I see
Great information. I guess I was thinking that the the quick short of the generator coil at the peak of the sinewave was being shorted directly across the drive coil.
Kind of a two for one thing, where a quick direct properly timed pulse was being sent to the drive coil to give it a little kick and at the same time help cancel out the Lenz effect in the generator coil.
Not a lot of "short", but just enough spike at the top of the sinewave to disrupt some of the Lenz effect and give that part of the disruption to the drive coil.
Kind of like an internal combustion engine, where timing of the spark is everything, a little off and it don't work at all.
But, I see how it works now.
ThanksOne thing to keep in mind is, man wrote the laws regarding the conservation of energy, not nature.
Nature writes it's own laws regardless of what man thinks or does.
In a normal setup, if the coil is shorted continuously, there is a repulsion as the magnet approaches the coil and an attraction as the magnet leaves the coil. Using a timed short at TDC for 2ms there should not be much drag at all because the magnet is not in the repulsion or attraction area. Try the experiment by shorting just before or just after the peak of the sine wave. As well as not getting as much power back, there will be some noticeable drag. TDC is like the zero stationary point. Wish i could explain it better.Originally posted by Steve220 View PostGreat information. I guess I was thinking that the the quick short of the generator coil at the peak of the sinewave was being shorted directly across the drive coil.
TDC has zero voltage too, so you cannot get much out in TDC, But, ... I think that if we collect the energy before TDC and in repulsion mode we would drag the rotor much less. Also as the speed increases the time lag of the current in the coil would make the repulsion work not so much against us.Originally posted by Zooty View PostIn a normal setup, if the coil is shorted continuously, there is a repulsion as the magnet approaches the coil and an attraction as the magnet leaves the coil. Using a timed short at TDC for 2ms there should not be much drag at all because the magnet is not in the repulsion or attraction area. Try the experiment by shorting just before or just after the peak of the sine wave. As well as not getting as much power back, there will be some noticeable drag. TDC is like the zero stationary point. Wish i could explain it better.
I see
Thanks Zooty,
You explained it very well
If you can time it just right, and only for the time required, I can see how it works.
There is the zero current at TDC and a little on each side of the repulsion and attraction to work with a properly timed short.
I know many different ways to bypass Lenz law have been tried in the past, but I still think it can be done.
I always thought that somehow a person might be able to disrupt a magnetic field for a split second to cause it to stumble, just a little.
It would not have to be 100%, just enough to gain a little ground each time around.
If that little ground could be scaled up, it would be huge.
Your work has given me an idea to check out for sure.One thing to keep in mind is, man wrote the laws regarding the conservation of energy, not nature.
I was pulling 980 m Amps out of the generator coils
created a dead short circuit across the coils and added the 1.5 Uf capacitor.
this is half wave loaded on the positive cycle only.
was able to get some really good results today this is looking good.
I over heated the coils and damaged them. They melted the former and came unglued from there base plate.
Winding some new one tomorrow.
this is the circuit for todays test.
cap short
didn't mean to get into any trouble here.
Redrichie actually only noted that this was something Romero was experimenting with. not that he discoverd it himself.
I have not read all the posts after mine yet thought I better type this out ASAP.
What if any results did you get w/o the switch?
using the cap in parallel to the coil and prior to the FWBR as I have been experimenting w/ this AM?
Patrick
I think it would be a good idea to have a thread dedicated to coil shorting. Romerouk recently told people to get their rotors speeding up under coil short/load before proceeding to the full replication as it can be applied to most applications, not just the muller style motor.
I agree I want to look into this for all motor generator applications.Originally posted by Zooty View PostI think it would be a good idea to have a thread dedicated to coil shorting. Romerouk recently told people to get their rotors speeding up under coil short/load before proceeding to the full replication as it can be applied to most applications, not just the muller style motor.
Romero said he choose the muller for this technique. its the technique thats important not the muller motor so much.
I am going to run some test on my other motor using the same technique as i have on the muller.
My Adams motor is larger and can handle the abuse . It has .5 ohm 9 m H coils 6000 Gauss magnets.
I also had it at COP 1 so close it stabilized its battery.
Hi Pat, at 12 seconds of the video he states if you were watching Saturday evening i had the Muller spinning on its own power, maybe i got that wrong sorry about thatOriginally posted by minoly View PostAsh,
what result did he get, all I saw him do was spin it up. did I miss something?
Zero sure is thorough w/ his build so far.
Redrichie made a nice find, shorting coils w/ an AC cap right on the pickup coil
Patrick
Ash
Originally posted by toranarod View PostI was pulling 980 m Amps out of the generator coils
This is awesome news Rod. I want to try it as soon as I can.
Can you share your circuit for triggering the Mosfet? Also what is the Fet rated at?
Will you be looking to short it on the + and - of the cycle eventually?
How did you measure the 980ma? With a load permanently shorted to the cap?
Excellent work
Regards"Once you've come to the conclusion that what what you know already is all you need to know, then you have a degree in disinterest." - John Dobson
Yup Ash, before he did speed it up with a Dremel, now he wind and test Coils and installed the first one, as you see in the Video. But hes very busy at the moment because of a Tornado there and he may work not that much on it as he want to.Originally posted by ashtweth View Posthe states if you were watching Saturday evening i had the Muller spinning on its own power
AshTheorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
yes, this works much better with the cap where you put it. I did not have luck w/ the caps I purchased today and the coils I have on hand so I will start winding new coils to test, but the effect is definitely there. it changes the timing where you put it, just like you say.Originally posted by toranarod View PostI was pulling 980 m Amps out of the generator coils
awesome
Rod, can you start the new thread with this one. I'll add JB's/Bolt's Amplified ssg short to it, but I like your's better. others can add theirs as well.
Patrick
