The Golden Tractate of Hermes Trismegistus applied to electromagnetism
    Principle of Mentalism: The Universe is All Wave
    from the link you provided:
    "What is the ether and why is it so difficult to detect it? I reflected on this matter for a seriously long time and here are the outcomes I have been led to: I think that all the contradictions about whether the ether exists or not are the result of wrong interpretation of ether's properties. The ether has always been presented as an aeroform environment [gaseous]. That was the essential mistake. The ether has a very strong density. It is known that of more dense a substance, the higher is the speed of wave propagation within it. When comparing acoustic speed in the air and the light speed I have drawn a conclusion that ether density is several thousand times higher than air density. It is not the ether that is aeroform [gaseous] but the material world is an aeroform to the ether!" Nikola Tesla
    follow up
    "..The results show that the frequency producing the greatest stress relief occurs at the resonant frequency (natural frequency). The reduction of residual stress after resonant vibratory treatment can attain 97%. Sub-resonant VSR treatments get less or no residual stress relief, depending on the frequency level applied."
    This process saves a great amount of heat energy to do the same stress relief using just vibration. This gives an indication of small amounts of energy applied in a resonant fashion has a notable heat energy equivalence - irregardless of the heat loss from the furnace.
    principle of correspondence
    Most people are familiar with the popular laser pointing devices. Laser light is unique in that it is a powerful beam of 'coherent' light. Coherent light means vibrating light with the same momentum, frequency, and phase. This type of light is 'triggered' in a material by an escalating light 'bouncing' back and forth between mirrored ends in an energized material. It is simply a photonic version of people doing 'the wave' in a stadium. Energized electrons in an atom are triggered into emitting a 'photon' of light as 'the wave' comes through. It is synchronized light - or coherent light.
    Signs and symbols -Confucius.
    • Now, back to vibration. All vibration should include three forces; Coulomb force, Van der Waals force, and Casimir effects at the atomic level. Dr. Willis Lamb in the 1940's measured a single atomic effect called the 'Lamb Shift'. This is an effect where Zero Point Energy affected the atom and caused a upward 'shift' in the orbital levels of the electrons. Now we are up to four types of factors.
      • I also found this:More of my antique diathermy machine (Tesla Coil) Wireless Electricity! - YouTube
        for color comparison here is a previous pic posted:
        What You Should Know About DIATHERMY
        • Just how it works, nobody knows. The patient is placed between antenna-type electrodes—but what happens within the body is still a mystery. We know that heat is generated by the motion of molecules, and apparently the molecules of the body are stirred into a fast jig by the fluctuations of the high-frequency field. But aside from mere heat, there seems to be some unique organic effect having to do with still unknown forms of physiological energy transformation.
          Principle of Correspondence
          Actually you do now...replace the Tesla coils with the patient...and keep the sparks
          compare the colors:
          • from: http://www.energeticforum.com/168367-post1372.html
            New magnetic-field-sensitive alloy could find use in novel micromechanical devices
            (PhysOrg.com) -- Led by a group at the University of Maryland (UMd), a multi-institution team of researchers has combined modern materials research and an age-old metallurgy technique to produce an alloy that could be the basis for a new class of sensors and micromechanical devices controlled by magnetism. The alloy, a combination of cobalt and iron, is notable, among other things, for not using rare-earth elements to achieve its properties. Materials scientists at the National Institute of Standards and Technology (NIST) contributed precision measurements of the alloy's structure and mechanical properties to the project.
            talking about 6 3 9 , what if i told you 6 is iron 3 is cobalt and 9 is copper
            we know about the 6 3 Alloy is iron Cobalt...it would stand logical the alloy 3 9 would have the opposite properties
            if 6 3 is magnetic then 3 9 is ....
            • a little change of perspective....
              always good to know
              • New magnetic-field-sensitive alloy could find use in novel micromechanical devices
                From the Golden Tractate
                "Know that this matter I call the stone, but it is also named the feminine of magnesia, or the hen, or the white spittle, or the volatile milk, the incombustible
                check out Russel's Table MALE and FEMALE
                • btw: the previous article was posted: November 23, 2011
                  You make the commitment and nature will respond to that commitment by removing impossible obstacles. Dream the impossible dream and the world will not grind you under, it will lift you up. This is the trick. This is what all these teachers and philosophers who really counted, who really touched the alchemical gold, this is what they understood. This is the shamanic dance in the waterfall. This is how magic is done.
                  ― Terence McKenna
                    compare the colors:
                    MM I have one of these machines, its in good shape still works, Im afraid of it Im not kidden this thing is straight out of the Frankenstein movies sparks everywhere.
                    I picked it up at a thrift store 25 bucks its too kool.
                      the Universe works in mysterious ways
                      Queen - Radio Ga Ga - YouTube
                      from: http://www.energeticforum.com/renewa...netism-37.html
                      posted this a while back
                      check this out
                      5 Million Volt Tesla Coil Charged Pyramid - YouTube
                      • Dave, if you intend on using it, please wear the safety helmet
                          thats what I look like when its running
                          • I havent tried it with any of my projects might give it a try
                            There are quite a few different designs the one I have has three spark gaps its pretty bizarre
                            • Dave, you be careful ...don't want the Miss to open a can of .....
                              from: http://www.energeticforum.com/renewa...tml#post165695
                              [QUOTE=MonsieurM;165345]First of all Principle of Mentalism + Principle of Correspondence
                              Shawn ....Remember Dr Boyd....
                              from: Allais effect - Wikipedia, the free encyclopedia
                              The Allais effect is a claimed anomalous precession of the plane of oscillation of a pendulum during a solar eclipse. It has been speculated to be unexplained by standard physical models of gravitation, but recent mainstream physics publications tend rather to posit conventional explanations for the reported observations.
                              The effect was first reported in 1954 by Maurice Allais, a French polymath who went on to win the Nobel Prize in Economics. He reported another observation of the effect during a 1959 solar eclipse.
                              anisotropic characteristics, which he ascribes to motion through an aether which is partially entrained by planetary bodies. He has presented this hypothesis in his 1997 French book.
                              Magnetic anisotropy is the direction dependence of a material's magnetic properties. In the absence of an applied magnetic field, a magnetically isotropic material has no preferential direction for its magnetic moment while a magnetically anisotropic material will align its moment with one of the easy axes. An easy axis is an energetically favorable direction of spontaneous magnetization that is determined by the sources of magnetic anisotropy listed below. The two opposite directions along an easy axis are usually equivalent, and the actual direction of magnetization can be either of them (see spontaneous symmetry breaking).
                              Magnetic anisotropy is a prerequisite for hysteresis in ferromagnets: without it, a ferromagnet is superparamagnetic.
                              • here is an interesting video
                                double bashar coil (walter rusell coil) as flux capacitor - YouTube
                                I charge it with HV with a joule thief 10 turns in a flyback. 24v input. 1000`s v output.
                                The hv hot is conected to the coil, ground to the" cubic" chamber (orgon acumulator).
                                I use stirofoam balls for isolation and observe the behavior of the ion wind.
                                I charge every coil i find and just the bashar/rusell works as "flux capacitor".
                                Single coil works too, but walter rusell in "A new concept of the universe" show how the equator of the coil "pulses", then I put some metal betwen 2 bashar coils and it works!!!
                                full explanation Walter Rusell 2 pairsConical forces
                                Russellian Science: "A New Concept of the Universe", by Walter Russell, part 1 - YouTube
