progress report
Hi all,
Not too many posts behind me but I actively follow this forum for some time and in last 30 days or more, I have been following this topic.
Reason I didnt reply here sooner is because I didnt have anything to report (at least nothing worthy).
Now I am here with some news.
In last 15 or 20 days (dont know precisely) I have been tinkering with this. I even bought a device that can change frequency of AC. I have aquired different transformers to test different voltages, I purchased different materials, different shapes, different gaps, different sizes and different resonate frequencies.
THINGS I DIDNT TEST are 50Hz sanding and sphere shapes.
Tested materials with 100 Hz frequency and many many more.
In course of testing this device, I tested at least 30-40 DIFFERENT setups. I even disassembled air purifier that has very nice setup for this device. Multiple plates with + and - separated and very neatly mounted on bars. anyway, like I said, I tested a LOT, but I want to name all I tested (at least what I can remember) since it might assist someone in what they want to do or give an idea:
Soooo here is what I tested.
at least 20 different setups involving. Cans, stainless steel tubes, copper tubes, aluminum tubes of different dimensions(height/diameter). Thinner ones resonated on 100Hz - 106.1 Hz, thicker ones I couldnt find resonating frequency (ALL resonating frequencies were discovered very precisely by using 2 methods. Microphone to analyzer then high volume MONO speaker against object with something very small touching it). So I tested them against each other. Some with same resonate frequency, some with higher frequency on outside, then inside, then - outside +inside, then +outside, - inside.
Then I tested all setups on different frequencies by doing VERY VERY slow sweep through very small range by range.
Then I tested all above setups with AC power frequency changed to resonate frequency of inside + power used, then -.
Then I tested IKEA setup (bought very nice thermos) with bottom cut off, tested it in different setups.
Tested all above, especially 100Hz resonating ones of inside tube on regular 50Hz AC power with all setups.
Anyway, I tested a whole lot, wasted a lot of time (I dont mind).
Once again, I DIDNT test prof.savic recommended process of sanding can to 50Hz (I tried to sand it to 50Hz but I just get wholes whenever I get closer to 50Hz, can just gets too thin and it ruptures and if I sand further, it ruptures and makes a big hole).
I also didnt test sphere shaped object, simply cause I didnt find any good ones or suitable.
Finally, after all testing, I did get instant bubles a lot and thats all nice, I was able to heat various quantities of water fast BUT what I didnt get is OU. I sincerely doubt there is any here. I mean, I got something you could call OU with COP of 1.1, several times, but I write that off to mistakes of WATT meter. This is 1.1 COP compared to the theoretical energy needed to heat water to boiling temp of 100 C.
One more thing, when measuring do NOT get fooled by having top of your water containing jar boiling. STOP, stir the water, then proceed. You can get first 2 cm of water boiling while the rest is cold!
I know it is said there are "people" who have achieved OU but after all this testing (and more that I dont remember) I sincerely doubt it (this goes for people testing tubes in ways I did, not for experiments I DIDNT do such as savic can sanded to 50Hz or whatever else there is and I didnt test it)
I wish you all luck, I will take a break on this one, hope to hear others update their progress.
Hi all,
Is frequency 200Hz good instead of 400Hz ?
