The Golden Tractate of Hermes Trismegistus applied to electromagnetism
In light of what we know now, let us look back at a video i posted a while back:
Principle of Mentalism
watch it pulsate and spiral
Floating Water Bridge - a fantastic Electrohydrodynamic Phenomenon - YouTube
what do you see and what don't you see
Benoit Mandelbrot.-
ps: the music is nice too
Floating water bridge / thermography - YouTube
Floating water bridge / density gradient visualisation - YouTube
Complete pdf Doc on Les Brown Physics of Crystals...Read it
MEGAUPLOAD - The leading online storage and file delivery service
As you saw in this experiment the water was triply deionized, and
from The Legacy of Marcel Vogel
8: Water research
Water is one of the prime solvents from which life has evolved. It is also the basis of many of the chemical compounds that are on the earth. From measurements made with the Omega 5, we obtain a measurement for water, in the pure state, of 454. The water used was triple distilled.
Signs and symbols -Confucius.
I wanted to link Dr Vogel and what Indianaboys and I have posted
from:The Legacy of Marcel VogelOriginally posted by MonsieurM View Postwatch this presentation by Richard Hoagland, it is only 15 min
The Meaning of Elenin - Part 3 of 13 - Richard Hoagland Awake and Aware Sept 24th 2011.mp4 - YouTube
watch Les Brown video
The fundamental geometrical pattern of quartz and water is the tetrahedron. Water molecules, bound together, form tetrahedrons in tilted or puckered rings. This tilting happens because of the bonding angle that exists between any three water molecules. This angle is 109.5 degrees. The normal flat hexagon has angles of 120 degrees. Water molecules with smaller angles, if they are to be formed into a hexagon, must have an uneven structure that is not in a flat plane but is instead a three dimensional object. This uneven structure is formed by what is called the bending angle or angle of tilt. This angle can be between 20 degrees and 60 degrees, but the most common is 26 degrees. This is where the intermolecular bond is the strongest and it happens to be half of the interlattice angle of quartz. The second most common bending angle for water is 54 degrees which is quite close to the interlattice angle of quartz as well. 52 degrees. This is also the angle of the Cheops pyramid.The intermolecular bonding angle for the water molecule is 104.5 degrees. This is the angle that exists between the hydrogen atoms of each water molecule. It is virtually double that of the interlattice angle for quartz.It is possible that there is a compatible harmonic between water and quartz because of the similarity of these angles. This would allow a resonant transfer of the energies that are imputed to the crystal to a significant group of water molecules in any given sample.
The structure of quartz can replicate itself in water because of this resonant transfer based upon structure.
The geometric structure produces frequency patterns, harmonics, that can transfer into water (Solfeggio and you: see http://www.energeticforum.com/158989-post732.html ). Very small amounts of energy are required for this transfer. The nature of resonant systems is such that a minimal input can achieve a maximal output.
a fractal construct has an 'efficient function', it has a fractal ergonomy , it functions on multiple levels and in multiple dimensions:Last edited by MonsieurM; 10-22-2011, 11:03 PM.Signs and symbols -Confucius.
Dr VogelThe nature of resonant systems is such that a minimal input can achieve a maximal output.
As an example of resonant transfer, one can imagine a series of dominoes being placed across the United States. from San Francisco to Washington. Each successive domino would be slightly larger and heavier than the previous piece. By the time we reached Washington, the final domino might be as large as the Washington monument. By applying a slight push to the first domino, less than one pennyweight, each domino would be knocked over until the final piece was toppled. Through the introduction of a very small energy to a system the result is the production of enough energy to knock over the final very large and heavy domino.Last edited by MonsieurM; 10-22-2011, 10:59 PM.Signs and symbols -Confucius.
sorry for the repetition;This structuring is best assayed with a UV spectro-photometer where one finds an increase in UV absorption due to an increase in the water bonding from the water forming chains on itself. The magnetic moment of this structured water is increased by 0.07 gauss and there is also an increase in the pH and dielectric conductivity.
key word quartz
" Animated ash was a form of bamboo that was reduced to activated charcoal by means of a partial vacuum electrical carbon arc process. The resulting ash (alkaline ) pH in the system withEdgar Cayce often recommended animated ash and ultra-violet light therapy for persons suffering from cancer. The readings stated that the animated ash would increase the oxygen in the body and assist the immune system in fighting the cancer.
a tendency towards alkalinity.
so to increase the UV effect, an Alkaline diet would be recommendedImagine a medical tool where you take a UV laser pointer and place a healthy cell , like stem cells, contained in a quartz lens and then shoot the UV laser through it, which would carry the healthy information in the beam, to heal sick people .
Cancer Healing & Spirituality (4): Edgar Cayce on Cancer Causes and Treatment (2)
alpha_and_beta quartz
both alpha quartz and dna are coaxial helices
An electrostatic spatial resonance model for coaxial helical structures with applications to the filamentous bacteriophages.It is found that coaxial helices with optimally mated symmetries can lock into spatial resonance configurations that maximize their interaction. The resonances are represented as vectors in a discrete three-dimensional space[
see also: http://www.energeticforum.com/renewa...netism-25.html
note: if the Crystal skulls are alpha quartz they will surely resonate with your DNA .....
John W. Keely
...When these harmonics form unisons or direct harmonic relations the two vibrating aggregates and their chords of vibration are said to be sympathetic to each other. This unison of frequency dictates that what happens to one vibratorily happens to the other simultaneously.
G. Fantuzzi -- Orgone Accumulator -- French Patent 2264406Originally posted by MonsieurM View Postwhat do you think would happen if we placed a Smith/Caduceus coil wrapped around a barium titanate (or quartz) hooked inside a pyramid (as les brown described)
see: Peter GRANDICS: Pyramid convertor of electrostatic to DC electric power
from: http://www.rexresearch.com/trawoeger/pyramid.pdf
You''l find the same pyramids set up (as in the picture below) in Les Brown's BookDevice for Capture and Centralizing of Dispersed Energy
Also published as: NL7502964 // IT1004384 // JP50134886 // DE2509431 //
Inventor(s): G. FANTUZZI
Classification: - international: A01K67/00; A61N1/16; A01K67/00; A61N1/00; (IPC1-7): H01Q17/00 ;- European: A61N1/16
Also published as: NL7502964 // IT1004384 // JP50134886 // DE2509431 // BR7501588
The present invention relates to a device to collect, concentrate, bind and radiate wandering energy which is propagated on a electrical carrier wave, this device being made up by a surface in the shape of regular pyramid, octahedral, cone or surface of revolution, in particular a spherical surface, which are used as mean of collecting and concentration of the wandering or biological energy which is propagated on an electrical wave.
At the interior of the aforesaid surface in the pyramid which can be made out of an unspecified material, metallic or not, are mounted with an electrically insulting formed of copper rollings of helical whorls around axis parallels between them and with the axis of surface. The ends of said rollings exceed the basic wall of the pyramid and end in feet of copper which join the diffusers.
The aforementioned energy or biological energy which is propagated on an electrical carrier wave, concentrated by the aforementioned surface, induced in excited rollings up by the terrestrial magnetic field and by an optional auxiliary variable magnetic field a flow of energy which radiates outside through the feet of copper in the form of a beam of electric and/or electromagnetic waves.
While varying dimensions of the surface which collects the energy and while varying the number of rollings and/or the whorls, one can obtain devices with various possibilities.
from: http://www.energeticforum.com/renewa...rystals-2.html
[QUOTE=MonsieurM;147949]
Principle of correspondence
look what i foundOriginally posted by MonsieurM View Postand probably that is why Tesla used to weight his coils too, it is much easier than finding 5.914441183 feet
you too are related to Light speed
More importantly, at this higher concentration of salt the DNA returned to near its original length with a final measured indicating complete dissociation of Rad51.from: Structural transitions within human Rad51 nucleoprotein filamentsQuite different conditions exist in my system in which the electromagnetic waves or radiations are designedly minimized. the connection of one of, the terminals of the transmitting circuit to the ground having, itself, the effect of reducing the energy of these radiations to about one-half, Under observance of 'proper rules and artifices the distance is of little or no consequence, and by skillful application of the principle of "individualization," repeatedly referred to the messages may be rendered both non-interfering and non-interferable. This invention, which I have described in technical publications, attempts to imitate, in a very crude way, the nervous system in the human body.' Nicolas Tesla
original text:
btw: we talked about salt see: http://www.energeticforum.com/153076-post152.html
Rules of Harmonics
MonsieurM,Originally posted by MonsieurM View Postand probably that is why Tesla used to weight his coils too, it is much easier than finding 5.914441183 feet
From the Bruce Cathie Grid Point Atlas Manula 2010
http://www.worldgrid.net/documents/g...as40manual.pdfhttp://www.google.com/url?sa=t&rct=j...lLSaSA&cad=rja
This may be a quicker link to the same file if still active and not having to wait:
http://dc314.4shared.com/download/bU...13828-e8d36919
IndianaBoys
Harmonics and the power of numbers - Chapter 8
MonsieurM,
This is an interesting document that references Cathie's work:
http://www.quantumk.co.uk/quantumk/C...0Harmonics.pdf
Thanks Indianaboys, downloading the book right now...more brain food
reading through the pdf doc http://www.quantumk.co.uk/quantumk/C...0Harmonics.pdf
just an interesting fact: 12 = 1 + 2 = 3 ; and 3 + 3 + 3 + 3 = 12Using numbers to heal
So, having briefly explored some of the basics around the power of numbers, it is time
to return to their specific relevance to health and the human body.
The number twelve has special significance within the human body - we have 12 pairs
of ribs, 12 thoracic vertebrae, 360 joints, 12 energy meridians etc. The number twelve
also underpins time keeping and is central to the bible and many spiritual belief
systems. You will even find it underpinning the design of genuine crop circles.
pushing it a little further into the 6 3 9 logic
3 = (6 9 )
3 is composed of the union of 6 and 9 so
12 = (69 ) + (69) + (69) + (69)
If we take this logic to its natural conclusion, the harmonic sequences affect our DNA,
our DNA is connected to some form of crystalline lattice and this is in turn connected
to an electro-magnetic Earth grid (as examined by Bruce Cathie) and then through to a
cosmic grid. As we change, so we change the grid around us and the planet.More importantly, at this higher concentration of salt the DNA returned to near its original length with a final measured indicating complete dissociation of Rad51.Last edited by MonsieurM; 10-23-2011, 10:34 PM.Signs and symbols -Confucius.
Multiview Mirror Pyramid Panoramic Cameras
Multiview Mirror Pyramid Panoramic CamerasIntroduction
Panoramic images and video are useful in many applications such as special effects, immersive virtual reality environments, and video games. Among the numerous devices proposed for capturing panoramas, mirror pyramid-based camera systems are a promising approach for video rate capture, as they offer single-viewpoint imaging, and use only flat mirrors that are easier to produce than curved mirrors. To date, the designs proposed typically capture panoramas from a single viewpoint.
Mirror Pyramid Cameras
[back to top]
A mirror pyramid consists of a set of flat mirror faces arranged around an axis of symmetry, inclined to form a pyramid. By strategically positioning a number of conventional cameras around a mirror pyramid, the viewpoints for the individual cameras� mirror images can be colocated at a single point within the pyramid, effectively forming a virtual camera with a wide field of view.
Mirror pyramid-based panoramic cameras have a number of attractive properties, including
high resolution, and
video rate capture.
Currently existing designs realize a single viewpoint within each mirror pyramid. In order to capture panoramas from multiple viewpoints with these designs, the entire physical setup would need to be relocated or duplicated. The former solution lacks the capability of video rate imaging, and the latter leads to bulky designs due to the multiple mirror pyramids.
In our paper we proposed a method for generalizing existing designs such that multiple viewpoints can be created in a single mirror pyramid. This enables simultaneous multiview panoramic video rate imaging with a compact design.
do you see the triangle in the center and the resemblance to a pineal gland
(Color) Seven snapshots of a cavity created when a round disk with an m = 20 azimuthal disturbance (shaped like a 20-petal daisy) impacts a water surface with velocity v = 1 m/s. Clearly, the 2% initial disturbance is retained until the very end, and is seen to oscillate several times during expansion and collapse. The diamond-shaped structure of the cavity near pinch-off (d), resembling the skin of a pineapple, reflects the history of these oscillations. (Time after impact: a: 33 ms, b: 77 ms, c: 95 ms, d: 104 ms, e: 107 ms, f: 125 ms, g: 200 ms.)
How flowers catch raindrops (Principle of Mentalism)
AmadorFlowersLarge.mp4 - YouTube
remember Mohr's Invention http://www.energeticforum.com/162785-post936.html
Otto MOHR
check out the gallery of fluid Motion ...Beautiful Pictures
Gallery of Fluid Motion - Physics of Fluids
btw:
Lots of water spotted in a still-forming solar system 175 light years away
Using the Herschel space telescope, astronomers have spotted evidence of water vapor at the edges of a planet-forming disk surrounding a nearby star. The presence of the vapor hints at enormous volumes of ice present in the disk.
Ancient Secrets
MonsieurM,
Here is one I believe you will enjoy, lots of parallels to this thread:
Ancient Secrets
137 page PDF
https://www.dmt-nexus.me/doc/Ancient%20Secrets.pdf
Denice Krueger ([email protected]) wrote: "I raise and train German Shepherd dogs. One November 12, 2000, I went to Aldergrove, BC, Canada to visit a friend who had some puppies she wanted me to see. We took pictures of a few dogs with different people, a
total of two rolls of film. I was thinking about buying the puppy in the picture and so we decided to take some pictures of me with that puppy. Later, when I got the pictures developed I just glanced at them and then put them away because I had decided not to buy that dog. Most of the pictures were of other people with other dogs. My son had also looked at the pictures when he picked them up for me. Neither of us noticed anything at all unusual
about them. At the end of December 2000, we went back up to the same friend's house in Canada. I decided to take the pictures along to give them to my friend so she could give the pictures to the new owner of the puppy. I had no use for them. At the last minute, I decided to look through them one last time for some reason. That's when I noticed that four of the
pictures out of two rolls had this white light. The pictures were not right next to each other on the negatives. There were pictures in between that did not have this light in them. Here are two of the pictures. I had the pictures and the negatives examined by a film expert who used to work in film analysis for the government. He had no explanation for what the light could be.
He said that a hair would be refractive and that you would not be able to see through it like you can this light. In the first picture, the dog and I are looking up for some reason. I have no memory of anything strange while we were taking the pictures."
The vortex energy seen on the pictures above and below are some of the unique energies being caught on film. You can see in Denice's pictures the "snake like energy" that has been seen at ancient sites for thousands of years. This is also why healing energy and connecting to spirit was "symbolized" by the snake. In the picture below to the left you can see the
energy emerging. There are historical and modern descriptions of this energy being seen above people's heads at ancient sites. The Aldergrove, B.C. area seems to be part of a larger vortex area that should be investigated by someone local. I have also heard of reports about crop circles in this area. This is no surprise, for these vortex-grid areas seem to attract UFOs, crop circles, etc. I can supply more information on this upon request.
IndianaBoys
