Reed switch bounce
Sometimes reed switches will bounce at various switching speeds and give a false signal or a signal full of noise. Still, I like reed switches because they are simple, but for accurate timing applications, may not work so hot.
I agree, a pickup coil and a Schmitt trigger would result in a cleaner output signal. This gives you the best of both, the analog pickup coil and a accurate square wave output that is adjustable at the required trigger point of the input. I think electronic ignition systems works this way too for accurate timing of the spark.
, now will use my new SSG coil with the same BR, TIP32C and an AC 440V 2.5+1.5uF capacitor. The only AC cap I have is a weird one with 6 pins so I soldered on 3 wires/connector so can swap to other capacitance
