The electric field of a magnet
Awesome vis Dave...amazing workmanship...reproducing all those inventionOriginally posted by Dave45
Thank you...quite inspiring
side note
the last one, I was wondering if we replaced the wooden cubes in the end with magnets ...It would not add more force ..you know adding the pull and push to gravity
Signs and symbols -Confucius.
Hubbard Coil and barbat Patent
@Dave45
Your post # 342 to # 371 I have not given up on the Alfred M. HUBBARD Coil Generator assembly. Here is the setup patented by William BARBAT US Patent Application # 2007/0007844. The link is
William Barbat: Self-Sustaining Electrical Generator; United States Patent Application # 0070007844 Self-Sustaining Electrical Generator
On your Post #416 Ignition Coil oscillator driver circuit, please find attached a draft circuit proposal
I hope it helps
JJ
It kind of makes sense, trying to recreate a sinkholeOriginally posted by Dave45I believe it takes rotation in one form or another either mechanical or induced, even in the Hubbard coil there is rotation the coils firing in succession in a circular pattern.
If we take water in a bowl just sitting there its static but if we rotate the bowl we add kinetic energy to the water.
We really dont need torque all we have to do is spin the coil the easiest way possible, high voltage will do it and we can also induce rotation by design.
resembles thisOriginally posted by Dave45Here's a link to Patrick Kelly's work,http://www.free-energy-info.co.uk/ btw thank you Patrick its people like you that will change this world for the better.
In chapter five there's info on the tpu and this wiring diagram
looks like a design made to rotate to me
Hook this to the flip flop circuit
Hubbard Coil
I had the winding direction of the shorted coil wrong, if we are to collect the field from the shorted coil it must be wound the same as the primary.
I went an picked up the transformer today this thing is huge, cant wait to get into it.Last edited by Dave45; 01-11-2012, 02:40 AM.Half of the Answer is knowing the right Question
Hubbard Coil
I think we can use a 1:1 wiring ratio, it just needs to be large enough to handle the amps at the end, and if you really think about it all we need is 12 volts at about 60 amps continuous, at least for a start.
I think by using a 1:1 ratio resonance should be a given, spacing the coils and diameter to length I think it would be wise to look at the golden ratio.
I read somewhere Hubbard said he used to different sized wires in his device, he may have stepped up the voltage some and we could step it up easy enough but we really need amps.
I wonder if we step up then step down the next coil but used the same size wire in both coils would we get a resonant reaction between them or between all six or eight
something to think about
Last edited by Dave45; 01-11-2012, 02:35 AM.Half of the Answer is knowing the right Question
Hubbard Coil
Let me rephrase that if we used say 12 ga. to 16 ga. in the first coil - step up
then used 16 ga. to 12 ga.- step down and alternated this same guage through out the system would we get a resonant reaction between all the coils.Last edited by Dave45; 01-11-2012, 02:35 AM.Half of the Answer is knowing the right Question
Iv been thinking of the magnetic model and the electric field that accompanies it
heliospheric current sheet 2001 till 2009 - YouTube
Fibonacci's Fractals - YouTube
We are not the only ones waking upHalf of the Answer is knowing the right Question
JJ do you think we can build the coils with just one winding but say 15 inches in length, by one winding I mean one for the shorted coil, one for the primary, and one for the secondary.
your thoughts would be greatly appreciated
daveHalf of the Answer is knowing the right Question
@ Dave45
If you read the second research, paper in my post #418 PPMT test apparatus by Joseph Flynn it clearly demonstrates the gain in total force on the armature pull-off test.
http://www.energeticforum.com/attach...d=13261538
Thanks for the heads up, Im going to start building soon there are alot of test that need to be done, some have stated its too complicated but I feel it will be no more complicated than building a pulse motor.Originally posted by myenergetic View Post@ Dave45
I was thinking about Hubbards coil he had two end caps if the end caps are a ferrous material then this would be a transformer of sorts, closing the magnetic field but allowing it to draw energy into the system.
I dont think it will be that complicatedHalf of the Answer is knowing the right Question
Quote "
your thoughts would be greatly appreciated"
@Dave45
In that case we shall be building the "Tesla Kapndz Zilano etc.." series but it requires some adjustment to accommodate the electrostatic charges generated by the magnetic field, a kind of conversion circuit as suggested by Zilano cw ccw secondary circuit.
Dave concept is everything: Hubbard coil works by the principles of micro cyclotron. Where the energy is taped @ moments of basic molecular oscillating frequency resonance (a fractal frequency) as neuview stated, (It is about a scalar wave inducing a charge density and current density having the velocity c even if the charge and the current are not in the same coil,) which coupling of molecules in the coils takes place.
Combining both principles requires some thought it might be hard but not impossible.
JJ
or perspective
