The electric field of a magnet
  • So we've been studying structure chasing down clues, does it have merit?
    One more confirmation and another piece of the puzzle
    Amazing Discovery With Magnets - YouTube
    • We use layered cores to try and separate the eddy currents from the magnetic field, we are going about it wrong, we need to collect those eddy currents.
      In a motor the magnetic field expels the current carrying wires, it pushes the electrons in the wire out to the outer edge of the magnetic field and it does it with a strong force, this gives our motors torque.
      The magnetic field running in the welding rod should do the same pushing the eddy currents to the outer edge where it can be collected in the copper winding.
      Eddy currents cause heating in the core, if youv ever run current through iron wire you know it cant take much before it gets very warm, but the magnetic field loves iron, we have to give each a path, iron for the magnetic field line and copper for the eddy currents.
      It would seem the size of the welding rods would make a difference, the larger the iron rod the stronger the magnetic field would need to be and the same for a smaller diameter rod the smaller the field could be.
      I really need to order some wire or make the drive.
      Just need to convince the wife , she gets ticked about the money , we cant really blame em I guess, but we have to, we have an obligation in life to try and help others.
      • @Dave45:
        Your points about the eddy-currents / magnetic-field makes sense. It seems like you're on to a sound theory. Keep it up and keep us posted.
        And good luck with your "frau" ~ 1 Peter 3:7.
        truesearch
        • I wound it with some old wire just to put a magnetic field through it, nothing out of the ordinary, it may need the opposite wound coils.
          I'll keep playing with it,
          later
          dave
          • Originally posted by truesearch View Post
            @Dave45:
            truesearch
            sAIN'T I37 LIfE a baa baa son-of-a-bit*h?
            137 the Cosmic Code | Alternative Thinking 37
            • What will happen. Maybe it can be used for metal detecting.
              • The more I think about it I believe this is the correct connection diagram
                In order to do this Im going to have to wind the ccw coils.
                Im not going to give up just yet
                later
                dave
                • Got stuck in the house all day, hidden numbers within the Fibonacci sequence.
                  • Dr. Peter Plichta who has studied chemistry, physics, and biology wrote that book.
                    he is just like you Dave, he sees himself as doing the work of god, he even refers to himself as St. Peter.
                    He recovered a prime number code that he calls the PRIME NUMBER CROSS
                    image on the left
                    Is it a coincidence his Prime Number Cross based on prime numbers is a good match for my prime number theory that suggest the Knights Templar Sator Rotas magic square is the treasure found in Solomon's Temple
                    see the image above right
                    You can read more about him here:
                    And here:
                    So I find it odd that King Dave-id wants to remain out of the loop?
                    It appears St. Peter Plichta and the ARKangLE RaphaEL will need to do it alone ...
                    • Its so simple, it boggles the mind
                      If the wire is wound at an angle we can give the field spin.
                      Its just a magnetic funnel
                      • Half of the Answer is knowing the right Question
                        • Dave,
                          By BEMF, are you referring to radiant energy?
                          I like where you're going, but my understanding is that in order to harvest the RE, you need a sharp voltage spike. The RE comes in from the aether between the spikes. You poke the aether, and the aether pushes back to restore balance to the disturbed system (to put it crudely).
                          With this in mind, I would think you'd need something at the bottom of your funnel to facilitate a discharge to disturb the system - perhaps a discharging cap with a spark gap grounded at far side, or perhaps a reverse-wired self-oscillating relay switch.
                          Maybe I've misunderstood you, but for what it's worth, you've got my interest.
                          Have a good day.
                          Bob
                          • Hey Bob
                            I havent built it or worked out the kinks but the idea is sound, Im going to build it soon, I believe it can be wound then twisted to give the wires an angle this will create a twisting vortex of aether funneled into a jet.
                            • Tesla's Egg of Columbus - YouTube
                              We know the magnetic flux is contained within the iron toroid so what field is turning the copper egg.
                              • Field strenght
                                Hi Dave,
                                I like this thread ,too bad most of it's over my head.
                                I am wondering what causes the magnetic field around a conducting wire to increase?
                                Is it voltage potential, or current flow?
                                The reason I ask is ,I'm running testes where with certain connections my leads react very strongly to permanent magnetic fields.
                                I can make my bi-filar coil float above the magnet?
                                Just wondering what causes the field to become stronger.
                                BTW ,I like that vortex idea.
                                artv
