Thanks for those images Farmhand. I'm not really sure how that all connects together though to drain the base. But I realised last night how your method as opposed to the spark gap might be used in the same way John Hutchison was using his coils, because as far as I can remember he was using frequency generators and what not.
Things are starting to get weird with the spark gap though. I was streaming some BBC iplayer video, whenever I activate the circuit the stream stops. Something also happened to the SSG's power supply, in that it shut itself down and I had to reset it by turning it off and back on, there are no wired connections between the Tesla experiments and the SSG.
Also the neon across the emitter and collector appears to have some use. It sometimes flashes when I turn the circuit on for the first time so there's HV coming back through in a similar way to an SSG needing a protective neon.
And the last thing was I wanted to compare the output before the spark gap, and from the Tesla coil output, but I started getting tingling in my fingers while holding the glass on the other end of the 30cm fluorescent while testing BEFORE the spark gap, so I think I'll put on some gloves before I continue further
It's getting more interesting and scary at the same time
As far as output goes so far, the shorter the spark gap/the higher the frequency, the brighter the fluorescent, but the shorter the streamers. There's a lot of things going on for me to be paying attention to and a lot of variables in its operation, plus I don't think the meter is quite telling the truth, so I can't really start to say about the input. It's generally in the 1-3A range though and sometimes more, currently on 12v.
Nice videos btw, I think that small fluorescent is the same one I was using earlier. It sounds like there's something loose rolling about inside yours too, I thought I'd broken it
Good stuff
Also let me know if/when you want more details on the spiral coils construction. I haven't measured the outer diameter of the secondary yet, and I'm still getting to grips with the circuit and all that so there's still some testing and modifications to be done, so I intend to see which is the better way to make the coil come to an end. And once I get an idea of how it all works and get something stable going I'll also be testing whether or not wood up close affects it. So it's still open to updates if anyone's planning on building a couple, you can use the info provided so far or there'll be updates coming at some point
Good stuff Also let me know if/when you want more details on the spiral coils construction. I haven't measured the outer diameter of the secondary yet, and I'm still getting to grips with the circuit and all that so there's still some testing and modifications to be done, so I intend to see which is the better way to make the coil come to an end. And once I get an idea of how it all works and get something stable going I'll also be testing whether or not wood up close affects it. So it's still open to updates if anyone's planning on building a couple, you can use the info provided so far or there'll be updates coming at some point
It's all getting very interesting
He uses a rotary make/break switch in this one.
