Edit: It has been shown to me by two people, that the way I calculated what I thought would be the co-efficient of performance, was wrong. And this arrangement cannot possibly be over C.O.P 1. So I would have to agree. However it is not possible to change the thread title on the main page so I just changed it above. Sorry for the confusion. Test is still underway to determin the effective work performed of this arrangement compared to conventional use. This will give an indication of any increase in run time for a fixed load. ;
Hi all, I decided with all the complicated machines being built that I should show just how easy it is to acheive a C.O.P. of 1 to 1.8. I used all easily obtained stuff, commecial inverters and a normal light bulb. In the video i make a mistake and refer to a negative terminal as a positive one, nobodies perfect, sorry.
YouTube - AlternateFarmhand1's Channel
At about 8 minutes I make the current reading of the inverter input wire's, there is equal current out to in. The bulb is 25 watts and the inverter is a 12 to 220/240 model, with about 500-600ma standby current use.
Normally the 2.6 amps shown is wasted, but it does not need to be, the only real energy consumed is what is disapated in the bulb the rest is disapated in the negative of the battery in normal circumstances.
Using a "Switch Bank" the 2.6 amps go's on to charge another battery or preferably two identical batteries to the source one's but in parallel.
The funny lookin light in a steel can is what I use for seeing inside chicken eggs when I am incubating them. Just incase anyone was wondering. Umm, It can also cook an egg if one is forgetful or easily distracted.
I don't see how it could be seen any other way than as a recycling of the energy used. I can see how it could be possible to implement this principal into many device's. And in future I will be always thinking of ways to get similar results from different things in different ways.
Taking advantage of the fact that potentials are in a way "locked" and when one falls another must rise.
Here's another video using a small battery charger which uses a 12 volt source.
I'm working on a few different things with this type of effect now but I thought I would show it's most basic embodyment so that it can be used by those who may get benefit from it. After a major storm or something it would be a way to use stuff for much longer than normal and get the very most from your batteries.
Its a perfect demonstration of the Aether powers the load.
. That could get people into trouble. Good thinking though all the same, that's what we need is a new way of looking at thing's.
Seems wasteful, but everything is full. Can't keep it all, I guess I can only gain what I use now.
If that make's any sense.
