Originally posted by RUE
First, I will answer a previous question: I am using a 4"x4" section of AZ31B and the same of copper. I have some ideas on how to maximize material that I'll get to later.
Let me address the update I mentioned on the third cell (I'm going to use the term "cell" like you would a battery, solar panel, etc):
For my third attempt, I wanted to use Sulfur but I wanted to make a model that would survive the test of time and not destroy itself. I just finished this model in the afternoon yesterday so it is far too early to describe it in terms of longevity. One thing I noticed in the first design is that as it began to decompose it began to puff, similar to what you'd see with a lithium battery. I am not seeing any of that yet but it's something I'll be looking for, along with discoloration of the copper.
**Here's what was done**
I first coated the entire contact surface of the copper with a thin film of PVA glue, paying close attention to detail so as not to leave any of the surface exposed. I then added one more layer of PVA and let the glue cure again. *protip* A foam brush is very useful for this, as it holds the glue and can be used for application and then cleaned with water later.*/protip*
I then mixed up a batch of Cr2O3:PVA in a 2:1 mix as in previous versions, and coated the surface of the AZ31B with it, using a tool to make an even layer. Again, I paid close attention to ensure that none of the metal was exposed. Once cured, I took a fine sandpaper and buffed it out so the surface was even and flat.
The final phase was to mix up a 1:1 batch of Sulfur:PVA and use that to bond the two surfaces together. Once I had contacted the two surfaces, I sandwiched them in a clamp between to pieces of flat wood and wax paper.
So far, the device has a peak voltage of 1.2V at approximately 80 deg. F ambient temperature. I was a little disappointed, but I did find that this version can run the small motor for a few seconds before sputtering out.
When completed, this thing measures about 2mm thick.
Phosphorus (Specifically: RED Phosphorus):
I would LOVE to use this stuff, but unless one is in possession of a chemical license, it is very difficult to acquire. Apparently some talented individuals have found ways to produce bombs and methamphetamine with red phosphorus, so big brother decided to make it a controlled chemical (they have a funny way of ruining all good things, don't they?). I am working on acquiring some for another test. I may or may not disclose my progress on that.
Some thoughts:
This device is a capacitor which naturally regenerates. The charge is stored on the metal plates unless it has somewhere else to flow. If you haven't thought of it already, try using some low voltage super capacitors to allow a place to store charge. It's a simple alternative to batteries.
A paint should be used on the surface of the copper to prevent it from being damaged by the elements.
There are other topologies which can be imagined whose benefits are maximum usage of available surface area from the individual sheets of metal, I am comparing those to the basic "plate against plate" method described in the patent imagery.
As a previous poster has stated, we must assume that Lovell left something highly significant out of the patent which could be the key to higher output. Our job is to experiment with as many different configurations of the device as possible in hopes to uncover the secret.
