hi farmhand
i have been watching your motor project it should be pretty interesting.
i used two different rated neon bulbs i hunted down a Mousier the one on the cap is rated at 95V and the one for the SCR gate is a 65V other than that it is all the same.
i thought about making it bigger and adding some switch in caps but that would be later down the road. i am getting some pulses but when i read across the battery terminals with my meter it is like the 65V is not present maybe because it is over the whole battery and i am just rising and falling on the wave.
if the SCR is on all the time the gate neon would not be triggering as all would be pretty much the same voltage so would think it would not light at all.
i am pretty sure this is not normal desulfating as well it seems to use little power and is making me use my brain which needs some exercize. i built it because of some things i tried before with batteries and how well they worked i would reccomend building this one for the learning if nothing else.
it is not a tune charger or a bedini charger but it is interesting if i add another cap i will make it so they switch in and out so i can choose what size to work with and how fast they charge, not sure charging is the right term for what this does.
thanks for the interest.
Martin
Martin
I'm not sure of the types of generator and motor you mean, I think I see
I think I have beat my head against this wall enough for one post.
