Small Mag motor demo
  • Small Mag motor demo
    Guys, check these please, Not sure if genuine,sent to Panacea by Claus Turtur, thank you Claus and for the individual backing them up, dont know ANY details or claims yet guys
    free energy generator 2 - YouTube
    free energy generator - YouTube
    Ash
    Ash
    WOW
    Thank you for posting this!
    -Altrez
      The coils look like the ones found inside old computer monitors , their litz wire wound on ferrite spools, I wonder if the rotor is diametrically or axially magnetized. The battery?
        This was already posted by Martin.
        I believe it is directly related to this circuit:
        Here is the video:
        SMSMAT - YouTube
        If you pay close attention, these are basically the same circuit but of a modified configurations. Instead of a magnetic ball, he uses a cylinder attached to a flywheel - do this and some slight modifications and you have the original video's machine.
        The guy that made the original circuit is this guy:
        ZEROPOINT132's Channel - YouTube
        Ok, there you have it guys, go at it.
          Thats similiar to mine Ash, those are button cell batteries between the springs on the one video and on the other video he's charging up a cap and running it off that.
          I guess its time to go jump down his throat to.
            Yeah looks to me like it runs from the energy stored in the rotor from the Dremel
            and a battery in the number 2 video free energy generator 2 - YouTube
            And looks it runs from the energy stored in the rotor from the Dremel and a
            capacitor in this video.free energy generator - YouTube
            No free energy battery and grid power used.
              Hi Mark, SilverToGold, Farmhand Et ALL
              Thanks for the input, i wonder if Prof Claus is messing with this, will keep my eye on it, thanks again for the feedback and posting all that guys.
              Ash
                Thanks for the post Ash. Looks to me like the next step in the progression on circuits from Tesla/Bedini where the magnetic field is recycled into a battery, to Anislie where it was recycled back into the original coil until disapated into heat, and now it is recycled into another coil to provide self powered turning of the system. I believe the assumption that the device mounted between the springs is actually a magnetic activated relay just like the diagrams indicate. If it was a battery the device would not turn since the wires leaving it go directly to the coils. A switch has to exist for the device to turn and since he went to the trouble to show everything I did not see another object that would be a reed switch. I was also impressed with the demo of the meter with a battery since it showed that the only two outside wires attached to the device was not a source of energy as some people might think. All in all I am impressed and hope you might ask the people involved if they would consider giving up enough info so that we might attempt duplication
                  Hi realmikel, Just after he spun up the device the cap voltage settled to a fairly
                  steady voltage of about 68.5 volts then about 2:30 mins later the voltage is
                  about 66 volts, then at about 5:35 in the video the cap voltage started to drop
                  fast so he quickly disconnected the voltmeter.
                  My guess is the reason the voltage started to drop fast is because the battery
                  was becoming drained. If it was self running at a steady state speed with no
                  load on the cap the voltage should have stayed stable but as was obvious it
                  was going to keep going down. Time was up.
                  EDIT Granted the volt meter is a load but it should have regained voltage if
                  the rotor did not slow down, he spins it up with the dremel so accelerating up
                  to speed won't drain the little batteries in my opinion.
                  That's video number 2 I'm talking about.
                    one of the guys in our group has been working on this and run time is extended but the circuit is not the same as the original as it did not work so something is wrong.
                    the one inch sphere we are using runs at 7.5 hz when spun by hand.
                    no real results to post yet so will let folks know when we do
                    Martin
                      Noticed your point yet felt that it was when he crosswired the cap while returning the meter connections that overloaded the system for a second and I heard the unit slow down that caused the voltage drop off. I am not sure that that the unit can regain speed back to bring the voltage back up to the original voltage in the configuration that is being used. I noticed that you did not explain how the " battery" as you call it was commutated by any other device on the machine. If that device is a battery then where is the reed switch to allow the motor to work?
                        he dont need reed switch nor Hall IC... he can switch the coils "a la bedini", one of the coils just need to have 2 windings...
                        in the second video there is a button cell between the magnets, and on the first one i can spot a small transistor next to the electrolytic cap...
                        its like magic, your eyes allways tell you something that is just an illusion! just like all other hoax's... this guy is not an energy researcher, he is an illusionist!
                        Light, I Am!
                          How odd, no matter how many times i review the clips I only see 4 diodes wired in parallel. and a cap. I assume "a la bedini" means comutation by transistor. Please show where the base, emitter and collector are wired into the circuit? As best I can tell the wiring diagram is reflected exactly in the clips. Biflilar coils require multiple wires to have any meaning? Where are the separate circuit wires utilizing the transister you claim to see?
                          • #14
                            That is not a transistor. It only has 2 leads. Not 3 like a transistor. Look at time 0:51 in the first video, it clearly only has 2 leads - like a reed switch perhaps. Though it does not look like any reed switch I've ever seen.
                            • #15
                              In the second video posted by Ash... does anyone have any idea what that small cylindrical object he inserts into the machine is? Looks like a battery to me... lol. Or maybe it's a cap? Just weird....
