FYI:
I posted this earlier:
Wouldn't you think there is a correlation between "Joe Cell" and "Moe-Joe Cell" and Peter DAVEY Sonic Resonance Boiler
Shocking history of the revolutionary boiler which bits all possible records (in English) (2/3 down the page to see the replications)
could not find replication vid online of this set up, but well worth trying to replicate just to efficiently heat your water (you could use gold, silver, copper etc... to give your water new properties...
) or boil it and put it in a moe joe cell (takes a few sec to get it to boil)
Peter Davey -- Sonic Resonance Boiler
YouTube - ‪Peter Davey's Sonic Resonance Boiler - 02.2008‬‏
ps: check out the vid i posted
Water Vortex Magnetizer and ORMUS M-State Concentrator
(not sure about the following statement but probably some have used it)
This is the "Original" structured water device that is
used by "Joe Cell" and "Moe-Joe Cell" inventors
to create highly energized water for their hydrogen cells.
The design of the Davey's sonic heater is extremely simple. It actually is composed of two major parts only - see Figure K8 (3) from monograph [1/4]. The most important out of these two parts is a resonating hemispherical bowl (1) made of a sound inducing metal plate. The second part is a buffering hemispherical bowl (2) almost identical in shape to the bowl (1). This second bowl has the radius around 4 mm larger than the resonating hemispherical bowl (1). Both bowls are assembled symmetrically one around the other, means the hemispherical bowl (1) is placed inside of the hemispherical bowl (2). Coin is 32 mm wide = 1.25984 inches / Big bowl approximately 1.75 inches wide and .75 inches thick / Small bowl approximately 1 3/8 inches wide. Of course, apart from these two bowls, the heater also includes a long rod, nuts, washers, and electrical wires. These are to hold it together, to supply electricity to both bowls, and to allow the heater to be submerged into water that it heats. But these other parts are marginal additions only. The major parts are the bowls. During experimental production of this heater, the resonating hemispherical bowl (1) usually is made from an old cover for a bicycle bell. The dimensions of this hemispherical bowl are not important. It is only vital that it falls into a sonic resonance at the frequency of 50 Hertz, and that it has the outer surface which is parallel and equidistant from the external buffering hemispherical bowl (2). To each of these two bowls a different wire of the household electricity supply (i.e. 220 V, 50 Hz) is connected. The heater must be submerged in water that it heat. It brings water to the boiling point extremely fast. More details about the design and operation of this sonic heater is provided in subsection K3.3 from volume 10 of monograph [1/4]. After being constructed, the Davey's telekinetic heater must be "tuned" in two different manners. The first tuning depends on providing the hemispherical bowl (1) with such frequency of the own oscillations, that makes this bowl to resonate acoustically when a sound of the frequency 50 Hertz is emitted nearby. The second tuning of the heater depends on appropriate selecting the distance "L" between both bowls (1) and (2). On this distance depends the formation of the standing wave between both bowls. Thus it decides about the energy efficiency of the entire heater. From the information that the inventor repeated to me, I gather that the measurements carried out by New Zealand scientists suggested that this heater may consume even less than the equivalent for around 5% of the energy that it generates in form of heat. This would indicate, that the electrical efficiency of this heater is around 2000%.
) or boil it and put it in a moe joe cell (takes a few sec to get it to boil)Peter Davey -- Sonic Resonance Boiler
, what i meant by "correlation" is in the structure being used not how they are used, i think that both use resonance to be functional (we are looking here at the cause not the effect
....links water in the tree and this research
