I would thinkyou are right about you need bait.
my question would be if the local radio station is putting out say 1 mega watt of power any coil you would make of small wire would just burn up with that type of power input be it static or magnetic.
then you would need to time the bait frequency to the actual timing phase of the generated wave.
and then there is the question of grounding good or bad?
i would use a magnetic tickler as because you already pointed out the voltage should already be there and if energy has any inirtia it would need to be overcome to get it going.
Martin
Martin
