notice the angle of the sphere's
The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Thanks Dave, I'll try to find more info on the Transmitter:
Peculiar discoveries attend his researches. For one experiment, he placed a copper electrode in a flask through which high-frequency current was conducted to a liquid. The liquid vaporized and passed through a second flask into a graduate, where it condensed. A quantity of metallic copper collected at the bottom. No heat had been generated, yet somehow the metal was transmuted through vapor and condensed again. On another occasion, he distilled and treated a quantity of carbon tetrachloride, which ordinarily will not burn. Yet after bombarding it with ultra-short waves, it became highly inflammable. Why? Wilkinson cannot say.He went to work to find a motor fuel which could be created from fruits or vegetables. He treated decayed fruit with electricity, produced both alcohol and lubricants. Then he discovered that by adding products obtained from sour cottonseed oil to the alcohol, he had an efficient motor fuel. For good measure, among the byproducts was a material which looks, smells, and bounces like crude rubber. He submitted several pieces to a Los Angeles laboratory, and in a few days received a sheet of refined rubber.The electrode of lead is located in the solution, on or near the bottom of the tankl and is connected to the positive or negative pole of a source of direct electric eurrent (more likely pulsed ) and a copper wire mesh screen serves as the other electrode. The screen has suitable stiffening means and is electrically insulated from the treating tank and the lead plate, and is located above the spirally coiled pipe at approximately the contacting surfaces of the oil and the solution. When a source of direct current is connected to the electrode electrolysis of the solution is produced as will hereafter be more explicitly referred to.Last edited by MonsieurM; 11-15-2011, 03:20 PM.Signs and symbols -Confucius.
Originally posted by MonsieurM View PostThanks Dave, I'll try to find more info on the Transmitter:
more here: Francis E. WILKINSON -- High Frequency TransformationsThis invention relates to aerial devices for use with radio or television receivers or transmitters.
The invention has for its primary object an improved aerial device whereby better reception and greater effective radius can be attained.
A further object is to provide an improved mounting whereby the aerial device is rendered directional.
A further object is to provide an improved aerial device which provides for alternative ways of connecting it to a radio receiving set.
According to the invention an aerial device comprises a pair of tubular members of non-magnetic conducting material in axial or substantially axial alignment but insulated from each other and each communicating at its outer end with a hollow sphere of said material, each tubular member having extending therethrough at least one rod or bar of ferro-magnetic metal surrounded by a coiled conductor insulated from the tubular member and each conductor having an extension eoiled in opposite directions about the end portions of the poles of one of a pair of permanent magnets, and means for connecting the coils to a radio receiver or transmitter.
It is not essential that each rod or bar be unitary as they may each be laminated or comprise a bundle of wires of ferromagnetic material, and the term rod or bar when hereinafter employed is to be interpreted as including such variations.
Referring now to the accompanying drawings:Fig. 1 is a part sectional plan of an aerial device according to the invention, the section being taken on the line I-I Fig. 2; 50 Fig. 2 is a transverse section of Fig. 1 taken on the line II-II of that Figure; Fig. 3 is a diagrammatic view to show the wiring more clearly, the terminals and connections of the wiring thereto; Fig. 4 is an elevation showing the device supported on a mounting; Figs. 5, 6, 7 and 8 are diagrams showing various ways by which the device can be connected to a radio receiver or wireless set; and Figs. 9 and 10 are diagrams showing how the device can be connected to a television receiver.
In carrying out the invention two tubes 1, 2, are provided of non-magnetic electrical conducting material which may be brass or copper, each tube having its inner end provided with a flange 3, 4. The outer end of tube 1 communicates with the interior of a hollow sphere 5 which is of the same metal as the tubes and the outer end of tube 2 communicates with the interior of hollow sphere 6 also of the same metal as the tubes. Each tube 1, 2 and its sphere 5, 6 are shown in the drawings as being integral with each other but may be manufactured independently and secured together as by brazing and if desired the spheres may each comprise hemispherical sections also secured together by brazing. The tubes are secured as by screws 7, 8, extending through the flanges 3, 4, to opposite sides 9, 10, of a easing constructed of wood or other suitable insulating material. Layers of insulating material 9a, 10a are preferably provided one between each flange and the adjacent wall of the easing.
I would highly advise you read this thread
from:http://www.energeticforum.com/renewa...tic-field.html
sorry for thatOriginally posted by skaght View PostOriginally posted by skaght View PostXenomorph,
I've read through the material on EH-antenna.com a number of times. From my reading of the material, the core is supposed to be conducting, but non-ferromagentic. Copper or aluminum should fit the bill. In addition, I believe their HZ antenna has two coils wound in the same direction on the conductive, non-ferromagnetic core separated by a small gap. I've been planning on building my own version of this, but haven't had time this week due to work demands...
I'd be curious if you get a chance to build such a beast if it displays any different types of behavior.
S
I guess then I have to shorten the list:
non-ferromagnetic conductive substances : , ]copper aluminium, air and water and maybe graphene/Carbon....Tesla...
Peter Davey, Tesla , the Water Purifier , Wilkinson.......find the link
weird: Sun today — solar flares onlineLast edited by MonsieurM; 11-15-2011, 04:29 PM.Signs and symbols -Confucius.
I forgot to add the following to the Previous Pictures:
Using magnetic vortex as eddy heater. - YouTube
Here is an interesting visual effect i noticed when searching Tesla's Patent:
from http://www.tesla.hu/tesla/patents/p-...6/p_056_01.gif
a zoom out version of the picture, please note the wave like effect
the zoomed in version:
Interesting, isn't it.....what do you guys think of that
Principle of Mentalism: The Universe is all waveLast edited by MonsieurM; 11-15-2011, 07:03 PM.Signs and symbols -Confucius.
Here is an extensive list of Tesla's Patent, I think Dave also posted one:
Pepe's Tesla Pages: Nikola Tesla
Guys as I was searching Tesla's Patent, I stumbled on a little piece of info
found this which relates to Peter Davey's Sonic Heater
THE NEW TESLA ELECTRIC HEATER *
by Nikola Tesla
STRICTLY CONFIDENTIAL
This device is greatly superior to the usual flat core type in efficiency and other respects. It consists of a thin polished metal tube acting as reflector and a base equipped with switch and connecting terminals and carrying spaced resistor wires concentric with the tube and at a certain distance from the inner surface of the same. In this arrangement the diffuse radiation is virtually eliminated, and the heater operates as if the resistor were not present, the rays being projected from the reflector radially to the central or focal region occupied by the boiling pot.
The principal advantages thus secured are the following:
1. A very high efficiency, as much as 96% being attainable.
2. The efficiency is practically the same whether the pot is large or small since the density of the rays is inversely as the diameter of the vessel.
3. Due to these features the current consumption is hardly more than half of that in the best heaters of the type referred to.
4. The resistor has a relatively much longer life and can be made to last almost indefinitely in some cases. Also less wire can be used if desired.
5. The heat being largely confined to the range, the kitchen remains comparatively cool.
6. Another practical advantage is greater safety from a variety of accidents frequently occurring with ordinary ranges.
7. The-new heater is especially adapted for use on shipboard, Pullman cars, aerial vehicles and automobiles.
8. Likewise, it is suitable for all kinds of service on the table, being free from the objections of the present type.
9. It saves considerable time in certain applications.
10. Owing to simplicity, the cost of manufacturing is low.
MECHANICAL THERAPY *
by NIKOLA TESLA
In order to convey a clear idea of the significance and revolutionary character of this discovery it is indispensable to make a brief statement regarding ELECTRICAL THERAPY.Signs and symbols -Confucius.
this was posted a while back:
Thanks RomoOriginally posted by petar113507 View PostHow would you control those "defects" with a frequency? what freq. would it be? Would it be in the growing phase of the crystalline structure? Or after th crystal was grown, to be bombarded with a certain "resonant" frequency which would spontaneously induce super conduction?
I think that super-conduction has to do with a certain shape. So, for instance migrating atoms, or leaving an empty part
That was the original point of looking at superconductivity -- was with the intent to be able to build it. So, I've been looking a little bit at silicon recently, as that is very easily obtainable for me near the beach.
Why is silicone interesting? Because we are made of carbon. Carbon is one half octave away from silicone.
Silicon is used in all of our modern day transistors and microprocessors. Silicon is also an element which is quite common around the world. Powerme left a vauge process for refining beach sand into high purity silicon, but I think I understand it. Hooking up HHO torch soon, so I will try this method of refining.
Carbon, is also the element which crystalizes into diamond -- the crystaline structure also becomming superconductive after doping with 3% boron. Boron comes just before carbon on Russell's table.
Superconducting diamond turns up in Russia - physicsworld.com
So why does silicone become superconductive when doped with boron?
Similarly, silicone carbide and aluminum become can also be superconducting. (you'll have to google it, I cant find it but read it earlier)
What does this tell me? Look at russell's charts. We are playing very similar atomic chords when we are cooling the silicone to superconductivity.
You know how you can play the same note on a piano, and shift one octave up? It sounds higher up, but you are still playing the same "note". I imagine that supeconductivity is a "note" that may be acheived in a vaiety of ways.
With that, I would also like to point out that silcon, having a similar cubic crystal to carbon. I am curently wondering if the shape of the crystal being formed has a link to superconductivity.
This seems to be what this article suggests.
Superconductors Go Fractal - Science News
Can you elaborate a little more on M-state water and "quantum water"? I do not like to ask too many questions without sharing my understanding, to make sure we are on the same page.
I am under the impression that water (the fractal antenna) briefly possesses a structure which induces very small windows of "superconductivity" near the center contracting axis of the vortex shape. I am under this impression that the magnets might "knock" the little superconductors out of position -- impregnating the water with a more electric property.
This has at least been supported by my experience with using one of these simple devices.
Seeing as how our nervous system would become more sensitized after consuming this type of water, I beleive that my body would give me a "good" response (the water tastes sweeter) when I drink it.
It seems to make moss, and grass grow very vigorously (resilient to drought), and greener than the other, faucet-watered areas.
MM, you post very rapidly. I would love to continue "thinking out loud" in an open group, but it takes a bit longer than I'd like to fully articulate my thoughts. I will reply when I can -- you have my full attention.
Thank you for the brainfood
from the article:
Physicists at the Russian Academy of Sciences are claiming to have created a form of diamond that superconducts. Vladimir Sidorov and colleagues say that their material, which they made by doping carbon with boron at high temperatures and pressures, exhibits bulk superconductivity below around 4 kelvin and remains a superconductor in strong magnetic fields (E A Ekimov et al. 2004 Nature 428 542).This is the first time that boron-doped diamond -- which is normally a semiconductor -- has shown superconducting behaviour.
this website is quite interesting for those that are not well read on Tesla: here is just a small excerpt:
those are active links1905-07-16: Tesla On The Peary North Pole Expedition
1907-03-__: Signalling to Mars - A Problem of Electrical Engineering
1907-03-08: Tuned Lightning
1907-03-20: Tesla's Wireless Torpedo
1907-03-26: Wireless on Railroads
1907-05-02: Nikola Tesla Objects
1907-05-03: Tesla's Tidal Wave to Make War Impossible
1907-05-19: Mr. Tesla on the Wireless Transmission of Power
1907-06-23: Can Bridge Gap to Mars
1907-10-19: Sleep From Electricity
1907-10-22: Possibilities of "Wireless"
1907-10-25: Tesla on Wireless
1907-12-20: My Apparatus, Says Tesla
1908-__-__: The Future of the Wireless Art
1908-01-05: Nikola Tesla's Forecast for 1908
1908-04-21: Mr. Tesla's Vision
1908-06-08: Little Aeroplane Progress
1908-09-15: Tesla on Aeroplanes
1909-05-23: How to Signal Mars
1909-12-24: Nikola Tesla's New Wireless
1910-01-16: What Science May Achieve This Year - New Mechancial Principle for Conservation of Energy
1912-05-__: Mr. Tesla on the Future
1912-07-06: The Disturbing Influence of Solar Radiation on the Wireless Transmission of Energy
this one is intriguing:
1919-02-__: Famous Scientific IllusionsLast edited by MonsieurM; 11-15-2011, 09:18 PM.Signs and symbols -Confucius.
By the way one of the crystals i found through my research and has a good potential is:Originally posted by MonsieurM View Posttthis was posted a while back:
from the article:Originally posted by petar113507 View Post
Tourmaline - Wikipedia, the free encyclopedia
Tourmaline is a crystal boron silicate mineral compounded with elements such as aluminium, iron, magnesium, sodium, lithium, or potassium. Tourmaline is classified as a semi-precious stone and the gem comes in a wide variety of colors. The name comes from the Sinhalese word "Thuramali" (තුරමලි) or "Thoramalli" (තෝරමල්ලි), which applied to different gemstones found in Sri Lanka.
you can also see it here but a bit different (which in a way exclude a printing effectOriginally posted by MonsieurM View PostHere is an interesting visual effect i noticed when searching Tesla's Patent:
here is a version of Walter Russell where you see the same pattern and guess what is the subject discussed
posted this earlier...
Originally posted by MonsieurM View Postweird: Sun today — solar flares online select the 15thLast edited by MonsieurM; 11-15-2011, 11:23 PM.Signs and symbols -Confucius.
