Hey Farmhand. That's looking pretty cool
Are you deliberately making it spark that slow?
I literally just finished making these
I wasn't going to post anything here because I didn't have anything to show except the fact I've made them, but a test run using a crude primary last night revealed the opposite of what I've noticed with the spirals. With these little coils, smaller capacitance gives a clear higher output voltage, and the significance of that might become clear in a minute. So with that in mind the test run after finishing them just now quickly went from 1860pF of ceramic caps to 200pF vacuum caps. I haven't tried any smaller yet because it revealed an effect that I think is worthy of posting here. So I'll explain the coil specs here, then I'll get to getting some video or pics of it.
I haven't made terminals for the coils yet. What I have in mind is 18mm MDF of a certain diameter using a holesaw, and then spray this with some 99.9% zinc galvanising spray.
Anyway, the specs. 20mm pvc conduit for the secondary, 15.5cm winding length consisting of 28.8 grams of 26 SWG. The primary consists of 28.8g 17 SWG, 12 turns, 42mm diameter. The primary and secondary are wound in the same direction on the coils, but the two coils are wound in opposite directions to each other. But everything is fully dismantleable so the primaries can easily be swapped and I've built them with making/testing different primaries in mind, the basic idea of which can be seen here
28.8g of wire was used because I originally weighed and matched them for the spirals, but as you may remember the 26 SWG was too long to fit on the base. The primary was also weighed before I improved the design of the spirals, so I basically had a complete matching set of wires left over.
So I have no idea of the tuning of it and the resonant frequency or anything. But the primary should be somewhat in tune with the spirals primaries give or take 0.2g of copper so I'll play with that at some point. I'll be back soon hopefully with a video anyway
[edit] Also the big gap at the bottom is so they can be used for Johnny Davro's simple SEC by putting a wire up inside the secondary connecting to the transistor base, so they are supposed to be as versatile as I could think of
Oh well. Also my webcam isn't capable of detecting the effect. Basically the whole wire coming out of the top of the coil has mini lightning bolts coming out all along it. Different spark gap settings determine how far down the wire they go. At a certain setting it looks like the plasma is sort of pulsing in waves going up the wire. Very interesting to look at but the place has never stunk so much of ozone.
A lot of
Same situation as the tank of water and submarine before
