Hi All,
One of my most admirable scientists of today who does not worry about rubbing up a few people in the wrong way, is V.I.Korobejnikov.
His theories which have been supported both by events and in practice are one of the futures in our strive for a clean energy. His 3D electromagnetic field is one of the systems that I use and has been put into practice.
I am going to share this with you so that just maybe a new insight into electromagnetic waves will inspire some of you to view what has been seen as anomilies in certain threads in this and other forums, and start designing to create what many think is impossible.
First I want to show you a very disturbing fact:-
On the anomalous secular increase of the eccentricity of the orbit of the Moon
Lorenzo Iorio
(Submitted on 1 Feb 2011 (v1), last revised 21 Feb 2011 (this version, v3))
A recent analysis of a Lunar Laser Ranging (LLR) data record spanning 38.7 yr revealed an anomalous increase of the eccentricity of the lunar orbit amounting to de/dt_meas = (9 +/- 3) 10^-12 yr^-1. The present-day models of the dissipative phenomena occurring in the interiors of both the Earth and the Moon are not able to explain it. We examine several dynamical effects, not modeled in the data analysis, in the framework of long-range modified models of gravity and of the standard Newtonian/Einsteinian paradigm. It turns out that none of them can accommodate de/dt_meas. Many of them do not even induce long-term changes in e; other models do, instead, yield such an effect, but the resulting magnitudes are in disagreement with de/dt_meas. In particular, the general relativistic gravitomagnetic acceleration of the Moon due to the Earth's angular momentum has the right order of magnitude, but the resulting Lense-Thirring secular effect for the eccentricity vanishes. A potentially viable Newtonian candidate would be a trans-Plutonian massive object (Planet X/Nemesis/Tyche) since it, actually, would affect e with a non-vanishing long-term variation. On the other hand, the values for the physical and orbital parameters of such a hypothetical body required to obtain the right order of magnitude for de/dt are completely unrealistic. Moreover, they are in neat disagreement with both the most recent theoretical scenarios envisaging the existence of a distant, planetary-sized body and with the model-independent constraints on them dynamically inferred from planetary motions. Thus, the issue of finding a satisfactorily explanation for the anomalous behavior of the Moon's eccentricity remains open.
This goes along with a paper by V.I.Korobejnikov which changes totally the concept of gravity, which can be found on the web.
As far as the above and the Moon, I would prefer someone take this on and make a new thread so as I can keep this for 3D electromagnetic fields and how they are created and how they can be used to create a new form of energy generation.
Over the last couple of years I have given hints to this and with very little interest it seems, this even enters the work of Dr. Stiffler, though he might disagree and so we will probably agree to disagree and that is fine with me.
I stated that the theories of V.I.Korobejnikov have been put into practice, well yes in a system of RF, oh yes RF has come up again, electromagnetic waves. A company EH Antenna systems have been working along with Korobejnikov to make an antenna to use a 3D electromagnetic wave which has some very unusual effects. Please read the paper here:-
In fact please read all of their site as it will give you an insite to all of this better than I can and it will save me a lot of typing
From time to time I will post here more on this subject as my time becomes available, which is a bit thin on the ground at the moment with all of my projects taking priority.
Enjoy and learn, things or lights will start lighting, pun intended
Mike
Lorenzo Iorio
Mike
