The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • Hehay, finally, found the UV LED's
    Also came up with a clear see through and sealed crystal cells tester. 2 plastic spoons one on top of the other, sealed in epoxy or hotglue. Makes for blasting with just about anything.
    The first such cell is of epsom salts, still trying to find some local rochelle salts.
    Now on to a few tests. Will report back
    Here's the approx 200 LED's:
    Here's the double spoon clear cell:
    • So here's funny...
      Coast to Coast have just had a guest on talking about syncronicity. I was listening to that while connecting up one of these UV LED's. Couldn't see anything at all from it, in person or via camera (as done for I/R) and nothing happened to the cell I was testing either.
      So, while listening to the show I walked into my game room, where there are several arcade machines and the idea was to see if the other board of these UV LED's was in a box in there. Maybe this lot were toast or something.
      There next to the desk, behind where I used to have my PC, was my UV EPROM eraser !!!!!
      Syncronicity or what ?
      Been in there plenty of times and not seen it.
      I connected it up, put the cell inside and blasted the thing with the strong UV these create.
      Left it to run a good 5 minutes.
      Unfortunately the cell didn't do a bean, stayed at 0.895V
      Well worth doing though, for that whole syncronicity thing.
      Here's the cell in the EPROM eraser:
      I'll try other mixture cells though next.
      • Originally posted by Slider2732 View Post
        So here's funny...
        Thank you mark, for trying the UV experiment....
        .....I need to think about your result , we are missing something...a UV reactant or absorber
        Synchronicity , what would we do without you
        Signs and symbols -Confucius.
          Slider2732, you made an Egg Crystal Battery
          • Rod just posted a very interesting info, that just adds more credence to the Ankh Set Up:
            Originally posted by toranarod View Post
            hello MonsieurM
            I saw a video on you tube about Bell labs creating a supper magnet
            and they appeared to use wire wound in this configuration.
            see if I can find it?
            Strongest Magnet in the World in 1963 - YouTube
            I found it
            Niobium - Wikipedia, the free encyclopedia
            This is great news for the Ankh set up
            Quartz + Neo
            ps: this is also applicable to Felix Ehrenhaft: Magnetic Current --- 9 articles
            see post: http://www.energeticforum.com/156953-post764.html
            Thanks Rod
              Here is another interesting Vimana version i found on a Turkish website
              Levitationsmaschine-Cetin BAL - GSM:+90* 05366063183 -Turkey/Denizli
              same design as the Ankh Set up
              alright, I have had some time to absorb the information. I always tend to want to give a conclusion to the information i have learned otherwise we are like computers; alot of data / knowldege and no wisdom / i.e. don't know what to do with it. So If these people are suggesting using a telsa coil for for running a UFO then what we are really talking about here is high voltage. Which brought me back to the crystal battery and a thought. When we saw the plexiglas being charged with millions of volts why didn't they leap from the floor and slam into the ceiling? Its because they were storing the energy and there was no way for the elctricity to form a pathway to create structured electromagnetism. Yet at the same time the electrons are not just running wildly or there were be an excessive amount of heat due to current / eddy currents and the thing would burst into a million pieces. Which led me back to structured release of energy. SO I went to you tube to see if anyone had thought of what I was thinking.
              Electro Levitation Demonstration FRANCE
              • Electro Levitation Demonstration FRANCE
                [/QUOTE]
                Electro Levitation Demonstration FRANCE - YouTube
                sorry
                start at 2:50
                • Originally posted by shawnnweed View Post
                  sorry
                  start at 2:50[/QUOTE]
                  HOW IT WORKS:
                  The simple explanation:
                  you have a two terminals with a 25k volt potential across them. The air near the tiny "corona" wire turns the air around it ionic. This newly charged ion air, then rushes towards the aluminum skirt (which is at the opposite charge.)..this is the "ion wind". The moving wind, brings new air near the tiny wire, which again becomes ionic, and the whole cycle repeats.
                  The more complicated explanation:
                  The two terminals have a 25k V potential between them. One of the terminals is MUCH smaller than the other. Thus, if since both are charged to the same level, the small wire will have a MUCH steeper electric field gradient around it, than the aluminum skirt will (its electric field gradient is smoother). So, in sum, the smaller wire rips ions (because of its steep electric field gradient) far more fast and readily than the aluminum skirt does. So there is a surplus of ions around the top of the craft, these ions don't stick around long, and rush towards the bottom skirt immediately. This is the "ion wind". The whole cycle repeats...and voila..lift/thrust.
                  NOTE: it does NOT matter if you change the top to negative, and the bottom to positive, or vice versa, you still get ion wind going downward. The ion wind is created by the smaller wire being able to rip ions more readily than the skirt, and it is independent of charge.
                  A MESSAGE TO THOSE WHO THINK ITS NOT ION WIND:
                  it's not "anti-gravity"...or "electrogravitics"....all the internet scholars need to stfu, it's just ion-wind...it's a VERY normal thing in electromagnetic theory. It's just that someone arranged a ion wind generator in the shape of a hovercraft, and now ever 13 year old and 45 year old non-physicist/non-engineers all think its a "UFO"!!! or btter yet...that it's "electrogravitics"..hahahah.
                  So, no...don't tease yourself there is no government conspiracy, life is much more boring that you suspect...it's just ion win.
                  This thing does NOT work in a high-vacuum (that is, a chamber that has had nearly all the air molecules sucked out). High-vacuums are VERY hard to create, and usually only physics labs have them....But guess what???? some physcists/engineers went ahead and used their highly sophisticated equipment to show that lifters do not, in fact, work when there is no air around to be charged. ....so no, its not "anti-gravity"...it really is just ion win.
                  Here is the link showing a lifter in high-vacuum:
                  EHD Thrusters Research: Lifters in vacuum
                  and here is another link showing this "government supressed super secret technology" being used TO COOL ****ING LAPTOPS...
                  Cool Your PC or Laptop with Ionic Wind
                  (see! its really not that amazing when you take it out of the UFO configuration)
                  Now, if anyone wants to build one, just google it. There's ton of intructions online...but becareful to ignore all the 'anti-gravity' banters...its annoying.
                  If anyone wants to learn Electrodynamics and how this stuff all works, I highly reccomend this book:
                  http://www.amazon.com/Introduction-E...iffiths/dp/013...
                  (you can find a pdf copy on torrents sites...the book does require a good understanding of calculus, so make sure you know that well...it teaches you all the vector mechanics you need to know)
                  here's another showing Ion wind
                  LIFTER SMOKE TEST - YouTube
                  • i created a levitating aluminum model replica of the Bob Lazar 'Sport Model', page 1
                    • Now that we have traveled some distance, it won't hurt to look at our road map: The Kybalion
                      this is the second time i am posting it, and I'm sure this time around its meaning is crystal clear :
                      the wonderful phenomena of the power manifested by the Masters and Adepts, who are able to apparently set aside the Laws of Nature, but who, in reality, are simply using one law against another; one principle against others; and who accomplish their results by changing the vibrations of material objects, or forms of' energy, and thus perform what are commonly called "miracles."
                      : "He who understands the Principle of Vibration, has grasped the sceptre of Power."
                      Where you find one thing you find its opposite-the two poles.
                      Things belonging to different classes cannot be transmuted into each other, but things of the same class may be changed, that is, may have their polarity changed. ( ex:leedskalnin)
                      Thus Love never becomes East or West, or Red or Violet-but it may and often does turn into Hate-and likewise Hate may be transformed into Love, by changing its polarity. Courage may be transmuted into Fear, and the reverse. Hard things may be rendered Soft. Dull things become Sharp. Hot things become Cold. And so on
                      And it will also be noticed that even to those unfamiliar with the Principle of Vibration, the Positive pole seems to be of a higher degree than the Negative, and readily dominates it. The tendency of Nature is in the direction of the dominant activity of the Positive pole. (see http://www.energeticforum.com/151657-post326.html )
                      the Principle of Rhythm :There is always an action and reaction; an advance and a retreat; a rising and a sinking; manifested in all of the airs and phenomena of the Universe. Suns, worlds, men, animals, plants, minerals, forces, energy, mind and matter, yes, even Spirit, manifests this Principle.
                      The Principle of Rhythm (ex: pulse generator ) is closely connected with the Principle of Polarity described in the preceding chapter. Rhythm manifests between the two poles established by the Principle of Polarity. This does not mean, however, that the pendulum of Rhythm swings to the extreme poles, for this rarely happens; in fact, it is difficult to establish the extreme polar opposites in the majority of cases. But the swing is ever "toward" first one pole and then the other.
                      The Principle of Cause and Effect underlies all scientific thought, ancient and modern, and was enunciated by the Hermetic Teachers in the earliest days. While many and varied disputes between the many schools of thought have since arisen, these disputes have been principally upon the details of the operations of the Principle, and still more often upon the meaning of certain words. The underlying Principle Cause and Effect has been accepted as correct by practically all the thinkers of the world worthy of the name. To think otherwise would be to take the phenomena of the universe from the domain of Law and Order, and to relegate it to the control of the imaginary something which men have called "Chance." ( ex: Butterfly effect - Wikipedia, the free encyclopedia )
                      The office of Gender is solely that of creating, producing, generating, etc., and its manifestations are visible on every plane of phenomena. It is somewhat difficult to produce proofs of this along scientific lines, for the reason that science has not as yet recognized this Principle as of universal application. But still some proofs are forthcoming from scientific sources. In the first place, we find a distinct manifestation of the Principle of Gender among the corpuscles, ions, or electrons, which constitute the basis of Matter as science now knows the latter, and which by forming certain combinations form the Atom, which until lately was regarded as final and indivisible.
                      The latest word of science is that the atom is composed of a multitude of corpuscles, electrons, or ions (the various names being applied by different authorities) revolving around each other and vibrating at a high degree and intensity. But the accompanying statement is made that the formation of the atom is really due to the clustering of negative corpuscles around a positive one-the positive corpuscles seeming to exert a certain influence upon the negative corpuscles, causing the latter to assume certain combinations and thus "create" "birth" an atom (ex: Protons and neutrons are both nucleons )...
                      This is in line with the most ancient Hermetic Teachings which have always identified Masculine principle of Gender and Feminine Poles Electricity
                      The so-called Negative pole of the battery is really the pole in and by which the generation or production of new forms and energies is manifested. There is nothing "negative" about it....
                      ..The Cathode, or Negative Pole, is the Mother Principle of Electrical Phenomena, and of the finest forms of matter as yet known to science. So you see we are justified in refusing to use the term "Negative" in our consideration of the subject, and in insisting upon substituting the word "Feminine" for the old term. The facts of the case bear us out in this, without taking the Hermetic Teachings into consideration. And so we shall use the word "Feminine" in the place of "Negative" in speaking of that pole of activity
                      A Feminine corpuscle becomes detached from, or rather leaves, a Masculine corpuscle, and starts on a new career. It actively seeks a union with a Masculine corpuscle, being purged thereto by the natural impulse to create new forms of Matter or Energy
                      Law of Gravitation-that strange attraction by reason of which all particles and bodies of matter in the universe tend toward each other-is but another manifestation of the Principle of Gender, which operates in the direction of attracting the Masculine to the Feminine energies
                      "Rhythm may be neutralized by an application of the Art of Polarization....
                      ...You simply overcome one law by counter-balancing it with another, and thus maintain an equilibrium.
                      "-The Kybalion.
                      "Nothing escapes the Principle of Cause and Effect, but there are many Planes of Causation, and one may use the laws of the higher (frequency ) to overcome the laws of the lower (frequency ie matter )."-The Kybalion.
                      ps: The ion wind is just one of forces that is working for us in the Ankh Set up
                      break the shackles of 2d, a fractal construct is multidimensional, it depends on mutiple force existing in different planes (the Ankh Set up does it )
                      • Anisotropy has many forces at play too....
                          alright, I have had some time to absorb the information. I always tend to want to give a conclusion to the information i have learned otherwise we are like computers; alot of data / knowldege and no wisdom / i.e. don't know what to do with it. So If these people are suggesting using a telsa coil for for running a UFO then what we are really talking about here is high voltage. Which brought me back to the crystal battery and a thought. When we saw the plexiglas being charged with millions of volts why didn't they leap from the floor and slam into the ceiling? Its because they were storing the energy and there was no way for the elctricity to form a pathway to create structured lift. Yet at the same time the electrons are not just running wildly or there were be an excessive amount of heat due to current / eddy currents and the thing would burst into a million pieces. Which led me back to structured release of energy. So I went to you tube to see if anyone had thought of what I was thinking.
                          Ion wind...using a telsa coil to generate high voltage. It's possible but you would need more than one. At the best conficuraiton a telsa coil pulsing at 12 intervals creates a 97% effecient steady current. But it would require three to get a continous current with zero failure. Which is probably why the viamans used three 'ank' setups to power their craft. However, solely using ionic propulsion means that the highest level you would be able to attain would be 65,000 feet; the air would be too light to attain further elevational thrust.
                          DC Tesla Coil design
                            we both agree..it would require more than ion wind
                            • ps: The ion wind is just one of forces that is working for us in the Ankh Set up
                              The other would be electromagnetic gravitaional thrust using a torroid
                              • MM my friend you are a wealth of information, there you go strip searching the net again
