In this image I think A is the active terminal, ( the high one would be disconnected for experimenting) of course.
B is the Coil "B" .
And C is a smaller Coil "A" and coil "B" combined but no primary coil "C".
The arrow D is pointing to a thick copper bus bar positioned directly above
the coil "A" and the primary coil "C" to protect them from arcs.
I think both the coil "A" and the coil "C" are about the same diameter. The
primary will no more readily arc to the secondary coil "A" as it would arc to
the ground because the secondary coil "A" is connected to ground. So the
coupling distance only need be sufficient to prevent arcing from the primary
coil "C" to the Secondary coil "A", this is the limiting factor for the input
voltage to the primary or the closeness of coupling. I think. it looks like the primary is about 50mm wide strip or rectangle bar.
Uploaded with ImageShack.us
This image shows the cylindrical conductor B' and the Hood "H" the sphere
terminal right on top of the coil "B" is there for experimenting inside again I
think or for producing streamers for the time lapse photo's.
P.S. If I were to build a coil like that I would wind the secondary coil "A" on
the fence, then I would cover it by wrapping something around it like another
layer of wood or something else to give good insulation then I would wind the
Primary right onto that. That is if I had it all calculated out like Nikola would
have. The Primary coil "C" and the Extra coil "B" could still be tuned for length
without needing to touch the coil "A".
B is the Coil "B" .
The pics look nice
At least then
The 33cm wire would follow the same pattern as the ruler. The most flappiness of the free terminal (loose end of the (now 33cm) ruler) would occur at 1/3 of the wire (11cm) or at 33cm.
