building something like it except with all the lightning that happens around here I hesitate to put any large metal things up high in the air. I'd have to make some quick take down mechanism for it or I'd likely get a whole lot more power than I want sometime
                  Can you post a pdf version of your site ?
                  Shock waves,electrified sound waves of ether. I agree.
                    site zip file
                    I will make a zip file of two idea's I have and link them in my google site trolldungon.zapto.org still do not know why my site does not show up It is only a theory but "they" may not be allowing it to be shown.
                      All in a zip file under Files
                      It is all in a zip file under files Remember I Lost a lot of my work from xenophed.com when they locked and erased my site and no I was not behind in my site payments payed two years and it was only 8 months old. The first one is proven by the file sam.pdf in the zip file I just reworked it to be self starting using a trick from electronic car flasher that I had used to power them the second idea is a spin on Grey and Tesla's work. I would like to get input on these idea's as this is already been done in the past many times and to keep relearning things because of "them" is old see Moray's bio for more on that. I would also note the plate can be placed in the attic of most home as long as they do not have metal roofs as Moray said there is 200 million volts 8ft from the ground. Go to the site download the zip file and read the pdf files in it where I base a lot of my principals from. I would also note that I have not got to redoing my low temperature turbine as it also has great potential for the world as a whole the premise here is to make it a Sunday project for Joe world to construct and have Free Energy for life as you will note from the license it is a copylefted design meaning any one who works on this is doing so for the good of all mankind not to own everyone owns it and no one owns it.
                      "If something has no need then or use (oil) they can not control you with it"
                        Site looks good now. I had not thought about putting a plate in an attic. Thanks for the suggestion. I'm also thinking about a big coil of copper tubing (1" diameter tubing) I've got as it's already shaped like a Tesla pancake coil. I think it might be good for this purpose also although I have run across info before pointing to aluminum and coating it with a dielectric.
                          Grey's Tube
                          Grey's tube is a common device that is used all the time General Electric GL-7171 it showed it in a video dismantling Greys Motor on you tube he used six of them the coil everyone thinks is his tube is but a HV inductor he latter changed to a motor of that design.
                          • #14
                            Zetex is NOT the "Gray" technology
                            This is false. Those aren't Gray tubes. Those motors are all
                            100% conventional - they were all changed afterward. Those motors run
                            on ignatrons and have NOTHING to do with what Gray originally had.
                            Why there is so much misinformation being kicked around right now about
                            the Gray technology is very interesting. Zetex trigger carts and motors
                            all have NOTHING to do with the original technology.
                            • #15
                              Wrong anwser
                              Grey had those made by GE read all of his documentation
