Oh you have the chip? I'll post the circuit, then. It's a fairly easy build.
Open Source Project for Tesla/Jackson Wireless Transmission
Check these guys out, i bought a while back frequency generators for a school from them, they seem very satisfied with them...
digital multimeter oscilloscope dso dmm usb Rigol Fluke meter (HK based)
DS1052E @USD465
2) DS1102E @USD685
3) DS1062CA @USD750
those were the prices i got at the time i bought them
Signs and symbols -Confucius.
UC3525 SG3525 NTE1721 PWM Mosfet Driver by 7imix, on Flickr
It hasn't really changed since the last time I posted it.
For the rt pin, you can put any string of potentiometers of different sizes to get the resolution you need. It adjusts the frequency.
For the 10k pot, I suggest a 10 turn pot, one of the expensive ones or a cheap trimmer. That adjusts the duty cycle.
I also showed how I hook up the coil. Vcc to coil, coil to mosfets, mosfets to ground.
Use the burliest mosfets you can find with the smallest rise time and fall time you can find.
I like it ! Should get full frequency with that circuit and the fet only do half the work each.Originally posted by 7imix View Post
I'll make one of those very shortly and put it straight to PCB. Those chips confuse me.
Yep, I like that about this circuit; even though two phases can be useful, using both phases for one coil with two mosfets shares the load in a nice way.Originally posted by Farmhand View PostI like it ! Should get full frequency with that circuit and the fet only do half the work each.
OK 7imix, I built that PWM circuit on a solderless board and it works good, i can get the full 200 Khz from each output so 400Kz and with very narrow pulses. I'll show some pics from the analogue scope.
This is at lower frequency.
This is full blast with the narrowest PW i could get and still get it focussed. It would be more stable soldered.
As you can see I can't use it like this so I'll have to solder it into a point to point board,
A couple of things I noticed as I worked it out and would suggest you try, is tying the shutdown pin to ground, (it says to in the datasheet) and I used a 0.001uf timing cap for full frequency. The timing cap should be connected to the CT pin and the Dead time resistor from the CT pin to Discharge. I think you must have made a drawing error because the timing cap would need to charge through the dead time resistor in you're drawing.
I also used a 100 ohm dead time resistor, and 2k-10kpot-1k divider for the PW control and 2k with 10K for the RT/frequency adjust.
Thanks for the drawing it helped me immensely.
I'm not sure if this chip can do it (havn't checked yet) but I think it can change the PW by way of a feedback from the load like the SG3524 and TL494 can.
I'm estimating I will need about 620 Khz maybe a bit lower when i wind my two new Resonator coil "B's" they will be aproxximately 1036 turns each 180 meters of 0.5mm wire so about 550 mm tall the same height formers as the one's I have now but full of wire. Plus there is 147 turns in the Coil"A" coupling coil.
That should give me a resonant frequency of about 600Khz I can do that with a SG3524 chip they can do 700Khz, so that would be a very good and simple drive circuit a SG3524 oscillator driving alternate Mosfets and using the Tank/Charing circuit, I might have to adjust the cap size for the primary charging circuit.
Haha here is a silly video of the new little coil I made lighting an LED with no connections to anything. I thought I would put it up on youtube for a laugh.
YouTube - ‪AlternateFarmhand1's Channel‬‏
I noticed the little one light's when the other one doesn't and vice versa.
CheersLast edited by Farmhand; 06-22-2011, 06:18 PM.
Hi 7imix, Seems i was wrong about the Shutdown pin. It should be left open by the looks of it. I see in the data sheet it say's it should not be left "floating" I guess that could mean something different to "open".
Datasheet says this.
But then I see in the example drawings that pin 10 is used to turn it off and a switch is used which more or less leave's the pin 10 open."Pin 10 should not be left floating as noise pickup could
conceivably interrupt normal operation."
It does work open or tied to ground.
Anyway I also built a basic SG3524 circuit but I am having trouble measuring the frequency. I think the oscillator can do about 500 Khz so 250 per output.
I see what you mean about the pulses dropping out too, but it doesn't happen untill the PW is so narrow it doesn't matter.
The SG3525 seems to have a much nicer "Squarer" looking pulse than the SG3524. I'll put both on pin to pin board's so I can make some change's if I need to.
It would have taken me a lot longer to work these out without you're drawing.
Thanks.
Ok I've got a new circuit and it's working well. I get a little flash of light and a puff of smoke from my fingertip now if I touch the toroid.
Video of that soon.
The circuit is reading a max of 550 Khz when no coils are attached and when I use it on the transmitter and tune it a bit it then says 850 Khz with the meter just sitting on the bench about 2 feet from the transmitter but if I connect the meter it then says over 2 Mhz, WOW.
I went with the SG3524 chip instead of the SG3525 chip from 7imix's drawing because I had some and the 24 chip is capable of higher frequency.
I found out however that the 24 chip has only single transistor outputs not TTL so the mosfet turn off was very bad, I fixed the problem by using PNP turn off sharpeners to drain the gates after the pulse is over. Thanks to 7imix's help I had a pretty easy time of it. Thanks 7
I think I labeled the drawing correctly.
Circuit on a project board.
Circuit sketch/drawing
Wave form from scope probe hanging 12 inch's from the toroid.
Frequency reading with the probe on mosfet 2 gate.
Frequency reading with the probe on the bench 2 feet from device.
Here's the video.
AlternateFarmhand1's Channel - YouTube
Enjoy !
Edited in video link.Last edited by Farmhand; 08-29-2011, 05:13 AM.
Hi all, I been playin while waiting for more wire and a function generator, so I can have a chance at achieving full resonance.
I now have a night light, the Fluro is connected to the ground connection of the receicver, and the two LED's are running from the output of the receiver through a FWBR.
With the lights on the receiver I still run the transmitter with only 350 Ma input at 12.5 volts, loading the receiver seems to make a smoother input to the transmitter and I can just keep the protection neon from flaring up, it only just glows from the transmitter actually exciting it. Loading the receiver seems to also make the transmitter Mosfets run cooler.
I was thinking that it may well be possible to get a circuit like this to run a Small Magnifying Transmitter, if it can be made to oscillate at Mhz frequencies I can't see why not. The guys working with the Joule thief exciters could get a circuit like that going I think.
CheersLast edited by Farmhand; 06-26-2011, 03:23 AM.
Ok my order of two rolls 180 meters x 0.5 mm magnet wire arrived so I made up a very simple winding jig from stuff I had laying around, I've finshed the first coil and there is a fair bit of wire left over. I'm not sure what to do about it because the coil is already 635 mm long and 1270 turns
. Long enough I think.
I can only assume there is a lot more than 180 meters of wire or the coil calculator is out of whack, my calculations tll me I already have just over 220 meters on there. I could use slightly bigger diameter former and I might yet I'll have a look for some tubing.
Looks like I should order more wire from that place. A similar thing happened to me the other day, I ordered 2 lots of 4 capacitors so 8 all up they were 15000 uf,35v caps. after a few days they turned up in the mail, 8 caps then two days later another 8 caps turned up
so I got 8 free caps. Hopefully they aspire to become free energy caps too.
Hi guys, ordered my function generator last night.
Function Generator 0.1Hz - 3MHz with AM/FM & VCF input | eBay
I wound some very long coils and have been having some fun with them for now. The transmitter now "bites".
Pic. https://skydrive.live.com/?cid=32a91...1245&sc=photos
Sparks and plasma bulb,
YouTube - ‪Plasma 3.wmv‬‏
Here is the second part of a video showing how I wound the coils, i'm having trouble uploading the first part for some reason.
YouTube - ‪Telsa Coil Winding Secondary 2.wmv‬‏
And this is some strange current use when a fluro is tuched to the toroid, when the fluro actually touches the toroid the current goes down considerably and actually hits zero a couple of times, I suspect this is a meter anomoly but the current does reduce because the battery voltage rises when the load on it is reduced.
YouTube - ‪Low current Fluro‬‏
I have to experiment a bit with some less turns primary, I'll try to think of a good way to tap the primary for testing. I measured the indutance of the two coil "A's" and coil "B's" while they were all set up and the transmitter was 0.006 mH less than the receiver so I wound a small variable inductor which adjusts from 0.005 uH to 0.012uH , I'll make another one for the receiver so I can have a bit of adjustment on it too and so raise the inductance of both a little.
Everything is going well, when I get the fuction generator I will determine the resonant frequency of the coils and build a dedicated circuit to run it, I am planning some more coils allready, I think I have been bitten by the Tesla coil bug.
I have piccies and can explain how I constructed the coil winding jig and the Winding video #1 explains how i went about it. I just need to upload it, every time I make a spark the computer glitch's and the upload fails.
4th time lucky I hope.
CheersLast edited by Farmhand; 06-30-2011, 04:36 AM.
Alrighty, I think these transformers are almost resonant, I am going to make a prediction that the resonant frequency is between 500 Khz and 550Khz it's difficult to get a proper reading with the equipment I have, but it looks like 508.2 Khz is working quite good. And if that frequency or aroundabout is correct then I can easily build circuits to drive it.
Some effects the coil has now. You can see in the bulb the broken filiment starts to rotate under the plasma thrust and it looks like a two pole motor to me because the energy pulses from the transformer are happening as the filiment is on opposite side's of its rotation, utilising two pulses per rotation mostly.
Plasma 5.wmv - YouTube
At about 3.20 in the video the plasma zaps me through the glass.
So another week or so and I should be able to show a reasonable power transfer. I can tune it to use quite a bit of power without overheating the mosfets, maybe 4 ampere's, I'm getting a fair bit of power availiable at the receiver now and it can light a small fluro tube and some LEDs at the same time, the fluro from radiation and the LEDs from the output, which reads about 70 to 100 volts open circuit, without a resistor it burns out LEDs immediately of course, but with a resistor it works and I get 11 volts over two 5mm white LEDs and a 270 ohm 1 watt resistor, quite brightly lit.
I'm trying to nut out some useful setup to make the output of the receiver more usable for running things other than lights.
CheersLast edited by Farmhand; 08-29-2011, 05:06 AM.
Farmhand have you seen this on my thread trees a radiant antenna:
Not speaking Russian , i used google translation to give me the correct translation for wireless electricity in Russian and i found this, quite interesting video:
farmhand, you may want to have a look at it
Experiments with the free energy (watch starting at 2 min easy to reproduceThis device transmits electricity without using any wires as a guide along which the transmission of electricity is land. The device is assembled by the scientist Nikola Tesla patents. The main element of the device is a transformer Tesla.
Experiments cold electricity transformer Tesla magnetic motor Vladivostok converter arc wireless power transmission cooler Bedini free energy of the pulse generatorLast edited by MonsieurM; 07-01-2011, 10:27 AM.Signs and symbols -Confucius.
Yeah I did have a quick look, very interesting and I am planning to check it out better, I like it.Originally posted by MonsieurM View PostFarmhand have you seen this on my thread trees a radiant antenna:
I was thinking of starting another thread specifically for replications of the Magnifying Transmitter as per the U.S. Patent 1,119,732. Apparatus for Transmitting Electrical Energy.
Concentrating on replications, driving circuits, and receiver output circuits.
Hopefully to get some better circuit designers to help with workable circuits for a predictable output.
Maybe if a few of us work together some with more skills than me, we can make an art of this. Which would please Nikola greatly. And hopefully contribute to the acceptance of these things. Maybe.
I have a remarkably powerful device now, it can light two fluro's by radiation at the Transmitter while lighting LED's through a resistor from the receiver while sustaining a virtual short circuit through a 20mm plasma stream to a ground wire, WOW. The input go's from about 4 watts to 15 watts to maintain the plasma stream but I can live with that.
Another video coming soon, shot entirely under light produced from the power through the device showing this.
Thank you for getting me interested in this. I am having a great time. And funny thing is I feel better when it is operating, Energised !
