Hello Everybody, I thought I would start a thread to debate what real efficiency is.
There are apparently two types of efficiency. Total efficiency and Working efficiency.
In this video Peter explains it. @ 6:15 mins
Free Energy Research 3/14 - YouTube
1. Total efficiency is output divided by input. TE = out/in
2. Working efficiency is output divided by input minus losses. WE - out/in-loss
Now a working efficiency rating is useless without knowing the total efficiency to compare it to.
So for example if I have a machine that has an input of 348 watts under a load
of 182 watts output then the total efficiency is roughly 52.3 %.
So losses are 47.7 % or 166 watts .
But the working efficiency is 182 / 348 -166 = 100 %
So then if I had a machine more inefficient with the same 348 watts input
under load of only 166 watts output then the total efficiency is about 47.7%.
So losses are 182 watts or 52.3 %.
But the working efficiency is 166 / 348 - 182 = 100 %
Or an even more inefficient machine with an input of 348 watt under a load of
88 watts output then the total efficiency is about 25.2 %.
So losses are 260 watts or 74.8 %.
But the working efficiency is 88 / 348 - 260 = 100%
So there we have it. Which is better to go by ? Total efficiency or working efficiency ?
And output means taken out of the system so a short does not really count
as a load.
Does anyone have anything to add to this. I don't care much for working
efficiency although it has it's uses for determining losses.
If my calculations are wrong please let me know.
For people chasing the elusive so called "OU" they will need to exceed 100%
total efficiency.
as a load.
total efficiency.
Umm What kind of motor ?
