Originally posted by MonsieurM
The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Based on what you just said if we find a way to excite quartz, there is a way to excite certain type of ice (those with close geometric similarities to quartz
we are converging... and this is good news, it means we are on the right track
Originally posted by IndianaBoys View PostMonsieurM,
Remember reading years ago Wilhelm Reich did some experiments with sand (quartz) and placing it in a sock then repeatedly boiling and freezing. In a dark room you could see it glow blue. Believe he referred to it as bions or orgone becoming visible. Maybe someone can locate the exact procedures for the experiment?
IndianaBoys
i will look for it...
Signs and symbols -Confucius.
Shawn, guys, have you seen this 9 min vid on the vedas (i know i talked about it earlier) this is one more i recommend you watch, at least the first 5 min
Greatness Of The Vedic Vedas Knowledge Perfect Science Part 3 of 6 - YouTube
please do comment on it, because it would help us in choosing the right source of light (i root for Pulsed High intensity UV light )
IndianaBoys, you are da man
Wilhelm Reich -- Orgone -- Collected articles
Method for biological activation of inorganic materials, e.g. calcium carbonate, useful to provide products for e.g. improving plant growth, or as a feed additive, comprises the use of radiation from an orgone chamber
Inventor: BARTH ADALBERT
2003-08-14
Abstract -- A method for biological activation of inorganic materials (I) involves applying radiation from an orgone chamber onto a metal surface and placing the mineral material (I) under the surface at a pre-determined spacing, so that (I) is subjected to the effects emanating from the orgone chamber and the metal surface. An Independent claim is also included for an orgone chamber for carrying out the process, comprising a vertical hollow body (preferably of square, rectangular or round cross-section) with: (1) vertical walls consisting of an inner electrically conductive layer (preferably of steel sheet) and an outer non-conductive layer; (2) a closed base consisting of a film or sheet (preferably of aluminum, as information matrix); and (3) a closed top consisting of a combination of layers as in (a), covered with a layer or quartz sand.
so what if Orgone was plain http://www.energeticforum.com/renewa...tic-field.htmlOriginally posted by MonsieurM View Post
Phospholuminescent Glow Sheets
MonsieurM,
Here is an item that may be of assistance to help visualize the energy:
PHOSPHOLUMINESCENT GLOW SHEETS
GLOW IN THE DARK TAPES AND SHEETS
Full sheets of glow-in-the-dark material measuring 12"x 12" square. It can be used as-is, stuck to a wall or metal plate, or easily cut into long strips with scissors or a paper-cutter following the observational protocol given below. Several sheets can also be assembled together to make an entire "glowing wall" for visualization of the human energy field.
Price: $23.95 per square foot sheet (12" x 12")
Visualizing the Orgone Energy in a Darkroom
by James DeMeo, Ph.D.
Director, Orgone Biophysical Research Lab
Ashland Oregon USA
The following describes a simple experiment to observe orgone energy in a darkroom. We routinely make this demonstration to students and professional visitors to our laboratory, inside the Orgone Energy Darkroom. But an orgone energy darkroom is not necessary. An ordinary darkened room will do, if care is taken. The experimenter should firstly read Wilhelm Reich's accounts of this phenomenon as given in his book The Cancer Biopathy which is available from our bookstore and from libraries.
Necessary Equipment:
* Steel sheet metal measuring 1 foot square, or 1 x 2 foot, about 26 gauge galvanized steel.
* One or more reels of 0.5" width glow tape, or one reel of 1" width glow tape.
* A small quantity of standard heavy duct tape.
Firstly, by our information this glow-in-the-dark material does not appear to have any "lifetime", so long as you put it where it will not be physically damaged. It should retain the ability to absorb light and then glow in the dark almost forever, though expect the viny material to begin degrading over time if you expose the material to sunlight or moisture.
To use this glow material to help observe the moving orgone in a darkroom, you firstly must secure a darkroom! A closet would do, but better to have some enclosed space where there is air ventillation, as you will need to sit there for upwards of 30 minutes or more, and all light as from windows must be closed off. This can be done in both daytime or nighttime, though daytime is more demanding to seal off windows and other stray light sources. Even at night, stray light creeping under doors or in *****s of windows from city lights or other parts of your home might be sufficient to overwhelm the effect, so firstly getting a really dark room is important. Set it up with a comfortable chair as you will need to sit in this dark environment for maybe 20-30 minutes, to allow your eyes to "dark adjust".
Once you have found such a dark room and sat in it to adjust your eyes, even with a tiny, tiny amount of light creeping in, many people observe the orgone energy quite spontaneously. It appears as a slowly moving dull-grey fog or as tiny moving points of light. If you observe this phenomenon against a checkerboard or pin-stripe background of high contrast, such as alternating patterns of black and white, it helps enhance the effect. Our glow-tapes and sheets are used to enhance this natural effect even moreso.
Using the glow tapes, you can make an "array" of parallel strips of tape separated about the same width of the tape, and lay them out on a flat piece of metal (the metal also enhances the orgone energy effects). Get a sheet of metal perhaps 1' square, standard 26 or 28 gauge galvanized steel as from a sheet-metal shop will do. Wash it clean of oils and allow to dry. It helps to add a strip of duct tape along the metal edges, to prevent cutting your hands during handling.
From one package of the 0.5" x 48" glow tape, you can make 6 strips of tape 8" in length. Lay the strips out near the center of the metal plate in parallel rows separated by around 0.5 inch. You will then have an array of the tape strips separated by equal widths without the tape. You can make an array to nearly fill the sheet metal piece by using more of the tape strips. The tape measuring 1" width is more economical, but to do the job right, it might be necessary to cut it down with scissors to the 0.5" width. A larger metal sheet measuring 1' x 2' is even better, but obviously requires more tape. At our lab, we have several of 1 x 2 foot metal sheets prepared like this, using 1.5- or 2-foot strips of the tape, and the effects are quite spectacular as enhanced inside our orgone energy darkroom. Similar effects are possible in an ordinary darkroom, but if you have an orgone energy accumulator or orgone blanket, you can place that near to the metal sheet with the tape to also enhance the effect. The large sheets of glow material can also be used for this same purpose, and you can then lay opaque shadowing materials on top of it, to yield up similar high-contrast patterns. It is useful for a variety of experimental purposes.
Just prior to running your visualization experiment, expose the metal sheet and tape strips to an ordinary houselamp or strong flashlight beam. Then take it into the darkroom and settle down. Almost immediately, you will observe the tape glowing brightly in the dark room, such that you can see around the room without any other source of light. This will become more apparent as your eyes adjust to the dark. Eventually, the glow tape will start to lose its energy, and the glow will start to dim. At this point, you will observe more and more movement around the glow tape, and the entire room will fill with motion that previously was not apparent to you. When the glow tape is very dim, and the metal sheet with the array held off at around 3 foot distance (one meter) you will see a tremendous agitation and motion of the energy, moving between the dark and lighter areas of the tape array. It is a motion which occurrs just above the tape array, not "in the tape", which you can confirm by looking at the array held flat to your line of vision. The movement jumps off the metal sheet, and towards it, being made visible by the dull light of the glowing tape. At this point, you can also use a magnifying glass to verify that the phenomenon can be magnified -- this proves it is "out there" and not some optical illusion. Best to use a large diameter magnifying glass where both eyes can be used at once.
Using the larger glow sheets, you can also cut them into strips, or any shape you wish, to reproduce the above observations, or just use the glow sheet without modification. You can also assemble several glow sheets into a large array -- for example ten or twelve such sheets, organized to make an array measuring 3 foot-squares horizontally and 4 foot-squares vertically, will virtually cover a large section of wall. The material can then be activated with a strong light, and then a person can stand in front of the glowing material as it slowly dissipates, to visualize the human energy field. This can also be done with even one of the squares, to visualize the field around a hand or smaller object, but it becomes more dramatic with the larger array of material.
At OBRL we are today experimenting with specialized very low-light videocameras to document these interesting phenomenon.
Happy Observing!
A Survey Of Laser Lightning Rod Techniques
MonsieurM,Originally posted by MonsieurM View PostShawn, guys, have you seen this 9 min vid on the vedas (i know i talked about it earlier) this is one more i recommend you watch, at least the first 5 min
A Survey Of Laser Lightning Rod Techniques:
http://www.teslaradio.com/pages/AD-A239_988.pdf
The concept of using a laser to create an ionized path in the atmosphere to act as a lightning rod is not new. Over the past four decades since the invention of the laser, there have been many documented investigations into the ionization of atmospheric gasses with an eye towards creating a laser lightning rod. Initial experimental attempts using lasers operating in the IR were not successful. Although some ionization was attained, it was found that the laser beam was selfquenching so that distances of only tens of meters were obtained in the atmosphere near sea level...
The laser is in the UV range.
I had started a thread but it did not generate any interest:
IndianaBoys
I posted this a while back:
Plasma antenna - Wikipedia, the free encyclopedia
A plasma antenna is a type of radio antenna currently in development in which plasma is used instead of the metal elements of a traditional antenna.[1] A plasma antenna can be used for both transmission and reception.[2] Although plasma antennas have only become practical in recent years, the idea is not new; a patent for an antenna using the concept was granted to J Hettinger in 1919.[3]. A recent book (see reference 9 below) titled "Plasma Antennas", authored by Dr. Theodore (Ted) Anderson ( [email protected]; 518-409-1010 USA number) and published in 2011 by Artech House covers plasma antennas comprehensively. The link for this book is: Plasma Antennas Early practical examples of the technology used discharge tubes to contain the plasma and are referred to as ionized gas plasma antennas.[1] Solid state plasma antennas (also known as plasma silicon antennas) with steerable directional functionality that can be manufactured using standard silicon chip fabrication techniques are now also in development.[4] Plasma silicon antennas are candidates for use in WiGig (the planned enhancement to Wi-Fi), and have other potential applications, for example in reducing the cost of vehicle-mounted radar collision avoidance systems.
Are you suggesting that pulsed UV will cause the water in the quartz to 'shine'?Originally posted by MonsieurM View PostShawn, guys, have you seen this 9 min vid on the vedas (i know i talked about it earlier) this is one more i recommend you watch, at least the first 5 min
please do comment on it, because it would help us in choosing the right source of light ( root for Pulsed High intensity UV light )
Well this obviously shows the answer to the Indiana Boys about their question. This would absolutely ionize a distance of 12 inches given the right intensity and wavelength. So if these researchers were using UV lasers in an attempt to ionize water, basically splitting water into itnto basic elements of alkaline and acid fractions, therfore causing a path of least resistance for lightening to travel to the ground then this shows potential of using a UV laser, if pointed toward a water pocket, to draw energy from a charged crystal but only if the crystal has a tendency to naturally, chemically, etc draw the bound/stored electicity toward the water that is trapped within. If the water is a focal point for the electricity to draw toward, sort of like rain falling into a funnel and centralizing at the bottom, then yes this will certainly work. However, I wonder what would happen if it actually worked. Imagine if scientist succeed in drawing down a lightening bolt using a laser, bang, and a split second later, no more laser, unless the laser were surrounded by very tall lightening rods. So my suggestion would be to shoot a laser through a hollow rod of aluminum and place the aluminum against/ near the crystal to draw the electricity away from the laser beam. And sure, let's try UV first.Originally posted by IndianaBoys View PostMonsieurM,
IndianaBoys
Here's a thought of a low level cascade effect. Use tungsten wiring , connected to a solar panel as the source of electricity. The tungsten heating element hits the quartz which turns the energy into infrared light, which is absorbed into the solar panel and perpetualtes in a circle. Of course this will not work due to energy level requirements to energize the tugsten but i thought it might trigger other trains of thought that might work. WHo knows?
