I made some cores a few years ago using iron filings I got from a automotive brake lathe. Any auto repair shop that resurfaces brake rotors will have iron filings.
Does anyone have an opinion on the following ready made coil?
Audio Crossover Inductor 6.01mH - 7.00mH SP056 from Falcon Acoustics, The Leading Supplier of DIY Hifi Components.
wattsup
A core you guys might be interested in
Originally posted by the bob View PostQuote:
Originally Posted by vrand
Hi Zilano,
Is there any benefits to copper coated welding rods vs non copper coated?
Cheers Mike
Hi Mike!
MAGNET CORE (WELDING ROD)
Purpose
To provide a low reluctance path that increases the magnetic flux through the coil.
Specifications
Low reluctance, high permeability magnetic material: Welding rod; 0.042" inch diameter copper coated steel
regards
zilano zeis zane!
Hi LTBOLO
I wasn't talking about his L1 and L2 coils,those coils are ok if tuned right.
thread 14
post 409
He is using copper coated welding rods ( he calls ferrite rod/cu) in his step down to 60 hz transformer. Read above MAGNETIC MATERIAL. His transformer for getting 230 volts 60 hz is magnetic. If you don't believe me, get some copper coated welding rod, make a bundle and put 10 turns of wire on it, put 20 turns beside of the 10 turns. apply 10 volts to the 10 turn coil and you can measure close to 20 volts on the 20 turn coil.
When he said look at the crystal radio, I knew he was going to modulate the system with 60 hz but didn't know where.
Tesla coils are turns ratio tuned with caps.
Zilano even says he uses induction method in his ferrite transformer.
Maybe MR. LTBOLO you should read my last post again.Half of the Answer is knowing the right Question
coil is OK. The ferrite core that's is another problem. I think Iron is betterOriginally posted by wattsup View PostDoes anyone have an opinion on the following ready made coil?
wattsup
other than that I use theses cores Same application just Iron core.
I am starting to look for other types Now.
My core
reply of post #153125
I wanted to check that my calculation was correct ... I took an average of 12mm diameter per turn (lower on the inside of the bobbin, larger on the outside).
One turn: 12E-3 * pi = 17.3 mm
One bobbin, 300 turns: (x300) = 11.31m
19 bobbins: (x19) = 215 meters
I think for the moment, I'll just make 1 driver coil and two generator/experimentation coils. Do you think it's necessary to double the coils (one on the bottom and one on the top of the rotor)?
(respectively 35 meters and 70 meters if I double the coils)
And do you have any links to suppliers for litz wire and iron dust cores?
Sorry for this load of questions
I hope to contribute more constructively in the future.
Meryl
wires.co.uk : Stranded Enamelled Copper WireOriginally posted by meryl.anny View Postreply of post #153125
Meryl
am looking for Iron dust too. any body ?
Thank you, I asked for the 7 strand wire described by Romero, 100 or 200 meters long. i'll let you know of the results (if anybody is interested)Originally posted by toranarod View Post
they have it that's where i purchased it fromOriginally posted by meryl.anny View PostThank you, I asked for the 7 strand wire described by Romero, 100 or 200 meters long. i'll let you know of the results (if anybody is interested)
5.6mH Crossover Inductor - Jaycar Electronics
Audio Crossover Inductor 1.01mH - 1.20mH SID100 from Falcon Acoustics, The Leading Supplier of DIY Hifi Components.
I like this oneOriginally posted by wattsup View PostDoes anyone have an opinion on the following ready made coil?
wattsup
Perhaps we should make our own iron dust cores using raw iron powder. We need to find a way to glue that powder together to form a rod though.Originally posted by toranarod View Postam looking for Iron dust too. any body ?
iron-powder: Iron Powders for Soft Magnetic Products
I could find some cores, but not with the correct shape. Obviously, it's not supposed to be bought by just anybody. Merchants I have found are targeting companies.
